jesse(at)itecusa.org Guest
Posted: Sun Dec 03, 2006 5:53 pm Post subject: Compare Engine Quoted Stats |
We should all just be in a chat room right now with all of these posts.
For the information and for the archives, can you give us some quoted stats on the Subie:
Engine Cost
Prop Cost
FWF Cost (I assume including Engine Mount that accepts the Van’s nose gear leg)
Expected TBO
Max HP w/ Turbo
Max HP if w/o Turbo
HP output (at) 10K
HP output (at) 18K
Dual Ignition?
Weight compared to IO-540 (including all Egg recommended upgrades – ie second battery?)
No of Prop Blades
Electric Prop?
Cowl Cost
Fuel Options
Here are the stats on the IO-540 new:
Engine Cost - $39,300 - $43,500ish
Prop Cost - $6,000 Hartzell ~$8,000 MT
FWF Cost (I assume including Engine Mount that accepts the Van’s nose gear leg) - $5,400 Push/Pull - $5,700? Quadrant
Expected TBO – 2,000 Hours
Max HP w/ Turbo – Normalized 260HP
Max HP if w/o Turbo – 260HP
HP output (at) 10K – Somebody smarter than me would have to calculate this
HP output (at) 18K – “
Dual Ignition - Yes
Weight compared to IO-540 – Roughly the same
No of Prop Blades – 2-3
Electric Prop - No
Cowl Cost - anybody that had theirs held know this?
Fuel Options – 100LL (maybe mogas with an O-540)
Please remove this do not archive tag on the reply.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
-- Date: 12/3/2006 4:36 PM
12/3/2006 4:36 PM
