rvreynolds(at)macs.net Guest
Posted: Mon Dec 04, 2006 12:10 pm Post subject: Airflow Performance Filter Maintnance |
We have installed the Airflow Performance filter per Section 37 -
Fuel System.
The instructions with the filter "suggest" it should be removed,
opened, and cleaned after the first 10 hours and then annually.
How easy is it remove the filter with panel and the CT-10 throttle
quadrant installed?????
Also, how easy is it to remove the seats??
Inquiring minds want to know.
Richard Reynolds
Rick S.
Posted: Mon Dec 04, 2006 1:42 pm Post subject: Airflow Performance Filter Maintnance |
Richard,
It's not easy WITHOUT the quadrant....Some posts a while back addressed this issue. I am using a fiberglass panel/console assembly and it ain't gonna be easy either. Others were considering relocating the fliter for just such a reason. I think the seats need to come out, then you can access the tunnel cover so there are a few more steps than most realize.
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
jesse(at)itecusa.org Guest
Posted: Mon Dec 04, 2006 6:46 pm Post subject: Airflow Performance Filter Maintnance |
The seats do come loose without much trouble, but to take them completely
out you need to remove the cover panel over the flap control tube by the
rear seats (or some have modified the seats to allow them to be removed with
that panel in place). Sliding the seat back past the normal stop, however,
will allow access to the screws. I like the idea of cutting the forward
tunnel cover back underneath the panel a little bit to allow access to that
area without removing as much of the rest of the interior, with nutplates
and a backing plate to tie them together.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
