Lynn Matteson
Posted: Wed Dec 06, 2006 6:45 pm Post subject: Skis for Kitfox's |
I'd like to get peoples opinions on skis for a Model IV. I know Skystar
offered them, but not (I don't think) in the wheel-penetration type
that I am interested in. We don't get enough snow around here (Lower
Michigan) to warrant full skis...that is, non-penetration skis. But if
we get our normal amount, my strip will be snowed over, while most of
the paved strips will be cleared of snow, and I wouldn't be able to go
there....well, you get the idea. I'd like to hear some dialogue about
what is involved in flying with skis, problems encountered, etc. I am
thinking of building my own skis of the wheel-penetration type, or
perhaps buying if a pair is available. I need a project, so building is
preferred.
Lynn
Kitfox IV Speedster...Jabiru 2200
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
smokey_bear_40220(at)yaho Guest
Posted: Wed Dec 06, 2006 10:09 pm Post subject: Skis for Kitfox's |
Michel, are you here?
Lynn, Michel built some that he uses in Norway. Looks
like they work well for him too. Oh, and he has a
Jabber engine too.
Kurt S.
--- Lynn Matteson <lynnmatt(at)jps.net> wrote:
| Quote: | I'd like to get peoples opinions on skis for a Model
IV. I know Skystar
around here (Lower
over, while most of
some dialogue about
preferred.
Lynn
Fox5flyer Guest
Posted: Thu Dec 07, 2006 4:44 am Post subject: Skis for Kitfox's |
Lynn, you might consider just not using skis, but instead, put on bigger
balloon tires. They'll ride over some pretty deep snow with no problem.
It's a lot simpler. Now if you had the snow down there that we have up here
it would be a different story.
Deke
Lynn Matteson
Posted: Thu Dec 07, 2006 5:57 am Post subject: Skis for Kitfox's |
Thanks, Kurt...yes I'm in touch with Michel. I have his drawing, and
some nice pictures of his installation. I also got some picture off
Sportflight.com, which were helpful. Now I just have to decide whether
or not to do it, and how much bother they are in use. I've been getting
some input from local fliers, including my flight instructor, and some
of the stories they tell is making me have second thoughts about "going
skiing." Things like running across snowmobile tracks, hidden
obstructions, etc. I know that if I stay on known grass strips, or
paved runways, I *should* be ok, but I've seen these snowmobile guys
tear up all over the place, leaving their ruts in their wake. I'm
trying to get some input as to the feasibility of the whole
matter....I'd hate to go two or three months without flying.
Lynn
On Thursday, December 7, 2006, at 01:09 AM, kurt schrader wrote:
<smokey_bear_40220(at)yahoo.com>
Jabber engine too.
Kurt S.
> IV. I know Skystar
> around here (Lower
> over, while most of
> some dialogue about
> preferred.
> Lynn
N369LM |
Lynn Matteson
Posted: Thu Dec 07, 2006 6:27 am Post subject: Skis for Kitfox's |
That's certainly good advice, Deke, but what if I decided to come up
your way? I've actually got the 20x6.50x8's that came with my kit, so
maybe that's an option. Do you suppose that size would work?
That option would not fulfill my need for a project, though...hmmm. : )
Lynn
bigger
problem.
up here
Deke
N369LM |
Richard Rabbers
Joined: 09 Jan 2006 Posts: 114 Location: Benton Harbor, MI - USA
Fox5flyer Guest
Posted: Thu Dec 07, 2006 7:47 am Post subject: Skis for Kitfox's |
Lynn, I ran my model 2 for a couple winters on the same tires (20s) that you
have and for up to six inches it was no problem. Heavy wet stuff may be a
bit different. If you decide to come up here and the snow is deep I'll plow
it for you! Actually, the skis are nice. The last two years I had my 2 I
ran it on skis that I made for it and I could go just about anywhere with
them, including paved runways. Up here, most airstrips have a place for
landing on skis, usually paralleling the active so there are lots of options
on skis, including the frozen lakes. Another thing about skis is that the
airplane tends to track straighter with less rudder input, and on a 2,
that's a big deal. Skis do make it a pain moving in and out of the hangar,
but there are ways around that. If just plan on hanging around "down south"
the fat tires will probably work for the most part. A good rule is to
always drag the landing area first to look for anything that may cause your
day to go bad.
Unfortunately, I let the skis go with the airplane when I sold it and now
the airplane is down in Mexico somewhere. I don't know what happened to the
skis. Should have kept 'em. They were one of my best productions.
Deke
Mikado Michigan
Subject: Re: Skis for Kitfox's
Lynn
> bigger
> problem.
> up here
> Deke
Float Flyr
Posted: Thu Dec 07, 2006 9:40 am Post subject: Skis for Kitfox's |
Stay on good solid ice ( preferably get a ground report ) or give snow a few
days to settle then you shouldn't have a problem with snowmobile tracks.
Timber jack tracks are another thing! They can be two or three feet deep
even in settled snow.
A number of years ago a small bush firm had to transport the body of a
deceased fellow along with supplies to a remote island outport in the
winter. The plane they were using, a DHC Beaver or Norseman, was pretty
well loaded so they had to tie the casket crossways through the two open
doors in the back of the plane and fly the short hop that way.
The pilot got in touch with some one in the community by radio well before
the flight and told him which frozen bog he would landing on. He requested
that they put a line of marker evergreen saplings down where he was supposed
to land so he wouldn't end up in a drift or bog hole. The guys in that
community being excellent woodsmen had for many years marked weak ice and
holes with saplings. The orders got mixed up and the boys put the saplings
on just about every obstruction around, including the straight ridge of a
particularly long large drift.
You got it the plane landed on or more correctly in the drift... Spun like a
top... The Skipper and his box went flying again and landed feet first into
a big rock, where it broke open spewing the dearly departed into or onto the
frozen mire.. All this happened right in front of the bereaved family who
could only pick up the skipper and stuff him into what was left of his box
and bury him.
The moral of the story: When flying skis make sure the report from the
ground is accurate.
Please : Do not archive this post It is intended only to promote safety in
Kitfox flying.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Michel
Posted: Thu Dec 07, 2006 10:09 am Post subject: Skis for Kitfox's |
On Dec 7, 2006, at 2:50 PM, Lynn Matteson wrote:
| Quote: | some of the stories they tell is making me have second thoughts about
"going skiing."
I still haven't landed on skis on unprepared terrain, Lynn. That is, if
you don't count the snow covered shoulders of my homeplace asphalt
runway, just for practice. Lots of stuff can hide under the snow. But
we have winter fly-ins where we land on frozen lakes there where there
is already people on the ground and we know it's safe.
Deke has a point that big balloon tyres will get you on much snow
covered surface. But snow, if a bit loose, can be tricky as it's an
enormous drag on the tyres/skis. That makes the plane feel like tipping
over when landing. The nice thing with the skis, then, is that it has
retaining wires that allow the plane to tip not more than 5 degrees
nose down, from level.
Michel
Lynn Matteson
Posted: Thu Dec 07, 2006 11:44 am Post subject: Skis for Kitfox's |
I may try the big tires first, before committing to the skis....thanks,
Michel.
Lynn
On Thursday, December 7, 2006, at 01:08 PM, Michel Verheughe wrote:
> "going skiing."
if you don't count the snow covered shoulders of my homeplace asphalt
tipping over when landing. The nice thing with the skis, then, is that
it has retaining wires that allow the plane to tip not more than 5
degrees nose down, from level.
Michel
N369LM |
Lynn Matteson
Posted: Thu Dec 07, 2006 12:01 pm Post subject: Skis for Kitfox's |
Deke-
I'll let you know if/when to fire up the plow. : ) Thanks for the
offer. Gotta fine-tune the cabin heater, and maybe try the larger
tires, then try some tests around here first. The hangar-moving is the
reason that I'd rather go with either large tires or the wheel skis.
And recall that my hangar is a dirt floor, so a dolly for moving the
plane is probably out of the question.
Lynn
On Thursday, December 7, 2006, at 10:47 AM, Fox5flyer wrote:
that you
be a
I'll plow
2 I
with
for
options
the
hangar,
south"
your
day to go bad.
now
to the
Deke
Mikado Michigan
> Lynn
>> bigger
>> problem.
>> up here
>> Deke
N369LM |
av8rps(at)tznet.com Guest
Posted: Fri Dec 08, 2006 8:18 am Post subject: Skis for Kitfox's |
Lynn,
I've put almost 300 flying hours on a couple different sets of Avid's wheel
penetration skis and have to say ski flying is a blast, so don't shortchange
yourself by not doing it. And the wheel penetration ski works great. I
would never want to go back to a straight ski.
I sent you a short video showing the wheel penetration skis in operation on
my early Avid Flyer in a separate e-mail. Or for anyone else wanting to see
it just click onto the kitfox lazair videos at
http://www.lazair.com/kitfox/movies/ and choose the video titled
avicAskis.mpg. (or if you want to go direct, just click on
http://www.lazair.com/kitfox/movies/avicAskis.mpg, but then you'll miss all
the other great videos on that site).
Ski flying with wheel skis can only be compared to having a seaplane with
amphibious capability - the options of taking off at the airport and then
landing in snow (or water in the case of the seaplane) provides one with
significantly enhanced experiences. Knowing you can now go pretty much
anywhere you want is a real rush. It opens up so many opportunites to visit
places that were previously off limits to you. And from a safety
perspective, it significantly increases your places to land in the case of
an emergency. The fact that you won't have the hassle of dollying your
aircraft from the hangar to a snow runway, or that you won't have to worry
about either too much or too little snow (knowing you can always operate off
the asphalt) makes the wheel ski a pretty good thing to have for winter
flying enjoyment. You will also find snow operations easier than pavement,
as the aircraft tracks straighter with the skis, and runway lengths or
direction are generally less limited. When you do a good snow landing it is
much like flying floats, you won't even know you are on the surface until
you either hit a small bump or see a spray coming off the undercarriage.
I'm not sure that flying can get any better than that...
The downside? Well, there are definitely some issues with ski flying. I
personally believe ski flying has a tremendous possibility of messing up
your airplane. Remember, most aircraft get wrecked off airport. And in the
case of skis, because you can go pretty much anywhere, you tend to do so.
And to make matters worse, the place you are going to land on is most likely
covered with a nice smooth layer of snow. It will probably look gorgeous
from the air. Smooth and bump free. But hidden underneath all that smooth
snow can be boulders, ridges, fence wire, ice chunks, etc, etc. Adding
insult to injury is the fact that you can't see very well as you are truly
experiencing the effect of being snow blinded. Flying low over a snow
covered area before you land looking for obstructions is always advised, but
many times won't really show you anything except a lot of white. Snow
drifts, ridges, and shallow drop offs are hazards that are some of the
hardest to see, many times being impossible to distinguish from the flat
areas. The 7,000 acre lake I live on here in Wisconsin makes for a great
winter runway (that's where the video was shot). But because we have a lot
of snowmobilers making ruts, and ice fisherman drilling holes (with nice
hard elevated rings of ice around the opening) all over the place, you have
to be careful. I'll admit to hitting many an ice fishing holes, and landing
cross ways on hardened and rough snowmobile trails, in my hours of ski
flying. That isn't exactly the fun part I described earlier. It will make
you wonder how much of that abuse your skis and/or your plane will handle
before breaking something. But if you are careful, and get those days when
you are the only one out in the fresh powder, it will make all other winter
snow related activities boring by comparison.
Here's a cute little wheel ski story I have to tell; One year I was lazier
than usual and left my wheel penetration skis on my Avid until mid July. I
thought it was kind of funny to do it, and what the heck, the airplane
operated just the same. But I decided that I had one last thing to do
before removing them..... So I loaded up my sheepskin lined leather winter
parka, along with my heaviest mittens and fur hat. Then I flew the little
Avid to a small airport I had never been to before. Once there I pulled up
at the fuel pump to top off my fuel (all of about 4 gallons as I recall).
When the line boy came out he was totally confused by seeing skis on my
plane. He asked where I had come from? I told him the mountains north of
the Yukon territories. Trying to keep from laughing, I told him I was glad
all the snow and ice had finally melted off the plane, and then went on and
on about how nice the weather was here in Wisconsin. Intrigued, he started
asking a lot of questions about range, speed, carrying capacity, etc of my
little white Avid Flyer. Then he wanted to know how it is that I could sit
that long in that small cabin? Somehow or other I muttered out answers
without laughing. Finally we went into the FBO so I could pay for the fuel,
and the next thing I know he has all of his coworkers coming out to see
"this neat little plane that flew here from somewhere near the north pole!".
Trying to avoid a lot of embarassment, or possibly being strung up by the
line boy, I told them all the truth, and then apologized for stringing them
along. They were a great bunch as they all got a good laugh from it.
Flying home that day I knew it would be a day I'd remember for a long time.
So there's proof wheel penetration skis aren't just for winter anymore<GRIN>
If you live where there's snow, go out and enjoy some ski flying. You'll
never regret it. If you don't get any snow, well you might want to consider
moving where there is...
Paul Seehafer
Central Wisconsin
ps - attached is a picture of my early Avid on wheel skis with the large
skinny tires. My later Avid uses the standard Avid/Kitfox type tundra tire.
Both tires worked well, with the advantage going to the narrow and tall tire
due to providing more ski area when in deep snow.
160.57 KB |
367 Time(s) |
Lynn Matteson
Posted: Fri Dec 08, 2006 9:19 am Post subject: Skis for Kitfox's |
Ok, that was enough to convince me...I'm building a set of skis...wheel
skis...for my fox. I just watched Paul's avicAskis.mpg video, and I'm a
believer. I probably won't get airborne as quick as Paul, given my
Jabiru engine and cruise prop, but I'll get up there eventually. : )
Lynn
On Friday, December 8, 2006, at 11:16 AM, Paul Seehafer wrote:
| Quote: | Lynn,
wheel penetration skis and have to say ski flying is a blast, so don't
shortchange yourself by not doing it. And the wheel penetration ski
works great. I would never want to go back to a straight ski.
operation on my early Avid Flyer in a separate e-mail. Or for anyone
else wanting to see it just click onto the kitfox lazair videos at
miss all the other great videos on that site).
N369LM |
