		Rick S.
				 Posted: Sun Nov 26, 2006 5:51 pm    Post subject: 2 Tailcone Questions: F-1012B came unpunched, small  tear in |
				Bill,
 The 1010 flange has been an issue since the beginning, I didn't have it but I know many others did. Some opted to buff it out and if I recall, were told it was OK by Van's to do that, other sent it back and recieved a replacment part. Personally for that small of a crack I would buff it back and smooth it out but I don't want to lead you astray, or what I mean is incur the "wrath" of the flame throwers....We had a joke a while back about the "Golden Rivet" this was the rivet that if not properly installed and it failed would result in a "zipper effect" of all rivets coming loose and you and your aircraft fluttering to the ground....oops...did I say flutter?  scratch that...I meant flaying to the ground.
 As for the 1012B, I believe mine was punched but that was kit #185. After seeing how Van's fabricaes the parts is strange that the holes were missed, I watched the machine make a few parts and it did holes cutting and then the part was stacked for stamping.....but the cutting and the holes were on the same process....don't know what to tell you except is easy enough to matchdrill it in assembly.
 Rick S.
 40185
  _________________ Rick S.
RV-10
40185 |
		wv4i(at)bellsouth.net Guest
				 Posted: Mon Nov 27, 2006 4:17 am    Post subject: 2 Tailcone Questions: F-1012B came unpunched, small  tear in |
				F1010 appears okay. F1012B flange NOT pre drilled/punched.
 Link McGarity
 #622 tailcone
		MauleDriver(at)nc.rr.com Guest
				 Posted: Mon Nov 27, 2006 6:02 am    Post subject: 2 Tailcone Questions: F-1012B came unpunched, small  tear in |
				Thanks for taking the time to give me the big pic.  I did go in and read
 the archives - that helps.
 Bill Watson - gotta prime!
 John W. Cox wrote:
 This subject was extensively posted when John Hilger received not one
 but three defectively formed items in a row. They (the responses) should
 all be in the archive. The posts at that time was "forgetaboutit", sand
 it, stop drill it or do the correct action.
 Require that the defective part is replaced with one which is correctly
 formed. Vans is great at that. You are the QC on all components
 installed.
				 Posted: Mon Nov 27, 2006 7:47 am    Post subject: 2 Tailcone Questions: F-1012B came unpunched, small  tear in |
				Found the F-1010 crack previous discussion and Van's answer. No hits on
 F-1012B lack of flange holes.
 Link McGarity
 #40622
		johngoodman
				 Posted: Mon Nov 27, 2006 8:38 am    Post subject: Re: 2 Tailcone Questions: F-1012B came unpunched, small  tea |
				I happen to be at that exact spot in building, as well. My F-1012B also does not have pre-punched flanges, but it looks easy to match drill. As far as the F-1010 crack, mine has two gaps in the flange of the hole. It appears that it was worked on. I'll check with Vans....
  	  | wv4i(at)bellsouth.net wrote: | 	 		  Found the F-1010 crack previous discussion and Van's answer. No hits on
 Link McGarity
 #40622
 do not archive |
				 Posted: Mon Nov 27, 2006 9:22 am    Post subject: 2 Tailcone Questions: F-1012B came unpunched, small  tear in |
				Talked to Van's this am re F-1012B flange. It is intentionally not
 PRE-drilled/punched so as to accommodate some variance in hole/skin
 alignment.
 Link McGarity
 #40622 tailcone
				 Posted: Mon Nov 27, 2006 11:28 am    Post subject: 2 Tailcone Questions: F-1012B came unpunched, small  tear in |
				Not sure I follow the thinking here.  Removing the visible tear simply
 removes the tear which
 could represent a focal point for local stresses.  It is the  most
 likely place for any stresses to  manifest
 themselves in further tearing.
 Without the tear, I'm thinking there is no focal point and no tear to
 propogate.  Whatever stresses exist
 in the piece remain.  Just because there isn't a tear in a replacement
 part doesn't mean there isn't the same
 set of  stresses in the part.  They just didn't result in a tear.
 If you are saying that the tear induces stress and the metal remembers,
 I guess I don't understand that.
 In any case, the tear needs to be removed or possibly stop drilled.  But
 doing either compromises the original
 intended strength of the piece so I agree it should be replaced.
 Bill Watson
 John W. Cox wrote:
  Removing the obvious (the visible crack) does not remove the adjacent
  induced stress which is yet to propagate.  Many who have stop drilled
  learn that lesson with time on their airframe after a perceived patch
  was signed off.  You are only cheating the inevitable. Metal has memory,
  it does not forget.  You are not going to fool it into long term
  submission.  We resort to Eddy Current and Ultrasonic more often that
  people know with our air carrier aircraft.
