dfmoeller
Posted: Wed Nov 29, 2006 5:24 am Post subject: Making a Vixen File Tool |
OK, here's an easy one for those who have made hand held (wooden handle)
deburring tools out of half-length vixen files, as depicted in the video on
scratchbuilding released by HomebuiltHelp.com.
How on earth would one drill screw holes through the hardened tool steel of
the file????? I've broken more than a few bits, and yet to scratch the
surface! I'm guessing that heat must be applied to the file to undo the
tempering, but doesn't that ruin the file?
Anybody that has been there; done that, would be more than welcome to give
me a tip or two.
Doug
carlossa52(at)gmail.com Guest
Posted: Wed Nov 29, 2006 5:36 am Post subject: Making a Vixen File Tool |
Doug, if you are thinking of deburring holes, consider fine sand paper.
I have used it with very good results.
Carlos
CH601-HD, plans
On 29/11/06, Doug Moellering <dfmoeller(at)austin.rr.com (dfmoeller(at)austin.rr.com)> wrote:[quote] --> Zenith-List message posted by: "Doug Moellering" <dfmoeller(at)austin.rr.com (dfmoeller(at)austin.rr.com)>
me a tip or two.
Doug
zodie(at)adelphia.net Guest
Posted: Wed Nov 29, 2006 5:59 am Post subject: Making a Vixen File Tool |
John.Hines(at)craftontull Guest
Posted: Wed Nov 29, 2006 6:21 am Post subject: Making a Vixen File Tool |
At the bank and stuff.
John R. HinesIT ManagerJohn.Hines(at)craftontull.com Office: 479-878-2449 Mobile: 479-366-4783 Fax: 479-631-6224 www.craftontull.com901 N. 47th Street, Suite 200 ·Rogers, AR 72756 Crafton, Tull & Associates, Inc. exists to anticipate and understand the needs of our clients and provide them with successful solutions.
Posted: Wed Nov 29, 2006 6:29 am Post subject: Making a Vixen File Tool |
Oops! Sorry guys, I responded to the wrong email. Sorry.
Chris Lewis
Posted: Wed Nov 29, 2006 6:39 am Post subject: Re: Making a Vixen File Tool |
No drilling required!
Skip the drilling and just bond the file to the wooden handle with some JB Weld-type epoxy (make sure the file is clean!). Drill a couple of shallow holes up into your wooden handle to help prevent shearing of the top side of the epoxy joint. Don't forget to chamfer the edges to prevent digging in if you get off level while deburring.
Enjoy.
Chris in Seattle
_________________ 750/ Zen-vair Semi-Scratch Builder
N750XT (reserved) |
zodierocket(at)hsfx.ca Guest
Posted: Wed Nov 29, 2006 1:07 pm Post subject: Making a Vixen File Tool |
Doug, please go with the Epoxy method. Bonding the Vixen file is a lot
better then the screw method. Don't forget to knock off the edges.
Mark Townsend
Can-Zac Aviation Ltd.
president(at)can-zacaviation.com
www.can-zacaviation.com
Michael Valentine
Posted: Wed Nov 29, 2006 1:22 pm Post subject: Making a Vixen File Tool |
Sorry to ask the obvious, but how does one cut the file in the first place???
Michael in NH
Chris Lewis
Posted: Wed Nov 29, 2006 1:29 pm Post subject: Re: Making a Vixen File Tool |
Cutting Vixen File
You could just use a cut-off wheel to score both sides part-way through and then place the file in a vise and whack it with a deadblow hammer. It should snap right off. Grind to suit your curved end shapes and then chamfer the sharp edges to prevent gouging
Chris in Seattle
N750XT (reserved) |
crvsecretary(at)aol.com Guest
Posted: Wed Nov 29, 2006 1:35 pm Post subject: Making a Vixen File Tool |
Drop it on the floor! Ok, only kidding (sort of...)
Files are VERY hard, and that makes them very brittle. Secure the file in a vice (with soft jaws) where you want the file to break and smack it close to the break zone with a rubber mallet - it will snap like a dry straw.
WEAR SAFETY GOGGLES !!!!
Best Regards,
Tracy Smith
N458XL reserved
wings in process....
ggower_99(at)yahoo.com Guest
Posted: Thu Nov 30, 2006 10:24 am Post subject: Making a Vixen File Tool |
and dress as a S.W.A.T.
Saludos
Gary Gower
crvsecretary(at)aol.com wrote:
[quote] Drop it on the floor! Ok, only kidding (sort of...)
Best Regards,
Tracy Smith
N458XL reserved
