Lycoming IO-540 Maintenance Manuals
john(at)roadmapscoaching.
PostPosted: Sun Dec 10, 2006 6:53 pm    Post subject: Lycoming IO-540 Maintenance Manuals Reply with quote
For those of you flying with the IO-540 D4A5, what engine manuals to you recommend buying. I understand there is a parts manual and an overhaul manual. I don't plan to be overhauling (have a new Aerosport engine) but do want a reference for general maintenance, torque values, etc. What is the best source for these? Lycoming direct?
John Testement
jwt(at)roadmapscoaching.com (jwt(at)roadmapscoaching.com)
40321
Richmond, VA
Finish kit - engine, cowl
12/9/2006
Tim(at)MyRV10.com
PostPosted: Sun Dec 10, 2006 7:06 pm    Post subject: Lycoming IO-540 Maintenance Manuals Reply with quote
Operations, Overhaul, Parts. All can be valuable to have.
Some can be ordered as reprints from ACS for cheaper.
Some can be found on Ebay.
John Testement
jwt(at)roadmapscoaching.com <mailto:jwt(at)roadmapscoaching.com>
40321
Richmond, VA
12/9/2006
Kellym
PostPosted: Sun Dec 10, 2006 7:21 pm    Post subject: Lycoming IO-540 Maintenance Manuals Reply with quote
Manual reprints available from Essco.
May be a few years old, but good enough for reference.
> John Testement
> 40321
> Richmond, VA
> 12/9/2006
Kelly McMullen
KCHD
Deems Davis
PostPosted: Mon Dec 11, 2006 11:30 am    Post subject: Lycoming IO-540 Maintenance Manuals Reply with quote
John,
Here's a suggestion I received in answer to the same question.
Operatorís Manual, Lycoming Revision 60297-10-5 (If you order a new
engine this should come with it.
The Lycoming Engine Parts Manual is PC-215-1 dated June 1993.
A complete set of Service Bulletins, Instructions, and Letters is BS-147.
The Lycoming Trouble-Shooting Manual is SSP-475.
Lycoming Special Tools Catalog is SSP-384.
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
LarryRosen
PostPosted: Mon Dec 11, 2006 12:49 pm    Post subject: Lycoming IO-540 Maintenance Manuals Reply with quote
How much of these manuals, if any, comes with an engine from BPE?
Larry Rosen
#356
Deems Davis wrote:
John,
The Lycoming Trouble-Shooting Manual is SSP-475. Lycoming Special
Deems Davis # 406
Larry Rosen
#40356
N205EN (reserved)
<http>
Rhonda(at)bpaengines.com
PostPosted: Mon Dec 11, 2006 1:33 pm    Post subject: Lycoming IO-540 Maintenance Manuals Reply with quote
Larry:
Lycoming doesn't ship the experimental kit engines with an operator's
manual. Not sure why, although we have discussed it several times with
them. However, I'm happy to supply you with one.
Best,
Rhonda
