a.s.elliott(at)cox.net Guest
Posted: Mon Dec 11, 2006 9:02 am Post subject: Landing/taxi light requirements for 601XL? |
Folks:
I am a new builder (601XL/TD/QBK/Corvair, kit delivery this week!) and would like to get some feedback on landing and taxi light requirements.
I tend to do a lot of night flying, but am not planning on installing the standard 2 x 4509 leading edge kit from Zenith, mainly because of the high power drain and low light/power ratio. Also, I don't really like the installation.
I am thinking either 55W automotive driving lights (~ same light as 4509's - very low cost) or 35W HID driving lights (~about 2-3 times the light of 4509's, much higher cost). I have never owned an airplane that has such low landing speeds and am not really sure how much light is needed.
I am also not decided yet where to install the lights - under fuselage, attached to gear legs or in the leading edge.
Anyway, any experience or opinions from other 601XL flyers would be appreciated. Here is a link to the info about the Xenarc X1010 HID lights: (Note that you can remove the fog filter in these lamps to get full driving light power.)
www.suvlights.com
Andy Elliott, Mesa, AZ
N601GE (601XL/TD, Corvair, building...)
Gig Giacona
Posted: Mon Dec 11, 2006 9:11 am Post subject: Re: Landing/taxi light requirements for 601XL? |
I don't think you'll have any problem with using the auto lights though I'd be interested in knowing what you don't like about the leading edge installation.
Putting them any where else is going to add drag without a whole bunch of fairing. And adding them to the gear would put the wires having to run out like the brake lines and I hate the brake lines.
601XL Under Construction
Afterfxllc(at)aol.com Guest
Posted: Mon Dec 11, 2006 9:24 am Post subject: Landing/taxi light requirements for 601XL? |
A good alternative is to use the van's rv landing lights set up .... they use off the shelf lights from autozone and they work great.
Jeff
billbutlergps(at)aim.com Guest
Posted: Mon Dec 11, 2006 9:25 am Post subject: Landing/taxi light requirements for 601XL? |
Are you planning to fly under "light sport" license?
Posted: Mon Dec 11, 2006 9:30 am Post subject: Landing/taxi light requirements for 601XL? |
That was not part of his question. I'm sure he knows he can't night fly under light sport but he may want to drive around on the ground a few hours after dark though huh?
In a message dated 12/11/2006 12:26:33 PM Eastern Standard Time, billbutlergps(at)aim.com writes:
| Quote: | Are you planning to fly under "light sport" license?
bryanmmartin
Posted: Mon Dec 11, 2006 9:38 am Post subject: Landing/taxi light requirements for 601XL? |
I installed off-road hid lights in my wing-tips. These give a narrow beam that really reaches out a long way. I would have preferred to have one of these and the other a wider beam light for better side visibility for taxiing but they come in pairs and I wasn't about to buy two sets. The X1010 lights you mentioned might be better as a taxi light than a landing light because of the wide beam. If you had someone else to go in with, you might consider buying a set of X1010s and another set of off-road lights and split them up so each of you could install one as a landing light and the other as a taxi light.
My lights have worked out pretty well for both purposes since they have to be angled downward to view the runway on final approach they hit the taxi-way about 20 yards ahead of the plane while on the ground and the back scatter does a decent job of lighting up the area.
On Dec 11, 2006, at 11:58 AM, Dr. Andrew Elliott wrote:
| Quote: | I am a new builder (601XL/TD/QBK/Corvair, kit delivery this week!) and would like to get some feedback on landing and taxi light requirements.
www.suvlights.com
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
_________________ --
Bryan Martin
do not archive. |
Gig Giacona
Posted: Mon Dec 11, 2006 9:43 am Post subject: Re: Landing/taxi light requirements for 601XL? |
He also never says ANYTHING about flying as LSA.
[quote="Afterfxllc(at)aol.com"]That was not part of his question. I'm sure he knows he can't night fly under light sport but he may want to drive around on the ground a few hours after dark though huh?
tya2(at)4-fly.net Guest
Posted: Mon Dec 11, 2006 10:04 am Post subject: Landing/taxi light requirements for 601XL? |
Dear Andy Elliot,
Are you the guy from the grumman gang? Maybe the real reason for not installing GE4509s is the high price, low life span when installed in cowling. The key thing about lights whether aircraft or automotive is what do they illuminate and where are they located and how can you adjust them to see what you need... Landing lights may be a see and be seen item for the tower, or other aircraft in low viz, they may illuminate other obstacles on the ground when taxiing, and they may show you critters or debris on the runway or taxiway in the dark. If you can't adjust the pattern of illumination, it doesn't matter what you install they are more show than go...
Reg
ex AA-1, AA-5, BD-4 and whole bunch of other planes, currently own 1995 Zenith CH2000 with dual 4509s in the left wing.
At 09:58 AM 12/11/2006 -0700, you wrote:
[quote]Folks:
www.suvlights.com
ron.butterfield(at)gmail. Guest
Posted: Mon Dec 11, 2006 12:35 pm Post subject: Landing/taxi light requirements for 601XL? |
On 12/11/06, Dr. Andrew Elliott <a.s.elliott(at)cox.net> wrote:
If your only objection to the 4509 was the power drain, I would
recommend the 50W H7604 instead.
| Quote: | I am thinking either 55W automotive driving lights (~ same light as 4509's -
very low cost)
I personally would be very skeptical of this claim; I tried a pair of
(admittedly cheap) driving lights on my motorcycle and could still see
my shadow from my buddy's stock halogen headlight.
Automotive lights generally put out a spread-out beam, quite unlike
the very bright spot of an aircraft landing light bulb.
RonB
Trainnut01(at)aol.com Guest
Posted: Mon Dec 11, 2006 1:30 pm Post subject: Landing/taxi light requirements for 601XL? |
Andy
T will be flying my 601 as an LSA. I will be installing a 55w automotive "Taxi" light in the wing. Not because I intend to fly or even taxi at night but because many times in my almost 40 years of flying (next March) I have had tower operators at smaller tower controlled airports as me to "show a light" It would embarrass me to tell them that I don't have any lights.
Carroll Jernigan
XL Corvair working on the wings (still)
amyvega2005(at)earthlink. Guest
Posted: Mon Dec 11, 2006 4:06 pm Post subject: Landing/taxi light requirements for 601XL? |
Trainnut,
the plus side is LSA allows for one hour after sunset. Cannot hurt resell value either.
Juan
agustafson(at)chartermi.n Guest
Posted: Tue Dec 12, 2006 6:22 am Post subject: Landing/taxi light requirements for 601XL? |
| Quote: | >> LSA allows for one hour after sunset.
Respectful Clarification: Sport Pilot rule states flying is legal during
"civil twilight" which is technically "when the sun is les than 10° below
the horizon". This amounts to about 25 minutes in my location.
Your location may vary as might the seasonal differences.
A Private Pilot, with night flying endorsement, may fly a LSA (Light Sport
Aircraft) at night provided that aircraft is properly equipped.
Aaron Gustafson
Gig Giacona
Posted: Tue Dec 12, 2006 6:45 am Post subject: Re: Landing/taxi light requirements for 601XL? |
Since we are talking about US FARs here I'd like add that there is no "Night Flying Endorsement" for private pilots
A private pilot operating as a private pilot may fly any aircraft that he is legal to fly during the day at night as well as long as it is properly equipped.
A private pilot operating as a LSA pilot (using drivers license as medical) may not operate and LSA aircraft at night.
Here is a great FAQ for rated pilots and operating as a LSA pilot.
http://www.sportpilot.org/questions/afmfaqs.asp?topicid=8
| agustafson(at)chartermi.n wrote: | Respectful Clarification: Sport Pilot rule states flying is legal during
Aaron Gustafson |
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Tue Dec 12, 2006 11:19 am Post subject: Re: Landing/taxi light requirements for 601XL? |
RE: GE4509 - They use them on tractors too. I used to buy them for my Cessna at the local auto parts store... sometimes they had to order them but they were half the price compared to aviation sources.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
