cjhukill(at)cox.net Guest
Posted: Tue Nov 28, 2006 7:21 am Post subject: Flowscan bushing |
I reamed the Flowscan to accept a standard aluminum bushing to allow for a AN3 bolt, and removed enough material to penetrate the sender's wall, and cause it to leak. ( these are VERY thin walls) After spending another $250 to replace the sender, I then turned down a couple more bushings on the lathe, so they would fit the existing holes in the Flowscan, without removing any material from the Flowscan.
Anyone need a leaky Flowscan, Cheap?
Chris Hukill
buildus interuptus during major home remodel
(I though airplane parts were expensive!)
