dav1111(at)cox.net Guest
Posted: Tue Dec 12, 2006 1:48 am Post subject: Battery Wire |
John, the best battery wire around for the long run from the tailcone to the firewall is Super-2-CCA FatWire. You can order it from http://periheliondesign.com/fatwires.htm
It is super flexible and really light weight. I love it. You can order a few feet extra and also use it to make up a great ground wire from the engine to the firewall as well.
Russ Daves
N710RV
First flight 7/28/06
LarryRosen
Posted: Tue Dec 12, 2006 5:39 am Post subject: Battery Wire |
Russ,
What length wire did you order?
Larry
Russell Daves wrote:
| Quote: | John, the best battery wire around for the long run from the tailcone
to the firewall is *Super-2-CCA FatWire. You can order it from
http://periheliondesign.com/fatwires.htm*
*It is super flexible and really light weight. I love it. You can
from the engine to the firewall as well.*
*Russ Daves*
*N710RV*
*First flight 7/28/06*
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Posted: Wed Dec 13, 2006 3:16 am Post subject: Battery Wire |
I think it was 13 feet but you need to run a line to be sure.
Russ
