Posted: Wed Dec 13, 2006 7:34 am Post subject: Not about Priming |
I finally primed my first parts (most tail surfaces primed at
Alexander's Tech Center). The specs:
- used the Industrial Wash Primer that Vans says they use on the QB. 1:2
Catalyst mix (should have used 1:1.5 as recommended)
- bought a cheapo 'trim gun' from Harbour Freight - 4oz cup
- Prepped parts by washing down with Coleman fuel and a red scotchbrite
(thanks all for that discussion)
- I did scuff the skins after dimpling. It does destroy the
scotchbrite especially since I've chosen not to deburr skin holes, but
the scotchbrite effectively deburrs 3/32 thin skin holes in my estimation
- Did the priming in my hangar, wore a filter mask (no fresh air), ran
fans, on a 60deg day. But kept the primer and gun in my 75deg shop
until shooting.
It all seems to have worked well despite my beginner's spray technique.
The thin coat I laid on is translucent greenish gold, rather attractive
but not uniform. Seems to have bonded tightly with the aluminum. In a
strange way it seems tougher than the 2 part epoxy on my other tail
parts even though it is thinner. I'm going to go with it.
Just sharing
Bill "I hate all paint, finishes, and primers" Watson - stapling up the
elevators & trim tabs, ready to dissassemble the tailcone, looking at
the QB components littering the hangar.
Posted: Wed Dec 13, 2006 8:44 am Post subject: Not about Priming |
In my estimation, I think the hole deburring is one of the most important
steps in the longevity of the rivets and the health of the holes they sit
in. The dimple produces a lot of stress to the aluminum and it should be
smoothed before it goes into the dimpler...I would reconsider this skipped
step!
"It does destroy the scotchbrite especially since I've chosen not to deburr
skin holes, but the scotchbrite effectively deburrs 3/32 thin skin holes in
my estimation"
The scotchbrite pad or wheel does not spin inside the hole to do an
effective enough job.
JMOO
JOhn G.
I need to make a deburring tool that is held like a grape before you put it
in your mouth.
| Quote: | From: MauleDriver <MauleDriver(at)nc.rr.com>
To: RV10-List Digest Server <rv10-list(at)matronics.com>
Subject: Not about Priming
Date: Wed, 13 Dec 2006 10:32:53 -0500
I finally primed my first parts (most tail surfaces primed at Alexander's
- I did scuff the skins after dimpling. It does destroy the scotchbrite
especially since I've chosen not to deburr skin holes, but the scotchbrite
fans, on a 60deg day. But kept the primer and gun in my 75deg shop until
shooting.
The thin coat I laid on is translucent greenish gold, rather attractive but
not uniform. Seems to have bonded tightly with the aluminum. In a strange
way it seems tougher than the 2 part epoxy on my other tail parts even
Just sharing
elevators & trim tabs, ready to dissassemble the tailcone, looking at the
Deems Davis
Posted: Wed Dec 13, 2006 9:25 am Post subject: Not about Priming |
There's a simple exercise re deburring that provides some visual
evidence of the differences that I picked up from Dan Checkoway, Take a
non deburred hole and dimple it then take a magnifying glass and examine
the edges. I'll bet that with a hole that was drilled with a drill bit,
you will see cracks around the dimpled perimeter, do the same with a
properly deburred hole and then compare the difference.
Now with all of that said, I'm not sure deburring will cause your plane
to fall out of the sky, for me it was a mental peace of mind issue.
However Ture confessions: there have been times when I forgot to deburr
a few holes prior to riveting and I didn't drill them out and deburr.
Some one mentioned that during WWII when they were mass producing P51's
that they didn't deburr every hole or sheet metal edge in those at the time.
As with everything in an experimental plane you pays your money and
takes your chances.
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
John Gonzalez wrote:
important steps in the longevity of the rivets and the health of the
holes they sit in. The dimple produces a lot of stress to the aluminum
and it should be smoothed before it goes into the dimpler...I would
reconsider this skipped step!
deburr skin holes, but the scotchbrite effectively deburrs 3/32 thin
skin holes in my estimation"
JMOO
JOhn G.
put it in your mouth.
> 1:2 Catalyst mix (should have used 1:1.5 as recommended)
> scotchbrite (thanks all for that discussion)
> but the scotchbrite effectively deburrs 3/32 thin skin holes in my
> estimation
> ran fans, on a 60deg day. But kept the primer and gun in my 75deg
> shop until shooting.
> technique. The thin coat I laid on is translucent greenish gold,
> rather attractive but not uniform. Seems to have bonded tightly with
> the aluminum. In a strange way it seems tougher than the 2 part
> epoxy on my other tail parts even though it is thinner. I'm going to
> go with it.
> Just sharing
> the elevators & trim tabs, ready to dissassemble the tailcone,
> looking at the QB components littering the hangar.
sstella(at)incisaledge.co Guest
Posted: Wed Dec 13, 2006 9:55 am Post subject: Not about Priming |
If you read the Standard Aircraft Handbook that comes with the kit it tells
not to deburr holes that will be dimpled.
Steve
n8vim(at)arrl.net Guest
Posted: Wed Dec 13, 2006 11:05 am Post subject: Not about Priming |
Page 5-2 from Van's (The document called "Useful Information") states:
"All drilled holes should also be deburred ...... Burrs around holes are
a problem mainly in riveting and dimple countersinking..... "
-Jim 40384
Steve Stella wrote:
Steve
LloydDR(at)wernerco.com Guest
Posted: Wed Dec 13, 2006 11:38 am Post subject: Not about Priming |
You are reading from Van's recommendations in the builders manual, if
you go to the aircraft standards book and read about deburring, the only
mention is to deburr for parts storage and to prevent scratches from
material touching, it states nothing about deburring for hole integrity.
Dan
N289DT
Posted: Wed Dec 13, 2006 11:45 am Post subject: Not about Priming |
I wonder why the difference of opinion between Vans and the Aircraft
Handbook?
Steve
Just as a follow up to my last, the primary reason to remove burrs would
to ensure the rivet or dimple set seats correctly and does not get upset
by the burr.
While I do agree with Dan and Deems, looking at the hole after deburr it
does appear smoother on the lip, but the striations from the drilling
process go all the way through the hole, IE even after deburring they
are still in the interior of the hole, and you can see this after the
dimple is formed because more of the interior of the hole is exposed.
Dan
VHMUM(at)bigpond.com Guest
Posted: Wed Dec 13, 2006 11:51 am Post subject: Not about Priming |
Oh dear....just ask any aircraft engineer!! You should deburr all edges and
holes to stop cracks.
Chris 388
Who cares just deburr!!
Chris
james.k.hovis(at)gmail.co Guest
Posted: Wed Dec 13, 2006 12:18 pm Post subject: Not about Priming |
Not necessarily. Recent testing shows burrs around fastener holes
don't have significant impact on the strength of structure. Main
driving factor is skin thickness vs burr height. Thicker stock (used
in larger aircraft) can stand larger burrs. Key thing is to prevent
burrs. Keep your bits sharp, don't push hard while drilling, and keep
your parts well cleco'ed together. I don't know what thickness is
typical in the RV-10, I'd assume .032" or .025" stock. If you're
getting .004" or less burrs, then anything other than a quick "hit"
with scotchbrite is probably a waste of time. Typical deburr operation
in the factory is either use as file-like tool (patented by someone I
actually know...) to run across the back sides of skins or use a
drill-motor and sanding disk. For thin sheet stock, I'd prefer doing
it by hand. And if you deburr BEFORE dimpling, you shouldn't have any
need to deburr afterwards. Bottom line, deburr probably makes fastener
installation easier, but may not do much to improve the structural
"soundness" of the airframe.
JKH
PS: BSAE 1989 U of Mo-Rolla
17+ years aircraft design engineer for a "major" midwest aircraft builder.
Chris 388
Posted: Wed Dec 13, 2006 12:35 pm Post subject: Not about Priming |
OK ask Vans!! They say deburr from Ken Kruegar chief engineer Vans!!
Chris 388
Posted: Wed Dec 13, 2006 1:53 pm Post subject: Not about Priming |
They have not updated that section of the manual in a long time, IE
before the pre-punch days, so in that sense the builders were drilling
thousands of new holes, which had the likely hood of causing large burrs
to form and be trapped between surfaces, but since the advent of the
prepunched kit, there is very little additional metal being remove, thus
there is less likely a burr to form and trap between surfaces.
With that being said, I do deburr everything, but am wondering if I am
just "drinking the kool-aid" as it really adds nothing to the structure,
and if you have a heavy hand might even cause a weaker joint because of
removed material.
Here is another one to stir the pot and a proverbial war, do you always
drill before dimple? If so have you noticed that the hole is actually
larger after the dimple, causing the rivet to be sloppy in the hole,
should you just dimple the punched hole, which then accepts a -3 rivet
without as much slop? I have heard people go both ways on this,
personally I match drill. The reason I was given to match drill was that
the punch does not make a clean hole like a drill will. So with that
being said the reason I ask this is the RV12 will not be match drilled,
IE the rivet will be put directly in a pre-punched hole, and if it is
okay for that structure why not for the previous punched kits? It would
save us a huge amount of time?
Just thinking through out the day.
Dan
N289DT
jesse(at)itecusa.org Guest
Posted: Wed Dec 13, 2006 2:50 pm Post subject: Not about Priming |
This is just my experience, not a technical answer:
I have tried dimpling practice parts without drilling, I have noticed more
damage to the skin (ie. Tiny cracks) when this is done. I certainly do not
recommend dimpling without drilling. For the RV-10, the holes will not be
dimpled. I don't think the issue is that the holes won't line up well, but
rather that the hole won't handle the dimple die as well without damaging
the skin if you don't drill it out. It could be that a modified dimple die
could make a difference here, but I couldn’t say for sure.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
armywrights(at)adelphia.n Guest
Posted: Wed Dec 13, 2006 9:11 pm Post subject: Not about Priming |
Yeah, remember the RV-12 is being pre-punched to size, and the RV-10 is
pre-punched undersized, hence our match drilling. Also, the RV-12 is pop
riveted I believe, which helps take up some builder inexperience.
Rob Wright
#392
Fuse
KiloPapa
Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
Posted: Wed Dec 13, 2006 9:37 pm Post subject: Not about Priming |
We use a #41 drill bit which allows the rivets to fit a little tighter after
dimpling and non-dimpled holes take the rivet just fine also.
I tip I learned from my mentor, Jack Hakes.
Kevin
40494
tail/empennage
_________________ Kevin
40494
do not archive |
Posted: Thu Dec 14, 2006 6:00 am Post subject: Not about Priming |
I'm definitely 'drilling' but actually reaming the pre-punched holes
where drilling isn't required. Reams seems to produce a better hole.
Anyway, what I intend to take a critical look at with a my jewelers
loupe (or whatever those things are called) are prepunched 3/32 holes,
reamed, dimpled, then deburred with red Scotchbrite -- compared to the
same holes reamed, deburred with a tool, then dimpled. It seemed to me
that reamed dimple holes could be effectively and productively deburred
with a vigorous Scotchbrite scrubbing.
Bill "Got my back-rivet plate in place and enjoying some error free
progress on the elevators" Watson
Lloyd, Daniel R. wrote:
removed material.
Dan
N289DT
Posted: Thu Dec 14, 2006 6:03 am Post subject: Not about Priming |
Same here. Using #41 bits and reamer.
KiloPapa wrote:
after dimpling and non-dimpled holes take the rivet just fine also.
Posted: Thu Dec 14, 2006 6:52 am Post subject: Not about Priming |
Just so everyone knows, I do not condone nor recommend in any way not
following the builders manual on match drilling and hole prep, and
following the best practices when building an airplane.
Let me stress this, I do match drill, I do de-burr, I do scuff, I do
dimple, I do clean (with Coleman fuel), and I prime (But I am not
telling with what). Then I rivet, and I check every rivet with the
gauge, some people have said that checking everyone is a waste of time,
but as in much of what we do to prep for riveting, it is for our own
piece of mind. I am sure to the best of my ability that it is done
according to acceptable methods and if I have any questions I have a TC,
an A&P, and an IA that come over to verify.
The email about not match drilling was just posting a question, because
I have been told by many different builders there opinion both ways on
this. For me, it was not worth the time savings, much in the same way I
assemble and then match drill, rather than like some that just drill
separate.
Dan
N289DT
