Posted: Mon Dec 04, 2006 10:32 am Post subject: access panels |
I have a QB fuse and I have been impressed with the quality of the
workmanship, but I have spent a lot of time trying to route conduit through
the fuselage sides. From the plans it looks like the two holes on each
bulkhead(four per side) were supposed to be drilled to 3/4" diameter. To me
it looks like they drilled it to size for the regular size snap bushings
that are used elsewhere(Like cable runs in the tunnel)
Hence, I have had a heck of a time doing this. I thought I was being clever
by uising a 4" CARBON FIBER pushrod used for models to help guide through
the holes. A little light was going off in my head after several(Ton) of
attempts of dragging this rod inside there. Carbon/aluminum, Pencil/
Aluminum???
Now that there is a big unknown about how much carbon residue i left on the
primed aluminum parts, I am thinking about making some access panel infront
and inback of these two bulkheads, which will allow me to clean the metal,
re prime or Beo lube. I addition, route everthing correctly.
I just can't figure away to unscrew the side panels and remove them as many
are riveted in and gaining access to re rivet would be like taking out major
assembles(MAJOR)
Any Ideas, has anyone else needed to put in access panels there. It seems
non structural as there are so few screws holding things in place.
Hope this is a relief from the engine wars.
John G.
Rick S.
Posted: Mon Dec 04, 2006 11:12 am Post subject: access panels |
John,
Isn't the carbon fiber wrapped around a rod then sealed with resin to make those rods? I wouldn't think you would get actual carbon scraping off, and pencils use graphite right? not carbon.
Just a thought...
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
AV8ORJWC
Posted: Mon Dec 04, 2006 12:20 pm Post subject: access panels |
Graphite cloth is Carbon Fiber cloth. They are interchangeably the
same. Their galvanic nobility with aluminum is anodic/cathodic.
Separating the two in construction is a valued step. In reality it is
not a serious issue. With titanium, stress cracks can develop when
exposed to heat. Hence we never use pencil marks in aviation
construction.
Larger lightening holes with a flared radius for reinforcement would
provide valuable wire routing - for those like me on the really slow
build schedule. You might have to drill out and modify with a re-rivet
at the end the quick-build panel.
Those who have gone before us have valuable perspective in such routing.
Rick come on, flyboys should know this. Naval aviators had to.
John Cox
40600
kearney(at)shaw.ca Guest
Posted: Mon Dec 04, 2006 12:23 pm Post subject: access panels |
Hi Rick
Graphite is elemental carbon so if a pencil left marks it may be a problem.
That is why we use sharpies when marking parts.
Cheers
Les
Posted: Mon Dec 04, 2006 1:01 pm Post subject: access panels |
Now that we all understand that graphite is carbon. What about the
reaction. I cannot get a rag in there to clean it off with any cleaner, I
can't barely get the carbon rod to find the holes. The carbon rod which is
now bevelled on the end will leave marks on a piece of paper, not as well as
a pencil but you can see it. I put tape over the end to stop this, but what
about what has already occured, just shoot in Boe lube and try for a few
more twenty minute sessions to get the rod and then the conduit to go
through the holes, or cut the access panels do a thorough cleaning, line up
the conduit, but for all other purposes, the panels will probably never be
used again.
[quote]From: Les Kearney <kearney(at)shaw.ca>
Subject: RE: access panels
Date: Mon, 04 Dec 2006 13:20:30 -0700
Hi Rick
Cheers
Les
Rick S.
AV8ORJWC
Posted: Mon Dec 04, 2006 1:47 pm Post subject: access panels |
When fishing wire runs on our air carrier birds, we use a simple brazing
rod with a limitless length of waxed electric tie string taped to the
end. Unlike an electrician's fish wire (available at the aviation
department of Home Depot) flat with a hook on the end for conduit. We
just go fishing with the straight rod.
When changing out flexible metal control cables such as the RV-10
rudder, We tie the terminated end to the string and fish the string by
pulling on the old cable. We tie a new replacement cable and then pull
the string back through fairleads, cables and pulley runs. We are often
pulling up to 45 feet on an aileron run. As yet no one has worn one out
to need the technique.
Another trick from HD's aviation department is their heaviest gage of
plastics weed wacker replacement line. It is great for determining wire
runs. It tends to bend at a similar radius to wire bundles. It's
flexible, it's cheap and easy to work with. Lancair used it to
determine their wire panels (4 x 8 sheets of plywood) to pre-wire
complete aircraft on the board in the avionics department. Randy DeBauw
(#40006)or the boys at Advanced might tell you the lengths needed for
the RV-10 from their doing his entire aircraft back in April of 2005.
During the FWF episode you can check wiring, cables and hose routing
with the stuff.
Electrolysis is not going to be a problem with the residue. Carbon just
like Hydrogen Embrittlement can change the molecular structure of sheet
metal. It becomes more brittle and cracks can ensue. Galvanic issues
are where two dissimilar materials such as Alclad and carbon fiber are
nested together in the presence of humidity. This is not a problem in
this application. Ask Van's Techline if you are concerned.
John Cox
AV8ORJWC
Posted: Mon Dec 04, 2006 2:04 pm Post subject: access panels |
Grease pencils okay but highly inaccurate. Anyone remember James McClow
and is color crayon sized cut lines?
Sharpies (which cleaned with alcohol) are great. Pencils either
physical or mechanical are VERBOTTEN. Not for layup, not for cut marks,
not nutten. All technical writing has to be in pen, so we have to
E.I.E. entries that we screw up. And I thought pilot logbooks were bad.
In sheet metal layup we use colors such as green, blue and red sharpie
for folds, shearlines and holes.
John Cox
owl40188(at)yahoo.com Guest
Posted: Mon Dec 04, 2006 2:15 pm Post subject: access panels |
Hi John,
I just put some access panels in the baggage floor. See my post on 11/14/06 , it has some pictures.
You probably need two more access panels in the passenger seat floors. This will give you access to both bays. I would create access panels in lieu of drilling out the panels as the access panels will be usefull for maintenance. I thnk the access panels should have been designed into the kit.
Niko
40188
LloydDR(at)wernerco.com Guest
Posted: Tue Dec 05, 2006 4:07 pm Post subject: access panels |
John where are you talking about that you need a rod to get to, are you
talking about the side panels under the door frames? You can call me
directly, if you want to and discuss this, because once I remove all the
panels on the QB there is not an area I can not get to other than under
the front footwells. I am having a hard time understanding where you are
trying to get to that you would have to cut access holes.
Dan
724-983-1221
Posted: Tue Dec 05, 2006 8:21 pm Post subject: access panels |
Daniel it is 8:15pm here so I'll call you tomorrow as it is probably late
east of here.
[quote]From: "Lloyd, Daniel R." <LloydDR(at)wernerco.com>
Date: Mon, 4 Dec 2006 20:55:27 -0500
Dan
724-983-1221
