		rleffler
				 Posted: Sat Dec 02, 2006 5:50 pm    Post subject: Band Saw |
				I see that many have band saws.   Can I get by with an inexpensive
 Ryobi/Rigid/Delta for $99?   These all seem to run 3000 rpm.
 Or do I really need a variable speed to drop things down to the 300-400 rpm
 range?
 Is the distance between the blade and the saw critical?  I'm not sure how
 long a typical piece being cut is and how long the stock it's being cut off
 is?
 I see quite a few people have a variable speed band saw from Harbor Freight.
 It appears that it has been discontinued by Harbor Freight.  What
 brand/model would you recommend?
  _________________ Bob Leffler
N410BL - Phase I
		millstees(at)ameritech.ne Guest
				 Posted: Sat Dec 02, 2006 5:57 pm    Post subject: Band Saw |
				Bob:
 I am using a $99 Delta, finishing the fuselage, and it has done everything I
 have needed.
 Steve Mills
 RV-10 40486 Slow-build
 Naperville, Illinois
 finishing fuselage
		Tim(at)MyRV10.com Guest
				 Posted: Sat Dec 02, 2006 7:11 pm    Post subject: Band Saw |
				I think you can get by with an inexpensive one OK for the most part.
 That said, it is actually nice to have variable speed, I used it
 a lot, and it is also very very nice to have a 12" or larger throat.
 I had times when I even couldn't cut a piece to length because 12"
 was too short, but I think it would have been a lot harder with 9".
 A 9" would absolutely be a worthy tool, but this is a case where
 larger is probably better if you have space and can find it affordable.
 I didn't start with a bandsaw initially, but it turned into one of
 my favorite tools in the shop, and now that it's at the hanger I'm
 thinking I need another one for the house.  Just bought a nice 10"
 drill press for the hanger tonight for $55 (demo model closeout),
 so I can bring my junky old crapsman home from the hanger.  Tools
 are addicting.
 Bob Leffler wrote:
  range?
  is?
		LarryRosen
				 Posted: Sun Dec 03, 2006 7:51 am    Post subject: Band Saw |
				Make sure you can get a metal cutting blade (one with many teeth) for
 the band saw you are considering.  I have the 12" variable speed Harbor
 Freight band saw.  As with most Harbor Freight tools you get good value
 but questionable quality, especially with electric tools.  When I first
 got my band saw, the variable speed controller did not work (this part
 was quickly replaced).  After a year of use one of the drive wheels
 cracked and it took over 6 months to get a replacement part.  As usual
 you get what you pay for.  If I were to do it again I am not sure what I
 would do.  You loose a lot of functionality by only having a 9" throat
 and no variable speed, but a 12" name brand would be at least 3x the
 harbor freight cost.
 Larry Rosen
 #356
 Tim Olson wrote:
  are addicting.
 > 300-400 rpm
 > range?
 > how
 > cut off
 > is?
 > Freight.
 > Thanks,
 > Bob
  _________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
		DAVELEIKAM(at)wi.rr.com Guest
				 Posted: Sun Dec 03, 2006 8:27 am    Post subject: Band Saw |
				I have found that a good old fine toothed carbide power miter saw works
 really well for many of the cuts.  Apply pressure slowly.  I also have a 12"
 sears band saw which I like.
 Dave Leikam
 40496
 tailcone
		Rick S.
				 Posted: Sun Dec 03, 2006 9:06 am    Post subject: Band Saw |
				My Delta has worked like a champ...get a 59-1/2" 18 TPI blade and follow the alignment directions and it will cut like budda, tip #1....let the saw do the work and it will hold a nice straight line, force it and you will fight it to keep it going straight.
 Rick S.
 40185
  _________________ Rick S.
RV-10
40185 |
		rleffler
				 Posted: Sun Dec 03, 2006 10:56 am    Post subject: Band Saw |
				Interesting.......
 I have a 12" power miter saw.   What the longest cut that I'll need to make?
 My saw can cut a 2x6 with no problems.  Are there any cuts that have to be
 longer than 6"?
N410BL - Phase I
				 Posted: Sun Dec 03, 2006 1:09 pm    Post subject: Band Saw |
				I am about to start riveting my tailcone, but I cannot think of  more than a
 few parts I had to cut much wider than a few inches.  The miter sure makes
 the angles easy.  You have to be very careful on the thin stock like the
 tailcone stiffeners.  Support the part well on each side of the cut and
 proceed slowly.  I had been using my bandsaw and noticed my miter sitting
 quietly when I thought, yeah - that would work good!  And so far it is.  If
 I can cut it on the miter I will, if not I use the band saw or whatever else
 will work.
 Dave Leikam
 40496
		jjessen
				 Posted: Sun Dec 03, 2006 4:04 pm    Post subject: Band Saw |
				I have a Delta.  9".  Works for 90% of the parts that you will need the saw
 for.  Otherwise, pick up a variable speed Dremel and use the cut off wheels
 to do the cutting.  I know of at least one RV-8 builder who bought and loved
 the Sears variable speed 12".  Whatever you choose, this becomes your metal
 saw.  No wood.  As a long time wood worker, take my advice and don't even
 think about combining your beautiful wood band saw for the metal work.  Get
 a cheap table top for your metal, buy a blade with lots of teeth and narrow,
 and move on.
 Did I say, "Move on!"  Oh, my goodness.  I'm becoming one of those......
 John Jessen
    #40328  (9 more days of Buildus Interruptus purgatory)
		patrick.pulis(at)seagas.c Guest
				 Posted: Sun Dec 03, 2006 5:02 pm    Post subject: Band Saw |
				I have a Ryobi band saw, however I engaged a local saw works to make up
 three specific blades, for cutting thin aluminium sheet, aluminium
 angle/stock and plywood.  The replacement blades are industrial quality
 and induction hardened and are far superior to the blades supplied by
 Ryobi.  I had them made for AUS$18 each and they thew in a 1kg block of
 solid lubricant wax to keep the blade lubricated and cool when cutting
 stock.  The baldes are interchangeable and cut through everything like a
 hot knife through butter.  Just contact your local saw works, you won't
 regret it.
 Patrick Pulis
 Adelaide, South Australia
 Build #40299 (Started on Wings)
 DO NOT ARCHIVE
		johngoodman
				 Posted: Sun Dec 03, 2006 6:30 pm    Post subject: Re: Band Saw |
				I'm getting ready to drill my tail cone so most of the multitude of parts I need to fabricate are done (for now). My Ryobi $99 from the Home Depot aviation department has worked well with the metal cutting blade they sell separately. I agree with the others that the 9" throat is a little confining, but snips, hacksaws, and dremels can fill the gap.
 It's not a great bandsaw but it gets the job done. Secretly I wish I had a good compound miter saw with a metal cutting blade.
 Best tool recommendation I've gotten from this site? The #30 and #40 reamer bits from Avery. Best bit I've ever used!
