wayne.e(at)grandecom.net Guest
Posted: Thu Dec 07, 2006 4:59 am Post subject: Installing fairings |
You could fit the nose gear fairing without the engine, it might even be a little easier, but it's really not a big deal with the engine on. You have to have the engine in place and the prop on or at least a prop plate in place to be able to properly fit the cowling. Definitely much easier to the install main gear fairings without having to crawl under the wing.
Wayne Edgerton # 40336
pluggin away - someday :>}
How are you going to fit the nose gear fairings without the cowl in place?
How do you fit the cowl without the engine in place. Main gear pants and
fairings probably should be fitted without the wings for easy access.
