JAPhillipsGA(at)aol.com Guest
Posted: Wed Nov 29, 2006 11:55 am Post subject: Buying a Partial Built Kit |
Dear Thread Friends, I'm looking to buy a kit that the original owner has finished most of the tail and part of a wing. A couple questions arise. What documentation for sale to satisfy the FAA for certification is required? When I bought my XL kit directly from ZAC I received a sales certificate that I had to include a copy of to the FAA for certification. Who out there has bought a started kit and successfully got it through FAA ? Second question is what amount of work can be accomplished by the first builder that will still allow me to be granted a repairman's certificate when I get her flying? That is the "tall pole" in the tent because I would not own a plane I can't work on. Hope to hear soon from some of you smart fellows. Best regards, Bill of Georgia
N505WP
601XL-3300
96 hours [quote][b]
agbeyer(at)sbcglobal.net Guest
Posted: Wed Nov 29, 2006 2:07 pm Post subject: Buying a Partial Built Kit |
A friend of mine just finished and is now flying a Zodiac HD. He got the kit from a guy that had the wings and tail stuff already done. He had no trouble with the FAA. I am not sure what steps he took to register the plane. The best guy to talk to is Joe Norris of the EAA. He is in Aviation Services and is a DAR. He did the inspection on my HDS. As far as working on your plane the FAA told me that a trained monkey, or your wife can work on the plane, but you need the Repairmans Cert. to inspect it.
Al from Oshkosh
HDS-3300 (N645AB)
275 Hrs.
Posted: Wed Nov 29, 2006 2:52 pm Post subject: Buying a Partial Built Kit |
I just am in process of registeting the plane on the famous -01 FAA paper. if amateur status, equals 40 hr fly off but repairman's certificate for annuals is literally automatic. Option two is LSA status which equals a 25 hour fly off, but would need to take 16hour repairman's license. You friend probably did what a lot of people have done, sign that it was 51% amateur built.
Juan
Posted: Wed Nov 29, 2006 3:36 pm Post subject: Buying a Partial Built Kit |
Hi Juan,
I think you could be mistaken on the 25 hour phase I test period for
LSA airplanes. We had one fellow get only 5 hours for a Kitfox last
year. The inspector (not DAR) felt the engine and propeller were
established (not certified, though) partners and decided a 5 hour
test period was appropriate.
On the Experimental-AB choice the minimum is 25 hours and 40 is
required if the power plant is considered a new combination or design.
I believe the down side of Experimental - LSA is the requirement for
the 2 day course for authority to sign off annual condition inspections.
Best regards,
Paul
XL fuselage
At 02:51 PM 11/29/2006, you wrote:
| Quote: | I just am in process of registeting the plane on the famous -01 FAA
Juan
gfmjr_20(at)HOTMAIL.COM Guest
Posted: Wed Nov 29, 2006 4:32 pm Post subject: Buying a Partial Built Kit |
"documentation for sale to satisfy the FAA for certification is required"
Bill--
I bought my kit from an individual. You will need the FAA Bill of Sale
to be filled out by you and signed by the seller. In addition you will need
to call Zenith and have them send you a Bill of sale showing the sale to the
original purchaser. The government is looking for a complete chain of
ownership. The last question is tougher----it depends. Typically it depends
on how good you are at convincing the FAA inspector or DAR that you
assembled 51% of the kit. Remember you don't really have to have assembled
51% of all of the kit parts , only items that are listed as part of the 51%
effort. For example you would not have to have assembled all of the ribs,
just enough to understand how to do it etc.
Keep a good log and photos of your efforts
I've built 2 planes under these conditions and never had any issue with
the FAA.
Hope that helps
George May
601XL 912s 13 hours
View Athlete’s Collections with Live Search
http://sportmaps.live.com/index.html?source=hmemailtaglinenov06&FORM=MGAC01
Posted: Wed Nov 29, 2006 5:15 pm Post subject: Buying a Partial Built Kit |
Thanks George, Every little bit helps, Bill
do not archive [quote][b]
Posted: Wed Nov 29, 2006 5:17 pm Post subject: Buying a Partial Built Kit |
just quoting what EAA specialists at EAA told me. 25hours LSA or 40 Amateur.
Juan
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Wed Nov 29, 2006 6:00 pm Post subject: Re: Buying a Partial Built Kit |
When I bought my wing kit partially assembled by somebody else, he had the forethought to give me his ZAC bill of sale. See if you can get the same.
DaveG
btucke73(at)yahoo.com Guest
Posted: Wed Nov 29, 2006 9:59 pm Post subject: Buying a Partial Built Kit |
Bill,
George is correct. You need an FAA bill of sale from every owner in the chain; One from ZAC, and one from every previous owner.
However, if you already bought a kit from ZAC, you can register the aircraft using the kit serial number and bill of sale provided by ZAC. Where individual parts come from are of little concern. This truly is just a paperwork drill - not for the weak hearted or time constrained...
Also, I noticed that someone has plans for sale on the list. When these plans change hands, make life easier for the purchaser, and fill out an FAA bill of sale for the plans. With those plans come a serial number for an aircraft. Regardless if any parts were sold, a bill of sale will be required to register the aircraft.
R/
Brandon
xl(at)prosody.org Guest
Posted: Wed Nov 29, 2006 11:01 pm Post subject: Buying a Partial Built Kit |
The form that you will use to verify that you did > 51% of the work is:
FAA FORM 8000-38, FABRICATION/ASSEMBLY OPERATION CHECKLIST
Go to www.faa.gov and search for 8000-38.
Even though I built from '51% kit' my DAR made me fill out the form
to 'verify' that I did >50% of the work.
Joe E
N633Z (at) BFI
CH601XL, 408 hours
Jabiru 3300, Sensenich 49x64 wood prop
On Wed, 29 Nov 2006 JAPhillipsGA(at)aol.com wrote:
| Quote: | ....snip
....snip
N505WP
601XL-3300
96 hours
JAPhillipsGA(at)AOL.COM Guest
Posted: Thu Nov 30, 2006 7:19 am Post subject: Buying a Partial Built Kit |
Joe, thanks for the info. I'll put that in the finish folder. Bill
