Deems Davis
Posted: Wed Nov 29, 2006 4:17 pm Post subject: Rudder question- ditto |
I haven't seen a response to John's question, I too would like to know
how other builders have set them up. when I installed my cable guides
they were very tight, how tight did you 'fly guys leave them?
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
John Hasbrouck wrote:
| Quote: | Question regarding rudder bearing blocks and the "nylon" rudder cable
guides. How snug should both of these be? I can tighten the center
rudder bearing block to the pont where the rudder pedals will not
move, obviously too tight. Same with the rudder cable guides. How
much play do we need in these? Are the aerodynamic forces on the
rudder enough to overcome the situation? Will there be enough wear in
to loosen the pedals and the cable? Inquiring minds want to know
John Hasbrouck
#40264
Tim(at)MyRV10.com Guest
Posted: Wed Nov 29, 2006 5:39 pm Post subject: Rudder question- ditto |
The cable guides for the rudder can be tight. You'll be moving
the pedals with your strong legs. You wouldn't want the pedals
loose and flopping around....it'll take a bit of a push to move
them. If you can tighten the center block to the point where you
can't move the pedals, my question is....how much force would
it take for you to move them...a lot, or a little? If you
honestly can't move them, even with huge force, yeah, they're
too tight. I can't imagine the hole being drilled right and
not having it be at least close. As for the aerodynamic forces,
there isn't much for force on a trailing rudder....until you
push it out into the wind, and at that point, there's lots of
force trying to re-center it. My guess is everything is just
fine, as long as everything is moveable in some way.
Deems Davis wrote:
Deems Davis # 406
> John Hasbrouck
> #40264
jhasbrouck(at)woh.rr.com Guest
Posted: Wed Nov 29, 2006 6:05 pm Post subject: Rudder question- ditto |
Tim,
Thanks for the reply!! Since I don't have seats installed I can't get
good read on how the rudders will feel when moved with my legs. Did you
torque the bolts for the center block to the values recomended for the AN3
bolt? If I do that I can't move the pedals with my hands but that doesn't
speak to how they'd feel with my legs. Trying to avoid having to go back
and adjust stuff later. It's much easier when it's all open......john
#40264
Posted: Wed Nov 29, 2006 6:25 pm Post subject: Rudder question- ditto |
That seems strange that you couldn't move them at ALL with your hands.
I mean, it'll take a shove on the bottom of the pedal, and then
suddenly they break free and swing, but you should at least
be able to move them. Is there a huge gap between the block halves
or something that is allowing it to be super tight, or is it
basically coming together right when you start to tighten the
bolts? I just can't imagine that part being able to be torqued
so that it pinches too tightly to be good...but I suppose it's
possible somehow. If you can't move them with your hands though,
with even a hard push on the bottom of the pedal, then I'd
say that is too tight. Maybe some silicone spray would help,
or at that point you may want to verify the parts are cut properly.
Tim,
get good read on how the rudders will feel when moved with my legs. Did
you torque the bolts for the center block to the values recomended for
the AN3 bolt? If I do that I can't move the pedals with my hands but
that doesn't speak to how they'd feel with my legs. Trying to avoid
having to go back and adjust stuff later. It's much easier when it's
all open......john
#40264
Posted: Wed Nov 29, 2006 7:30 pm Post subject: Rudder question- ditto |
Tim,
The block halves come together fine but the diameter of the opening has
been reduced by the width of the saw blade used to cut the block in half.
While we've been discussing back and forth I've been working the rudder
pedals and I think they are "wearing in". The movement seems to be freeing
up with use and as it does I've tightened the bolts a little more. My
biggest concern was that there would be sufficient aerodynamic force to
re-center the rudder and over come the friction in the system....john
#40264
jesse(at)itecusa.org Guest
Posted: Thu Nov 30, 2006 6:24 am Post subject: Rudder question- ditto |
Tight enough to put some drag, but not really tight. It helps to keep the
cables a little snug in their places if they hold on, but you certainly
don't want it so tight that you can't move it with your hand. I can't speak
to whether it will loosen with wear or not, but I wouldn't want to leave it
that way.
Just my take on it.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
