Posted: Mon Dec 04, 2006 9:43 pm Post subject: Intercoms |
Next question,
I was looking at intercom units and would like to put in the wiring to the
headphone jacks and wanted to know if anyone has experience with any of the
three units. All I would like to have, not too complicated to us and
install and one that functions well and one that I can hook up to say an
Ipod and or satallite radio(Stereo function)
AVCOMM DX-AC6PA INTERCOM
PM3000 PANEL MOUNT STEREO INTERCOM
Sigtronics SPA-4S Stereo Intercom
Any body ever used any of these brands?
John G
jesse(at)itecusa.org Guest
Posted: Tue Dec 05, 2006 7:15 am Post subject: Intercoms |
Is there a reason that you are staying away from an audio panel like the
GMA-340 or the PMA6000, 7000, 8000? I think most of these offer stereo, and
they should all offer audio inputs. For the Garmin, you have crew and
passenger inputs and then you could have a switch that switched from your
MP3 or Satellite Radio source.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
noel(at)blueskyaviation.n Guest
Posted: Tue Dec 05, 2006 7:22 am Post subject: Intercoms |
I would recommend the pm3000
Noel Simmons
Blue Sky Aviation, Inc.
www.blueskyaviation.net
Ray.R.Doerr(at)sprint.com Guest
Posted: Tue Dec 05, 2006 7:44 am Post subject: Intercoms |
Then there is the GMA-347 from Garmin that has the digital voice recorder and many extra unswitched inputs for stuff like EFIS AOA alarms and Ebgine monitor alarms.
Thank You
Ray Doerr
N519RV (40250) Flying
Posted: Tue Dec 05, 2006 8:02 am Post subject: Intercoms |
Noel,
Are you Blue Sky Avaitoin in Camarillo?
How difficult is it to install?
I need my transponder in the glider certified this spring. Can you guys
still do it.
John G.
[quote]From: "Noel & Yoshie Simmons" <noel(at)blueskyaviation.net>
Subject: RE: Intercoms
Date: Tue, 5 Dec 2006 08:21:55 -0700
Noel Simmons
Posted: Tue Dec 05, 2006 8:07 am Post subject: Intercoms |
Believe I am staying away form the conventional stacked deck, putting in
smaller stuff like in the glider, Becker. VFR only. No cash, need to build
a small cabin after this in Colorado, hence the need for the plane. Call me
rebel!
Not planning on selling this bird and want most of my systems the same for
ease of use so that my aging memory does not remind me each time I switch
between planes. Currently 40 years old.
JOhn G,
[quote]From: "Jesse Saint" <jesse(at)itecusa.org>
Date: Tue, 5 Dec 2006 10:14:10 -0500
and
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
Posted: Tue Dec 05, 2006 8:21 am Post subject: Intercoms |
Large temperature differential I am afraid, we are in Lewistown Montana. We
just specialize in RV's, I tend to stay away from certified, don't like the
way they are constructed :>0, gliders are a different story love them
certified or not.
If you are talking about the pm300 it is quite easy. Simply use shielded
wire from your jacks to the panel, the wiring diagrams are downloadable from
PS engineering's www.
There are a few people on the list that are trying to keep you from making a
mistake. If you are using multiple coms and multiple Navs you should go
with an audio panel.
Noel
billderou(at)yahoo.com Guest
Posted: Tue Dec 05, 2006 8:46 am Post subject: Intercoms |
I started flying with the PS1000 intercom and no audio panel to simply "get flying" and use a portable for my backup. Apparently there is noise running around the cabin that emits from the windows and the air from the vents rushing around the mic. An intercom that has fewer squelch circuits than headsets gangs multiple headset mics into one squelch circuit.
For example, the PS1000 has two squelch circuits. When the co-pilot breaks squelch it opens the mics at both passenger seats. Thus the mic nearest the noise (of the set of 3) will break squelch. It means that the squelch must be turned up high and normal talking becomes stuttered. Once squelch is broken there is a noticable hiss in the background heard as people are talking. The PS3000 has three squelch circuits which gang both passengers into one circuit.
My next step will be the Garmin 347. It has a squelch circuit for each headset and filtering to reduce the background hiss once squelch is broken. It also has lots of input choices. The several unswitch inputs can be used to route the devices that wish to talk to us. Such as, VOR ID and weather, TIS traffic, and engine monitor.
Bill DeRouchey
billderou(at)yahoo.com (billderou(at)yahoo.com)
Flying with 58 hours
"Doerr, Ray R [NTK]" <Ray.R.Doerr(at)sprint.com> wrote:
[quote]--> RV10-List message posted by: "Doerr, Ray R [NTK]"
Thank You
Ray Doerr
pcasson(at)sasktel.net Guest
Posted: Tue Dec 05, 2006 2:56 pm Post subject: Intercoms |
I've installed a Sigtronics SPA-4S Stereo Intercom. My only complaint is it does not have enough
audio inputs if you have things like warning tones from your EIS or AOA system to integrate. Not
hard to wire up a summing amplifier in front of an existing input to combine audio inputs but still
something you would not need to do on a more capable unit.
Perry Casson
Next question,
John G
