Posted: Wed Dec 06, 2006 12:31 pm Post subject: The difference in Teflon wire? |
Tim,
I noticed form your web site that you recommend Wire Masters.
Do you know the difference between the two types of Teflon wire:
Teflon 22759-PTFE
(Polytetrafloroethylene)
Teflon 16878 -PTFE
The numbers mean nothing to me.
John G.
rvbuilder(at)sausen.net Guest
Posted: Wed Dec 06, 2006 1:11 pm Post subject: The difference in Teflon wire? |
Teflon can be difficult to work with. Harder to strip primarily.
Michael
Tim(at)MyRV10.com Guest
Posted: Wed Dec 06, 2006 1:31 pm Post subject: The difference in Teflon wire? |
They were just a good supplier for me.
I don't know the differences off hand, as I only really read
up on the 22759...but it's the 22759 that you want.
John Gonzalez wrote:
Quote: |
Tim,
Teflon 22759-PTFE
Teflon 16878 -PTFE
John G.
Posted: Wed Dec 06, 2006 1:35 pm Post subject: The difference in Teflon wire? |
A little slippery is it.
Okay, so which tefzel wire is needed or what is the difference in these.
Tefzel-ETFE
(Ethylene Tetrafluoroethylene)
Cross-Linked Tefzel-XL-ETFE
John G.
[quote]From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Subject: RE: The difference in Teflon wire?
Date: Wed, 6 Dec 2006 15:09:48 -0600
Michael
Posted: Wed Dec 06, 2006 2:39 pm Post subject: The difference in Teflon wire? |
To help strip teflon (or any other slippery insulation) once the
insulation is cut, use a large alligator boot to grip the insulation so
you can pull it off. Or get one of the nifty automatic strippers
that'll cut an pul;l off the insulation all in one lick.
Linn
Michael
stein(at)steinair.com Guest
Posted: Wed Dec 06, 2006 3:57 pm Post subject: The difference in Teflon wire? |
You don't want any "PTFE" wire...only "ETFE"...which is Tefzel
(crosslinked).
The "22759" number on it's own is almost worthlesss, because there is both
teflon and tefzel in that mil spec. The important number is the "slant" or
"/" numer, in this case /16...so you want to get M22759/16-xx-xx (x=the wire
size, and y=color). There are a LOT of other slant number out there, but
some are silver plating, different stranding, different conductors, etc..
Also, the 16878 number is also a good one depending on the slant
number...you can just use that main first Mil Spec number as your guide.
I'll say it again...save yourself some time and just buy it from someone who
already has done the research ----hint, hint, hint! Also, just for an FYI
or records, the mil spec for the shielded cable is M27500-TE(or
TG)2T22-xxxxxxxx which is a bunch of other gobblteygook that tells you
sizing, stranding, color, inner jacket size & type, etc...
OK, enough stumping. Teflon has several less desirable properties over
Tefzel. Michael Sausen eluded to the stripping, and that it's a lot more
slippery. I also has poor cold flow characteristics, which means in large
bundles it can and will slowly flow around things like zip ties, etc...
Anyway, go with tefzel that is the correct mil spec and you'll be fine.
Cheers,
Stein.
[quote]--
N777TY
Joined: 09 Apr 2006 Posts: 69 Location: Charlotte, NC
Posted: Wed Dec 06, 2006 4:28 pm Post subject: Re: The difference in Teflon wire? |
Why not just order from Stein and not worry about these numbers? He's got the stuff that you need/want... it'll be painless buying from him.
_________________ RV-7A
N777TY |
Rick S.
Posted: Wed Dec 06, 2006 9:44 pm Post subject: The difference in Teflon wire? |
Thank you for your time.
I have your number too, and I planned on contacting you for several items
and this may be another.
JOhn G.
[quote]From: "SteinAir, Inc." <stein(at)steinair.com>
Date: Wed, 6 Dec 2006 16:53:57 -0600
(crosslinked).
wire
who
Cheers,
Stein.
Posted: Thu Dec 07, 2006 5:48 pm Post subject: The difference in Teflon wire? |
Linn
Michael
