Posted: Mon Dec 04, 2006 7:27 am Post subject: engine wars was Re: Eggenfellner |
Dave Leikam wrote:
snip
| Quote: | I fly my friends Archer 180 hp. The mechanics say the compression
is great and the engine is in tip top shape yet we are always adding
oil. This is normal?!?
usually
| Quote: | I always thought burning oil was a sign of a worn engine.
It is ..... at least worn cylinders/rings.
snip
| Quote: | I also don't understand why Lycoming hasn't come up with a cutting
edge engine design.
Because it's cost prohibitive to re-certify the engine and the
engine/plane combination. thank the FAA for that one!
| Quote: | Every auto maker seems to improve their engines one way or another
every year. 50 years for Lycoming and no major changes? Where are
there more internal combustion engines of similar horsepower to GA
aircraft than autos. My feeble opinion is that the best odds for an
alternative engine will be found in automotive engine technologies.
Go Egg.
Well, I have to agree that auto engines are definitely more state of the
art, but comparing the life of your car engine to your Lycosaur isn't
really fair. You don't treat them any where near the same, as was
alluded to in some posts. Your car doesn't sit idle for weeks (or
months) at a time and then get run a little bit. Most airplanes in
private ownership (non-flight school or other business related
operation) get treated that way. The accelerated cylinder wear that
causes high oil consumption is due to the rust that forms in the
cylinders when the plane sits for an extended period of time. If the
plane is flown regularly and about 100 to 150 hours a year, the lycosaur
will go to TBO without even getting a top!!! The secret is regular use
and care.
Linn
Dave Leikam
40496
tailcone
Muskego WI
