Posted: Mon Nov 27, 2006 10:37 am Post subject: transponder antenna placement |
Hey all -
I was perusing the archives looking for info on the transponder antenna
placement, and I ran across mentions of microwaves cooking private
parts. Really? Come on... really? I'm looking at spots to mount the
antenna, and under the pilot / copilot seats seems like the best bet for
me. The tunnel is out, because I made a false floor that goes from the
firewall to the spar and I don't want any penetrations there. I was
thinking the transponder antenna under the copilot and the avidyne/ryan
traffic antenna under the pilot seat. I've already got comms under the
rear passenger seats, and navs in the wingtips. Is the transponder
really going to do a number on me or my copilot under the seats?
Inquiring minds want to know...
cj
#40410
fuse
www.perfectlygoodairplane.net
Rick S.
Posted: Mon Nov 27, 2006 10:54 am Post subject: transponder antenna placement |
Chris,
I have heard both....that it is harmful microwave energy from William Curtis who's electronic knowledge I trust and that it's bunk. I mounted mine on the bottom right side between the battery and the right sidewall behind the baggage bulkhead. It's outta the way, it is a long coax run but at least it's not near the nads, rumor or not
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
Posted: Mon Nov 27, 2006 11:10 am Post subject: transponder antenna placement |
How do you like 'em- sunny side up, over easy, hard boiled or poached.
Scrambled is not an option.
Seriously, what kind of material would be needed to stop the radiation?
Inquiring organs want to know.
John G.
| Quote: | From: "Chris Johnston" <CJohnston(at)popsound.com>
Subject: transponder antenna placement
Date: Mon, 27 Nov 2006 10:36:33 -0800
Hey all -
cj
#40410
fuse
jesse(at)itecusa.org Guest
Posted: Mon Nov 27, 2006 11:18 am Post subject: transponder antenna placement |
I can't speak to the sperm-count effect of the Transponder antenna, but if
you're out of the baby-making stage, then that might not matter anyway.
Let's go ahead and get the do not archive tag here.
I put mine on the tunnel just aft of the firewall, which allows for a very
short wiring run and keeps it away from the other cables and antennas. I
have the comms under the pilot and copilot. The main thing I would
recommend, if you are comfortable putting it under your seat, would be that
you have at least 30-36 inches between it and the comms, which shouldn't be
a big problem. Also, I understand that it is a good idea to keep the cable
run separate from your other antennas.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
bcondrey
Posted: Mon Nov 27, 2006 11:30 am Post subject: Re: transponder antenna placement |
Chris,
Below is from an exchange on this subject on the AeroElectric list - short version is that there isn't an issue.
Message: #10129 Date: Mar 10, 2003 From: "Robert L. Nuckolls, III" <bob> Subject: Re: defending the "familiy jewels" . . .
>A transponder antenna that close to your passengers "private parts"
>might not be the best thing to do. The radiation may do some damage.
>Rino
A hangar myth. Folks have looked at the
peak output power rating of a transponder (100 to 250W)
and tried to make a connection between a desire to
make one's airplane visible to a distant radar receiver
and cooking meat.
When you buy a microwave, it too is rated in the
hundreds of watts . . . but CONTINUOUS duty. A
good 700W microwave will boil a cup of water in
about 2 minutes. (Remember the traveler's immersion
heaters in the hardware store? They're 300W heaters
and take about 4 minutes to boil a cup of water).
If you measure the current draw of this machine,
it will be on the order of 8-9 amps or 1000W total
input.
Your transponder draws about 1.5 amps while being
interrogated for a total input power of 18W. The
output comes in the form of a series of 0.5 uSec
pulses in respond to an interrogation that represent
a string of binary numbers representing either your
squawk code (mode A) or altitude (mode C). Assuming
you are interrogated once per second (quite often)
your average output power for a 250W transponder
is on the order of 250W x 20 pulses x 0.0000005
seconds/1 second or 2.5 milliwatts per second.
This isn't going even going to warm up much less cook
anything.
Another fallacy of the myth concerns body parts
most sensitive to microwave radiation . . . turns
out that your eyes are the most vulnerable . . .
but the story isn't nearly so interesting to
really macho pilots. None the less, there are
folks who have armor-shielded their seat bottoms
in deference to this myth. The story was REALLY
popular about 15 years ago in the heyday of
the Long-Ezs
Here's a post I did on a canard pusher list
server about 5 years ago:
> Location away from the pilot/co-pilot is also
>recommended but over ten feet requires a different cable. Yes?? I was
>thinking about locating it aft of the pilot in the baggage area. Is that
>distance safe?
A totally bogus recommendation. A few years back, someone observed
that their transponder was rated for 200 watts output . . . 1/3rd
that of the family microwave. Our hero was immediately concerned for
preservation of the family jewels and proceeded to line the bottom
of his composite seat pan with aluminum foil. What he failed to
understand was that his RF coffee warmer and popcorn popper was
rated in continuous watts while the transponder was in peak watts.
The average power output from a transponder is less than 1 watt . . .
BTW, the eyes are about 100 times more sensitive to the effects of
microwave heating than are any deep organs . . . you'll go blind
you quit making babies.
AV8ORJWC
Posted: Mon Nov 27, 2006 11:33 am Post subject: transponder antenna placement |
This goes along with the original scientific studies used in 1983, when
cell phones were first sold that said everyone was going to get brain
tumors on the side closest the antenna on your hand-held.
I think it led to a lot of brain dead teenagers but no tumorous growths
in their adult life - yet. However, there are a lot of EA-6B Naval
Aviators that swear their love life was curtailed by the errant
electrons bouncing off the gold electroplated canopies from all that
jamming they did for Uncle Sammy.
Rick I would think the Air Force used similar stories on the girls in
your day. Just don't forget about Blue Nads from those forward NACA
ducts.
John Cox
40600
Posted: Mon Nov 27, 2006 11:39 am Post subject: transponder antenna placement |
Does the placement of the transponder antenna need to be as far forward
as possible, or am I making that up? I feel like I read that or heard
that somewhere. If I can put the antenna behind the bulkhead I'd love
it! is there a good argument (besides longer coax run) against putting
the antenna back there?
cj
#40410
fuse
dlm46007(at)cox.net Guest
Posted: Mon Nov 27, 2006 12:10 pm Post subject: transponder antenna placement |
Why worry? I have been flying light airplanes for thirty plus years and 4000
hours with the transponder antenna just below my seat. I had three healthy
children in my 20s and two healthy children in my 50s , the last at 55.
Tim(at)MyRV10.com Guest
Posted: Mon Nov 27, 2006 12:18 pm Post subject: transponder antenna placement |
If your com's are under the rear seats, having these antennas
so close may not be a good thing. I'm no expert, but I
do think they want 30+ inches or something like that, so
the more the better. The other suggestion of under
the tail seems OK though, despite the long cable run.
I opted to keep that cable short and put it in the tunnel.
Not sure if you could just do a penetration in your
false floor and grommet it to seal it up, but if you can
find a way to get it there, it's not a bad spot. Don't
put it way up right by the exhaust though....leave it back
a little.
Chris Johnston wrote:
Hey all -
cj
#40410
fuse
Posted: Mon Nov 27, 2006 12:20 pm Post subject: transponder antenna placement |
I think you're making it up. On my old certified plane it was back
behind the step area, under the tail.
cj
#40410
fuse
Rick S.
Posted: Mon Nov 27, 2006 12:26 pm Post subject: transponder antenna placement |
Well many a night we did radar ops checks and had to actually transmit, I never did trust those cones set out in front. I saw a guy throw a wad of steel wool out in front and watched it burst into flames...yeah I know not so smart in a slightly explosive enviroment but that convinced me that those invisible radio waves really could do some damage if they were powerful enough. That was almost as exciting as throwing a cement brick into an F-100 afterburner and watcing the force of full AB throw the brick a good 400 feet. The noise and vibrations off that AB was enough to make you feel sick to your stomach. All BTW you could not "see"
Some truth to the term that what you can't see CAN hurt you. Of couse that leads to why there is an eye patch on the stick of the Victor alert birds.....
Rick S.
40185
RV-10
40185 |
Rick S.
rvbuilder(at)sausen.net Guest
Posted: Mon Nov 27, 2006 12:59 pm Post subject: transponder antenna placement |
Sounds like a good episode of Mythbusters. Adam can put his nads in a
microwave and Jamie can sit on a transponder antenna while being
regularly interrogated or pushing ident. ROFLMAO!
Seriously though, I don't think anyone has ever done a serious study on
this. In reality any potential health issues are probably pretty small.
You probably get more rads from the solar radiation at 15,000 feet than
from the transponder. I still wouldn't put it right under my seat
though. The biggest issue in placement is keeping the antenna lead as
short as possible.
Michael Sausen
-10 #352 fuselage
Posted: Mon Nov 27, 2006 1:02 pm Post subject: transponder antenna placement |
Since we met when I visited your garage you will have to judge for yourself
Posted: Mon Nov 27, 2006 1:22 pm Post subject: transponder antenna placement |
Under the seat however, the moicrowaves would be going through several
layers of metal to find your privates, unless your a low hanger.
DO not archive
[quote]From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Subject: RE: Re: transponder antenna placement
Date: Mon, 27 Nov 2006 14:59:20 -0600
short as possible.
Michael Sausen
-10 #352 fuselage
Rick S.
billderou(at)yahoo.com Guest
Posted: Mon Nov 27, 2006 1:49 pm Post subject: transponder antenna placement |
The antenna placement recommendations from Garmin are:
1. place antenna 3 feet (physical measurement) from transponder unit
2. cable no longer than 8.8 feet of RG-400 (to handle the high power)
3. 30 inches (physical measurement) from any com antenna
4. Try to maximize distance from landing gear leg when placing under the seat to minimize
holes in pattern. Mine is too close but it works correctly.
Bill DeRouchey
billderou(at)yahoo.com (billderou(at)yahoo.com)
Flying with a few pit stops
"John W. Cox" <johnwcox(at)pacificnw.com> wrote:
[quote]--> RV10-List message posted by: "John W. Cox"
ducts.
John Cox
40600
AV8ORJWC
"Rads on the Nads". A new section for Tim on the RV U site. Leave it
to Michael to get us all ROFLMAO.
John Cox
40600
Do not Archive
Posted: Mon Nov 27, 2006 6:45 pm Post subject: transponder antenna placement |
Not having to do any testing myself ... ..... I'll side with bunk!
First of all, the energy just isn't there, and the average energy is
way lower than that so ..... make your own assessment. Lets face it
... microwave ovens work on the resonant frequency of water molecules.
I haven't a clue what that frequency really is, but the transponder
frequency probably isn't anywhere close. I'd liken it to the cell
phone/tumor thingy.
Linn
do not archive .... because I just may be blowing smoke!
Rick wrote:
Chris,
Rick S.
40185
wv4i(at)bellsouth.net Guest
Posted: Tue Nov 28, 2006 3:46 am Post subject: transponder antenna placement |
My comm and xpdr antennas in my RV6 are roughly 30" apart, have no
problem, are located under the seat area, etc. The avionics are basic
King 76 and 97 series. Keep in mind that the radiation patterns of
antennas so located are mostly directed away from the aircraft (and you)
by the aircraft skin, the latter which provides an RF ground plane.
Metal between you and any RF emission is better. Further away is also
better, as the strength of the RF field decreases with the square of the
distance. The antennas' distance apart recommendation goes mostly to RF
interference and to a lesser extent the possibility of detuning one
antenna by virtue of its proximity to the other. Rather than get into
all the theory and math behind the recommendations, BEST to just follow
the recommendations and move on (or take up ham radio like me). The
other issue that arises, besides inter station interference, is the
possibility of pumping too much RF into a nearby receiver front end of a
2nd radio/xpdr, while transmitting on 1st. This can damage the receiver,
but mostly only an issue with similar avionics, i.e. xpdr vs xpdr, comm
vs comm, etc.. Also, Bob Nuckolls' points re effective radiated power,
pulsed, duration, etc. are well taken (know he'll sleep easier now).
Radar is, as John C noted, a different story, while pulsed, is in
MEGAwatts, and also at very harmful frequencies, but it is highly
directive, AWAY from aircraft. Softer body tissue is most vulnerable to
RF exposure. Last, when considering antenna placement location, SIMPLY
consider the most often direction of the target station from the
aircraft, and seek the best, practical, unobstructed, line of sight
antenna location, thereby avoiding nulls. Nav antennas in wing tips,
okay if you must, but one in each wing tip then, would be better, re nulls.
Ready to put out the flames here.......as always.
Link McGarity
#40622
