Mike Whisky
Posted: Thu Nov 30, 2006 4:57 am Post subject: I knew it is going to happen |
Hi there,
ok I screwed up riveting a 470 4-4 rivet and had to drill it out, the second attempt went wrong again and then drilling out made the 30# hole look like an 8.
What rivet do I have to use now and what core drill?
Michael (who is finishing the tailcone and expecting the wings next week)
_________________ RV-10 builder (flying)
#511 |
Tim(at)MyRV10.com Guest
Posted: Thu Nov 30, 2006 6:01 am Post subject: I knew it is going to happen |
You'd want to probably use a -5 sized rivet. I bought some long ones
and a rivet cutter. Never actually needed one though. If it's in
an area that isn't noticible, you could also probably just use a
#8 screw if the hole is as big as you say. Depends on what it is.
Michael Wellenzohn wrote:
Hi there,
RV-10 builder (tailcone)
#511
http://forums.matronics.com/viewtopic.php?p=78103#78103
jesse(at)itecusa.org Guest
Posted: Thu Nov 30, 2006 6:40 am Post subject: I knew it is going to happen |
One option would be to use a longer 4 rivet and let it swell to fill the
hole, but you would be better going bigger, or, like Tim said, putting a
screw in there. That all depends on where it is.
Better yet, leave the rivet out and use some Bondo to fill the hole.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
