Garmin 496 - IFR?
jim(at)CombsFive.Com
PostPosted: Thu Dec 14, 2006 2:14 pm    Post subject: Garmin 496 - IFR? Reply with quote
I have been planning on using the Garmin 496 with a panel dock. The Garmin Web page indicates the 496 is not IFR certified.
Here is the response from Garmin as to why:
"The GPSMAP 496 is not a IFR certified unit. The FAA has no intentions to certify a handeld unit as an IFR unit. You need to go with a TSO-129 certified box if you want to an IFR GPS."
Hmmm. That really stinks!
So does that mean no /G filing?
Jim C
N312F
Finishing
n8vim(at)arrl.net
PostPosted: Thu Dec 14, 2006 2:26 pm    Post subject: Garmin 496 - IFR? Reply with quote
Put "VFR GPS" in the comments box... ATC will help you out.
-Jim
Jim C
N312F
Finishing
jesse(at)itecusa.org
PostPosted: Thu Dec 14, 2006 3:08 pm    Post subject: Garmin 496 - IFR? Reply with quote
Without an IFR GPS such as the Garmin 430, you would probably not want to fly hard IFR based on just the 496. There are, however, a number of other less expensive IFR GPSs that would be your official instrument and then you could fly the 496. It is a great backup/supplement, but I would not bet my life on something like that unless I had sufficient IFR backups. Technically I have not idea if that would be accepted or not. It seems to be fairly unclear about non-certified avionics being used for IFR flying in an experimental, but the chances of them finding out that you filed /G with just a 496 is almost negative anyway (unless your e-mail is archived, of course). SYMBOL 74 \f "Wingdings" \s 10
Just IMHO. Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
PostPosted: Thu Dec 14, 2006 3:15 pm    Post subject: Garmin 496 - IFR? Reply with quote
Jim C
Date: 2006/12/14 Thu PM 05:26:03 EST
Subject: Re: Garmin 496 - IFR?
-Jim
Jim C
N312F
Finishing
david555(at)cox.net
PostPosted: Thu Dec 14, 2006 7:01 pm    Post subject: Garmin 496 - IFR? Reply with quote
I would like to comment about the use of a panel dock and a 296/396/496, I
originally thought it was a great idea, until I installed one in my 182. I
really like the 396 and when it was on the yoke it was used as my primary
VFR navigation. (instead of the garmin 430) When it is mounted in the panel
it can be hard and frustating to use the "rocker" button, particularly in
turbulance. The "rocker" button is used in many of the navigation functions
and in almost all of the weather functions. I will be mounting the 396 in
the RV10 on an E mount protruding from the panel, directly above the
stick.The airplane will also have the 430, SL30, Grand Rapids 3 screen, but
for local VFR flying, its hard to beat the 396/496.
MauleDriver(at)nc.rr.com
PostPosted: Thu Dec 14, 2006 8:17 pm    Post subject: Garmin 496 - IFR? Reply with quote
The 396, and presumably the 496, doesn't have approaches in it anyway.
They have some fixes but you *can't* use them for approaches, certified
or not.
What Tim said as far as IFR panel planning. I think it is very difficult
to do effectively without either 1) having used the ticket or 2) copying
someone who knows what they are doing.
Flying IFR with a homebuilt panel seems to me to be a lot more serious
business than flying a homebuilt aircraft to this pilot.
Jim C
N312F
Finishing
wcurtis(at)core.com
PostPosted: Fri Dec 15, 2006 5:02 am    Post subject: Garmin 496 - IFR? Reply with quote
[quote]I really like the 396 and when it was on the yoke it was used as my >primary VFR navigation. (instead of the garmin 430) David, Do yourself a favor and connect your 396 to your Garmin 430. That way weather VFR or IFR, the active route on your 430 will feed down to the portable 396. Then you only have to program one device and if your panel goes dark, you still have the active flight plan in the portable. Get the 396/496 power data cable and connect RxData in to one of the GNS-430 serial out configured for Aviation Data. > The Garmin decison to reduce the TSO on the 480 sounds like a marketing > decision to me. Perhaps someday Garmin will go the way of King which > they so heartliy disliked. How so? Garmin was founded by ex-King engineers and I think on their worst day, their customer service is better than King on their best. Just my opinion. William Curtis http://wcurtis.nerv10.com/ [quote][b]
Tim(at)MyRV10.com
PostPosted: Fri Dec 15, 2006 5:12 am    Post subject: Garmin 496 - IFR? Reply with quote
I agree with your statements. Also, I'm not sure if this is
correct or not, because it's been a while, but doesn't Garmin
set up those handhelds purposely to NOT give you the info
you'd need to complete an approach? I mean, they give
you the fixes for some of the approach segments, but I thought
I had heard or seen that the purposely leave out some of the
final approach data.
I've had a couple of educational experiences regarding handhelds.
Previously, I was adamant when talking to my highly experienced
airline pilot pal that I could get down to my airport while IFR
with my handheld. I even went as far as to set up the extended
runway centerline and try to prove it by flying down to
the runway. Yeah, I even made it over the airport. The thing
is, I really didn't have a clue as to exactly where I was on
the approach and if I had safe obstacle clearance. You may
indeed be able to get to an airport with one, but you really
won't be able to effectively fly a real and safe *approach*.
Prior to my instrument training, I had told the same guy how
I could use my handheld for enroute ops with no problem, and
use it to help me fly the approach using my other actual
non-GPS nav equipment. He explained that I would find that
there's no way I'd have time to play with that GPS during
an approach, to do the things I needed. And that a handheld
GPS doesn't have the same buttons or menu structures or usage
designs as the certified gear, rendering it much less easy
to use for that type of flying. I didn't believe him...until
I took my instrument training. I found a couple things.
1) I didn't have time to play with the GPS at all. I could plug
in a Direct to waypoint, but it just wasn't made to quickly
adjust routing of a full route. 2) With it mounted low on
the yoke, it was not at all comfortable to spend a lot of
time looking at it, as it distracts you from your scan to look
that low.
Truly, I've had approaches way back then where I had my hands
full just keeping a pair of needles centered and my speed in
check. And more recently I've found that having a properly
designed menu and routing structure to a system can be
extremely important to getting things done quickly. With
the RV-10, you're moving so fast even on enroute ops that
on things like a low IFR departure and climb, you're a busy
pilot just flying the plane. Some of the things that you'd
normally consider conveniences of use can become critical to
a comfortable completion of flight.
This is just a guess, but after a couple years of watching
the RV-10 builders evolve, I do predict that although the
flying qualities of the RV-10 make it a great IFR platform,
that we're headed for some statistical failures. There is
the lions share of the builders who plan to build an IFR
plane, but with our flexibility of design, I'm not sure if
it's going to be done to the required standards by some.
And from there on, it's only a matter of time before we start
to see the statistics turn bad as the pilots start actually
flying some IMC flights. There is an overwhelming urge
in the homebuilding arena to try to cut corners on what
is being done in certified planes. We tout the benefits
of building our own plane to OUR standards, and chuckle
as we talk about how much cheaper we can do things. Well,
there's some truth to the talk that we can save money, but
at the same time, some things are done on certified planes
for a reason...usually safety.
I have been told by that same wise buddy above that most of the
rules of airspace, and IFR procedures, and rules that were bought
in blood. It took deaths to get things to change to be the way
they are.
I have a much higher respect for what is required to safely
do IFR flight than I do for just building a homebuilt aircraft.
Most anyone can build an RV-10 and fly it reasonably
safely. Flying in hard IMC conditions, however, in any aircraft,
is a much more challenging thing. Hopefully the flexibility
we're allowed to build our own planes doesn't turn into the
demise of our safety record though, as people push the limits
of what their design and their skills can handle.
or not.
> Jim C
> N312F
> Finishing
PostPosted: Fri Dec 15, 2006 5:43 am    Post subject: Garmin 496 - IFR? Reply with quote
Tim,
Well said!
The only reason I have not pursued IFR ticket is that I would have not been able to stay proficient. If I can't stay current then having the IFR rating would only serve to get me into trouble.
I do plan on building my skills and knowing what my limits are.
A statistic is not something I want to become. I do value the input of all the people in this forum. If I don't learn from this, I shouldn't be flying anyway. Safety has to come first.
I don't know which would be worse, having a inexperienced pilot with a full state of the art panel or having an experienced pilot with a minimal IFR panel. Hopefully I can take baby steps to build my skills and upgrade the airplane as I need it.
Thanks, Jim C
N312F
Date: 2006/12/15 Fri AM 08:12:56 EST
that low.
they are.
or not.
> Jim C
> N312F
> Finishing
david555(at)cox.net
PostPosted: Fri Dec 15, 2006 5:54 am    Post subject: Garmin 496 - IFR? Reply with quote
Thanks for the info. David
Tim(at)MyRV10.com
PostPosted: Fri Dec 15, 2006 6:22 am    Post subject: Garmin 496 - IFR? Reply with quote
As far as the proficiency goes, here's my take on that.
During my build, I certainly didn't maintain actual proficiency
in IFR skills. But, once you get your plane built, you'll
be spending 25-40 hours just flying the plane. Then, you'll
really need to spend some more time truly learning your panel
for IFR ops. This is best done with an instructor, and can
be done as part of the Instrument Proficiency check. You'll
need to shoot multiple approaches in practice before you'd
ever want to even try it for real. So I don't think it's
unacceptable to get the ticket, but then lose the proficiency
for a while. The fact is, you'll learn a lot of things
getting the ticket that will help with your conceptualization.
Also, you can always re-read books, or watch a DVD Course
again. The important part is that you get some re-training
using your new panel when you're done.
Also, as has been discussed before, but is arguable, is that
I think there is some value in spending some time during your
IFR training doing it the "old fashioned" way. Ideally,
you'd put in 20 hours using steam gauges, and another 20
on EFIS systems. But, there's something to be said for
being able to make the approach using some of the rudimentary
gear, and maintain your orientation...and it may help you
later if your EFIS dies.
Tim,
Well said!
PostPosted: Fri Dec 15, 2006 6:43 am    Post subject: Garmin 496 - IFR? Reply with quote
I have used a 396 in a panel dock a fair bit and have talked to others who
are, and there have been no complaints. When in turbulence, pushing any
buttons is harder, but the 396 is fairly intuitive and the buttons are
responsive. I have not tried a yoke mount or anything like that, so the
panel mount is all I have experience with. I personally would very much
recommend it, for weather more so than for navigation, but just because that
has been my use of it.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
LloydDR(at)wernerco.com
PostPosted: Fri Dec 15, 2006 6:52 am    Post subject: Garmin 496 - IFR? Reply with quote
I totally agree with this, during the first hours my instructor took us
out in a plane with all the bells and whistles, and with my lacking of
experience I was able to fly the approach pretty easy. But then we went
out in my Cherokee 140 that had dual KX155 with standard CDI's with
glideslopes, and I could not maintain, and quickly became overloaded
with what needed to be done. This demonstration alone was what made me
determine to learn the "old fashion way". I am putting so much
technology in the plane, that it will make it simple to fly, right up to
the point that it fails and I have to revert to the CDI/Nav radio.
So, with that being said I will be learning to fly a standard set of
instruments, and then will spend the first 100 or so hours in the RV
learning all the bells and whistles but still have the ability to fall
back to an SL30/CDI approach.
Dan
PostPosted: Fri Dec 15, 2006 8:08 am    Post subject: Garmin 496 - IFR? Reply with quote
Yes, they include only minimal approach information - Perhaps just the
final fix with initial fixes eliminated. Whatever, it's not enough to
fly an approach. Legal reasons I'm sure.
dlm46007(at)cox.net
PostPosted: Fri Dec 15, 2006 9:05 am    Post subject: Garmin 496 - IFR? Reply with quote
You will find that the approach intersections are there (in the database)
but do not come up when an approach is selected. Example the RFD RNAV (GPS)
Z 19 calls out NADME, JORMO, WAGET, all of which are in my G295 database of
4/13/06. As a backup map you could add them to the flight plan in the
portable.
dlm46007(at)cox.net
PostPosted: Fri Dec 15, 2006 10:13 am    Post subject: Garmin 496 - IFR? Reply with quote
One other thing to consider, the FAA has to set the TSO so that "EVEN A
CAVEMAN CAN DO IT".
No knowledge of UHF electronics, computer programming, spherical geometry or
mathematical statistics required.
PostPosted: Fri Dec 15, 2006 11:15 am    Post subject: Garmin 496 - IFR? Reply with quote
database) but do not come up when an approach is selected. Example the
RFD RNAV (GPS) Z 19 calls out NADME, JORMO, WAGET, all of which are in
my G295 database of 4/13/06. As a backup map you could add them to the
Yes, they are in the 396 too but having to add them manually into a
second unit just about negates their use in practical IFR flight for
this pilot.
Arguably non-standard, yet supported use of even certified GPS systems
can lead to problems. A recent classic is the King Air accident at
Martinsville VA. Check out September's AOPA mag or the NTSB
http://www.ntsb.gov/ntsb/brief.asp?ev_id 041104X01760&key=1
It was a localizer approach with an NDB fix. The King Air had everything
it needed plus some. What appeared to trip them up was the use of a
KLN90B (2nd gen GPS) for waypoint sequencing. That is, using it to
track passage of the NDB fix, and the DME-based missed approach fix. If
you can read the IFR jargon, the AOPA (and Flying) mag writeups are
fascinating reading. Everything about the operation was by the book or
beyond. And yet use of the GPS as a backup aid seemed to trick the
trained, proficient, and otherwise compentent crew, sending them into
the hills.
For me, it crystallized some changes I had recently made to my GPS/IFR
work - that is, I no longer try to recreate non-GPS approaches on my 2nd
Gen Garmin 300XL. If I use it in place of an ADF, VOR, or DME, that's
all I do with it. The single pilot IFR cockpit can be a busy place and
simplicity has helped me, even in my crawling Maule. Of course, the new
equipment makes me drool.
What is it that the FAA says, building experimental aircraft is for the
education of the builder. I think you can do a lot of experimentation
on aircraft design and construction and learn a lot. Experimenting
with IFR equipment, procedures, or anything is another matter. If you
do no experimentation with IFR equipment and procedures, you'll learn
plenty.
How did the airmail pilots learn about IMC? By sending another pilot
and a/c into the next cloud.
GRANSCOTT(at)aol.com
PostPosted: Sat Dec 16, 2006 5:06 am    Post subject: Garmin 496 - IFR? Reply with quote
Jim consider buying a "certified" IFR GPS like a 300xl and use the 496 as situational awareness system...
P
PostPosted: Sat Dec 16, 2006 9:09 am    Post subject: Garmin 496 - IFR? Reply with quote
I fly that setup now as installed in my Maule with the 300XL installed
over 6 years ago and the 396 mounted 2 years ago. Flown a good deal of
IMC approaches and such. Very serviceable. The weather on the 396 is
worth it's weight in gold.
However, I would suggest that going that route now is to miss 2 whole
generations of GPS development. And I don't think giving up the newer
technology will save you much money (look closely at what the 300XL
install requires - it's more than just the box)
The real challenge is that 1) you will have to thoroughly have to learn
and stay proficient on the 300XL in order to use it for GPS approaches.
2) no matter how much you try to use the 396 for IFR enroute and
terminal work, you simply can't/shouldn't do the approaches on it
because they aren't there. So you will be faced with using both systems
on typical flight to get optimal utility from both. Since they can't be
connected for sharing route information, you will be entering a lot of
route information on both. And believe me, when stuff gets busy, losing
track of what's entered on which system can get you.
I love my setup just as a steam guage using, ADF proficient, dual Nav
equipped 'Bo driver treasures her skills - but it's old school now. The
396/496 is an excellent weather provider, sat music source, flight info
DB, and last resort backup in an IFR machine. Using it as a primary
IFR device is dreaming. Please get a real panel.
Bill "inventorying the QB, with no autopilot, no ADF, and no dual Nav on
my crawling Maule" Watson
P
