Posted: Sun Nov 26, 2006 6:19 am Post subject: Weight of the IO-540? |
Can anyone give me a rough estimate of what their IO-540 and the aluminum
propeller weight is?
Just trying to do some planning estimates.
JOhn G. 409, Thinking about electrons
jim(at)CombsFive.Com Guest
Posted: Sun Nov 26, 2006 6:55 am Post subject: Weight of the IO-540? |
IO-540 (C4B5) is somewhere around 420 lbs
2 bladed Hartzel is approx 80 lbs
Someone else may have more exact numbers.
Jim C
N312F
40192
Date: 2006/11/26 Sun AM 09:19:26 EST
Subject: Weight of the IO-540?
n223rv(at)wolflakeairport Guest
Posted: Tue Nov 28, 2006 7:46 pm Post subject: Weight of the IO-540? |
Or you can think of it as $100 per lb..... For both the engine and
propeller! Pretty scary...
Do not archive...
Rick S.
Posted: Wed Nov 29, 2006 6:43 am Post subject: Weight of the IO-540? |
I saved a few pounds,
Barretts XIO-540 "Lightweight"-397 pounds
MT 3 blade-47 pounds
Don't hold me to those...It's off the top of my head
Buuuuuuuut....I think it's more than $100 a pound
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
mritter509(at)msn.com Guest
Posted: Wed Nov 29, 2006 7:38 am Post subject: Weight of the IO-540? |
Rick - How far aft will the empty CG move with the light front end?
| Quote: | From: Rick <ricksked(at)earthlink.net>
Subject: RE: Weight of the IO-540?
Date: Wed, 29 Nov 2006 06:40:30 -0800 (GMT-08:00)
Rick S.
40185
MSN Shopping has everything on your holiday list. Get expert picks by style,
age, and price. Try it!
http://shopping.msn.com/content/shp/?ctId=8000,ptnrid=176,ptnrdata 0601&tcode=wlmtagline
Posted: Wed Nov 29, 2006 8:09 am Post subject: Weight of the IO-540? |
I think it is more like $110.00 per pound.
Good point.
[quote]From: "Mike Kraus" <n223rv(at)wolflakeairport.net>
Date: Tue, 28 Nov 2006 22:45:27 -0500
Do not archive...
Rick S.
Posted: Wed Nov 29, 2006 8:28 am Post subject: Weight of the IO-540? |
Not too concerned but the W & B will tell....I think I will be able to get rid of the bag of lead in the back seat when flying with just two like during my demo ride in the factory RV-10.
My initial thought is the lighter front will create a more balanced CG. There are others with the same combo so I'm not to worried. Besides....weight is a whole bunch easier to add than remove.
Rick S.
40185
RV-10
40185 |
Posted: Wed Nov 29, 2006 9:40 am Post subject: Weight of the IO-540? |
Rick,
I have a three blade MT prop (love it) but no light weight engine (Aero
Sport). My CG only moved aft a small amount - not enough to take the shot
bag out of the baggage compartment. My experience has been with one or two
folks on board I make better landings (still waiting for that perfect 10)
with the shot bag in the back and two notches of flaps.
Mark (N410MR - in paint shop)
Date: Wed, 29 Nov 2006 11:26:40 -0500 (EST)
Rick S.
40185
View Athlete’s Collections with Live Search
http://sportmaps.live.com/index.html?source=hmemailtaglinenov06&FORM=MGAC01
jesse(at)itecusa.org Guest
Posted: Thu Nov 30, 2006 6:16 am Post subject: Weight of the IO-540? |
With the hartzell up front and full fuel and two people (front seats), we
find that it handles fine on landing if you just don't use full flaps. Full
flaps makes it a little harder to get the nose up.
As was mentioned before, it is always easier to add weight that to remove
it. Just be careful when flying full (at or near gross) because then your
CG will be further aft, which is worse.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
apilot2(at)gmail.com Guest
Posted: Thu Nov 30, 2006 6:44 am Post subject: Weight of the IO-540? |
I wonder what is different about #2 demonstrator/prototype as far as
W&B/CG with the lighter Cont. IO-360 up front. It would seem that
similar adjustments could be made if you planned for lighter
engine/prop combination while building the fuselage.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
