cleone(at)rr1.net Guest
Posted: Sat Dec 02, 2006 1:12 pm Post subject: Questions?? |
Hi Bob, In the John Deere alternator and regulator frequently talked
about here is the rectifier in the regulator? And, Is the
alternator generating 3 phase AC ? And, about what voltage is the
output of the alternator. Also, since we know that the # 5 terminal
must be connected to voltage or the alternator doesn't work. I have
tried this and it is true. Then what is the circuit like? And would
it be a good place to connect the overvoltage crowbar to? Enjoyed
your lectures at Bloomington recently. Cleone
klehman(at)albedo.net Guest
Posted: Sat Dec 02, 2006 3:24 pm Post subject: Questions?? |
Cleones wrote:
Yes.
| Quote: | And, Is the alternator generating 3 phase AC ?
No. It is single phase AC. There are only two wires coming out of it.
| Quote: | And, about what voltage is the output of the alternator.
It will go up to about 200 volts open circuit but when loaded it will be
in the vicinity of 15 volts depending on how you measure it.
| Quote: | Also, since we know that the # 5 terminal must be connected to
voltage or the alternator doesn't work. I have tried this and it is
true. Then what is the circuit like? And would it be a good place to
connect the overvoltage crowbar to? Enjoyed your lectures at
I interupt the wires into the regulator. In the past Bob has said that
either into or out of the regulator will do the job but I wanted to be
able to cut power to the regulator in case it was overheating or
internally shorted. The regulator uses the battery connection to turn
itself on and to sense the battery voltage so that it can regulate to
14.4 volts nominal output.
Ken
Posted: Mon Dec 04, 2006 2:25 pm Post subject: Questions?? |
At 05:27 PM 12/2/2006, you wrote:
>talked about here is the rectifier in the regulator?
Yes.
will be in the vicinity of 15 volts depending on how you measure it.
> is true. Then what is the circuit like? And would it be a good
> place to connect the overvoltage crowbar to? Enjoyed your
that either into or out of the regulator will do the job but I
wanted to be able to cut power to the regulator in case it was
overheating or internally shorted.
| Quote: | The regulator uses the battery connection to turn itself on and to
sense the battery voltage so that it can regulate to 14.4 volts nominal output.
Ken
Ken,
| Quote: | Thanks. Let me consider this. So.. doesn't this indicate
using a NO relay? This circuit might be carring very high current
at the time the relay opened. Hopefully the contacts would not be
welded closed and the spinning alternator would not be delivering
current to the regulator and we would achieve the desired
results. I don't know if an attempt to fuse the AC output at a
little more than the rated current of the alternator is called for
or not. This might not be advisable because it might cause the
charging to be shut down unnecesarily. Do you agree with my
thoughts? Also regarding the # 5 connection of the regulator. I
started the engine and made sure the alternator was working with
the wire connected and then redid this with the wire off. The
first time the voltage was about 14 volts and the second time it
was just a little over 12. Thanks again.
Cleone
Posted: Wed Dec 06, 2006 6:34 am Post subject: Questions?? |
Cleones wrote:
> Yes.
>> to connect the overvoltage crowbar to? Enjoyed your lectures at
> that either into or out of the regulator will do the job but I wanted
> to be able to cut power to the regulator in case it was overheating
> nominal output.
> Ken
Ken,
> using a NO relay? This circuit might be carring very high current at
> current to the regulator and we would achieve the desired results. I
> don't know if an attempt to fuse the AC output at a little more than
> the rated current of the alternator is called for or not. This might
> not be advisable because it might cause the charging to be shut down
> unnecesarily. Do you agree with my thoughts? Also regarding the # 5
> connection of the regulator. I started the engine and made sure the
> alternator was working with the wire connected and then redid this
> with the wire off. The first time the voltage was about 14 volts and
> the second time it was just a little over 12. Thanks again.
Cleone
Cleone
Yes I use a NO relay. My alternator switch applies power to the
"Battery" connection on the regulator and to the OVM module and it
closes the NO relay. Your voltage readings are indeed what I would
expect to see.
Fusing the output of an alternator won't provide Over Voltage
protection. It is done to simply to protect the wire from battery
current if the alternator should short out. So in this case my fuse or
circuit breaker is between the battery and the regulator to protect the
wire from overheating because of battery supplied current if there is a
short in the regulator or the alternator. I think I had a 30 amp CB on
hand and used that.
I hope I'm not muddying this for you. My wires from the alternator to
the regulator are sized at 12 awg to handle the 20 amp max output so
they are not at risk from the alternator if the regulator shorts.
Putting the OV relay in those ac wires would provide a means of
disconnecting the supply to the regulator though which is what I did.
Ken
