Posted: Tue Nov 28, 2006 4:56 pm Post subject: Stupid questions |
Okay, I've been away from power planes too long.
What is a marker beacon antenna for? Don't say a marker beacon. Is it for
IFR equipment.
Do strobes have to be located on the wing tips.? I thought that when I used
to fly power they were also found on the belly. Am I imagining this.
If on the belly is okay, why not just put in one light rather than two on
the wing tips.
Thanks,,
John Gonzalez, Do Not Archive my ignorance in this matter. Finished Drilling
teeth for the day.
Posted: Tue Nov 28, 2006 5:36 pm Post subject: Stupid questions |
The marker beacon is IFR equipment that has going out of common use for
some time. The beacons themselves are being decommissioned and GPS
usage has replaced much of their use in the cockpit. I think they are
only required on Cat II and III approaches (you and I won't be doing any
of those in the '10) However, any audio panel you install will probably
have marker beacon lights (they are pretty). It just occurred to me
that I have no idea where the receiver is for the marker beacon.
Have you been flying gliders? I know how that feels. You won't be
interested in marker beacons even if you fly IFR. You are new school by
definition - only old school guys will insist on them.
So, I wonder whether I'll install a marker beacon attenna? Don't know.
Bill " I"m taking a break tonight" Watson
John Gonzalez wrote:
for IFR equipment.
used to fly power they were also found on the belly. Am I imagining
this.
on the wing tips.
Thanks,,
Drilling teeth for the day.
rvbuilder(at)sausen.net Guest
Posted: Tue Nov 28, 2006 5:42 pm Post subject: Stupid questions |
No such thing as a stupid question, just stupid people. Wait, don't
think that came out right.
Anyway, the Marker Beacons (also known as Fan Markers or Fan Beacons
for the radiation pattern they emit) are used to identify approach fixes
under IFR flight. Usually Outer, Middle, and Inner. The old saying
goes that some have attached the coat hanger to the back of the MB
receiver and picked them up. I opted for a slightly better arrangement
and you can see it below. Doesn't have to be anything pretty as they
are fairly high power, directional, and you fly fairly close to them.
<http://www.mykitlog.com/users/display_log.php?user=msausen&project 2&c
ategory=624&log=6520&row=4>
Michael Sausen
-10 #352 Fuselage
jhstarn(at)verizon.net Guest
Posted: Tue Nov 28, 2006 6:07 pm Post subject: Stupid questions |
| Quote: | Okay, I've been away from power planes too long.
IFR equipment.
I just looked in ACS ..no three light marker beacons. Next I'll be looking
up GCA. OLD marker beacons were on IFR final approach to the end of the
runway & lit up as you passed over their cone signal. Remember: "On center
line, on glide slope"..... OR Did I just date myself....again 8*)
used to fly power they were also found on the belly. Am I imagining this.
I had a strobe on my first 172 mounted on the belly 'cause it was so LARGE &
HEAVY to mount anyplace else. Modern ones are small & light, suitable for
wing tips.
| Quote: | If on the belly is okay, why not just put in one light rather than two on
the wing tips.
With them on the wing tips you have better total sky coverage AND they
"wink" (back & forth, left/right) if set up to alternate. They cause others
to "see" motion in the sky, in daylight too.
| Quote: | John Gonzalez, Do Not Archive my ignorance in this matter. Finished
PS: The only ignorant question is the one NOT ASK. KABONG Do Not Archive.
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Rick S.
Posted: Tue Nov 28, 2006 7:18 pm Post subject: Stupid questions |
A marker beacon antenna can be nothing more than a 40" strip of copper wire glassed into the wingtip. 14 ga solid romex stripped will do a good job. So will stripped off coax wire.
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
bob.kaufmann(at)cox.net Guest
Posted: Tue Nov 28, 2006 8:17 pm Post subject: Stupid questions |
Hey there has been a time or ten when a PAR has saved my bacon. Something
about iced up, dead VOR and fog at PDX flying night mail. UGLY, UGLY,
UGLY.
Bob K
Moving furniture, or honey do. LOL
Vern(at)teclabsinc.com Guest
Posted: Wed Nov 29, 2006 8:23 am Post subject: Stupid questions |
Hi John,
The link below is a pdf file outlining the anti collision lighting
requirements and distribution pattern.
http://www.creativair.com/source/_inst/requirements.pdf
Vern (40324 fuselage)
Posted: Wed Nov 29, 2006 8:47 am Post subject: Stupid questions |
Thanks, that's a great link.
John G.
[quote]From: "Vern W. Smith" <Vern(at)teclabsinc.com>
Subject: RE: Stupid questions
Date: Wed, 29 Nov 2006 08:21:54 -0800
Hi John,
