LarryRosen
Posted: Thu Dec 14, 2006 2:46 pm Post subject: Garmin 496 -Antenna |
Jim and others,
I am also planning on putting a Garmin GPS into a panel dock. I was
wondering on where you were going to put/mount the antenna? With the
freedom we experimental builders have it sure would make sense to
somehow mount the antenna under the cowl or canopy and not just have it
sitting on the glare shield.
Larry
#356
James Hein wrote:
Put "VFR GPS" in the comments box... ATC will help you out.
-Jim
jim(at)CombsFive.Com wrote:
> I have been planning on using the Garmin 496 with a panel dock. The
> Garmin Web page indicates the 496 is not IFR certified.
> Here is the response from Garmin as to why:
> "The GPSMAP 496 is not a IFR certified unit. The FAA has no
> intentions to certify a handeld unit as an IFR unit. You need to go
> with a TSO-129 certified box if you want to an IFR GPS."
> Hmmm. That really stinks!
> So does that mean no /G filing?
> Jim C
> N312F
> Finishing
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
jesse(at)itecusa.org Guest
Posted: Thu Dec 14, 2006 3:11 pm Post subject: Garmin 496 -Antenna |
Here's my hidden mount on N416EC. I don't think there has ever been a
problem with reception in 92 hours on the Hobbs.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
24 KB |
450 Time(s) |
35.6 KB |
489 Time(s) |
jim(at)CombsFive.Com Guest
Posted: Thu Dec 14, 2006 3:19 pm Post subject: Garmin 496 -Antenna |
I had heard that some have mounted it out in front of the firewall at the top just behind the engine. I do not have the unit yet and have not actually thought too much about it. I don't mind putting it on the top of the Instrument panel (I think!). I may change my mind after seeing it.
Jim C
N312F
Date: 2006/12/14 Thu PM 05:45:27 EST
Subject: Garmin 496 -Antenna
Jim and others,
Larry
#356
Posted: Thu Dec 14, 2006 5:18 pm Post subject: Garmin 496 -Antenna |
Jesse,
Excellent! I like that mount!
I am not IFR rated (Yet). The plans are to add that after I get flying. I think the idea of "VFR GPS" in the comment section of the flight plan is the way to go. It stays FAA legal and still provides a cost effective panel in the airplane.
Jim C
Tim(at)MyRV10.com Guest
Posted: Thu Dec 14, 2006 6:03 pm Post subject: Garmin 496 -Antenna |
Now might be a good time to again bring up a comment regarding panel
planning and IFR ops. It's just my opinion, but I really, truly
believe that a person will make better choices in all of the
panel-related decisions if they take the time to get their IFR
rating *before* they lay out their panel. I know it's a downer
when you want to spend the money on the plane, but truly you will
not have a full understanding of what's necessary or how critical
some of the details can be, until you have the rating and have
spent some time in the clouds...preferrably during the rating.
It could actually save you money in the end if you don't have
to re-do things, or have a more effective panel that allows you
to actually get there safely.
Jesse,
Jim C
apilot2(at)gmail.com Guest
Posted: Thu Dec 14, 2006 6:26 pm Post subject: Garmin 496 -Antenna |
Amen
On 12/14/06, Tim Olson <Tim(at)myrv10.com> wrote:
> Jesse,
> Jim C
> Do not archive
wcurtis(at)core.com Guest
Posted: Thu Dec 14, 2006 6:33 pm Post subject: Garmin 496 -Antenna |
[quote]> I have been planning on using the Garmin 496 with a panel dock. The >> Garmin Web page indicates the 496 is not IFR certified. Jim, What exactly surprises you that the Garmin portable GPSMAP 496 is NOT IFR certified? Let's see: 1) It's portable - how do you validate the repeatably of a portable system configuration? 2) The 496 is $2800, their IFR certified panel units start at $11,000 While is is certainly a good idea to have a portable GPS, the requirements for TSO 129 or TSO146a are quite clear and IMHO, no portable will EVER meet these requirements-yes ever is a long time. That being said, I too will have a portable 496/596(?) IN my panel with the antenna mounted on the glare shield. It will sit right below an IFR certified GNS-430W. Even if you don't have a GNS-4/5xx you still would be able to use the portable as "supplemental" aid to navigation, however, no matter how you read the regs you definitely will not be able to file /G. By the way, anyone notice that Garmin Service Bulletin 0621 has reduced the WAAS certified TSO'd 146 (sole means navigation) GNS-480 to a lowly TSO's 129 box like the non WAAS GNS430/530? It also explains what took Garmin so long to get WAAS certification for the GNS 430/530. GNS 480 owners can read the gory details below: http://www.avionicswest.com/PDFiles/480SB0621.pdf http://www.avionicswest.com/PDFiles/480nesletter.pdf http://www.avionicswest.com/software/Service%20Bulletin0621.htm William Curtis http://wcurtis.nerv10.com/ [quote][b]
dlm46007(at)cox.net Guest
Posted: Thu Dec 14, 2006 6:48 pm Post subject: Garmin 496 -Antenna |
The Garmin decison to reduce the TSO on the 480 sounds like a marketing decision to me. Perhaps someday Garmin will go the way of King which they so heartliy disliked.
Posted: Thu Dec 14, 2006 7:19 pm Post subject: Garmin 496 -Antenna |
Excellent point! While that seems so obvious, It does need to be said. It's right up there with measure twice, cut once.
My plans for the panel include the AF-3500 EFIS / Engine monitor, Garmin 496 MAP/GPS, SL30 Nav/Com, Garmin 327 Transponder, AP and PE 7000B audio panel.
Thats way more function / capability that I have now in a CAP Cessna 182.
Layout / use however are clearly major points for discussion.
Dang, I hate it when you are right! I need to go do some work with some IFR rated pilots to make sure I get this right the first time around.
Thanks, Jim C
N312F
Date: 2006/12/14 Thu PM 09:02:32 EST
Subject: Re: Garmin 496 -Antenna
Jesse,
Jim C
Posted: Thu Dec 14, 2006 7:24 pm Post subject: Garmin 496 -Antenna |
It is interesting that when you read the bulletins, which I've seen
a while back, that there are some inconsistencies. For one, depending
on which one you read, one says that you will still be able to fly
LPV approaches, and the other talks about needing alternate equipment
and so on. And, it does state that the "problem" is basically in
how the equipment matched up to a technical specification, not something
that they saw failures in the field over. It's been a popular and
proven box, so it's hard to be shaken too hard over a technicality, even
if it does (or doesn't) truly limit the functionality until they come
out with a "fix". Not too many months ago, I did get the latest
software rev v2.1, and they told me that there are always
updates in the works. It will be interesting to see how they evolve
the 480 now that the 430/530's will have WAAS...especially when those
new models came out at even more obscene pricepoints.
Tim Olson - (with an "on", not an "en" as is being commonly written
these days)
David McNeill wrote:
[quote] The Garmin decison to reduce the TSO on the 480 sounds like a marketing
Posted: Thu Dec 14, 2006 7:32 pm Post subject: Garmin 496 -Antenna |
| Quote: | From my "Inexperienced" point of view:
- The 496 has a WAAS GPS receiver.
- It's newer than the panel mounted 430, 480, 5xx stuff
- They (Garmin) already have certified database for use
So why not make a portable receiver that meets the TSO standard? (Which I admittedly know nothing about)
These are just questions from my viewpoint. Just because it's portable should not mean it is not certifiable. (Again - My opinion!) The TSO requirements may indeed force the panel mount issue.
As for cost, the certification costs will drive the cost of the unit up. Fewer units sold also drive the cost up.
This whole certification / IFR business is new to me. So I am learning as I go.
This is a great forum to get the questions asked and get good feedback.
Thanks, Jim C
N312F
Date: 2006/12/14 Thu PM 09:32:41 EST
To: RV10-List(at)matronics.com
Subject: RE: Garmin 496 -Antenna
| Quote: | > I have been planning on using the Garmin 496 with a panel dock. The
Jim,
Let's see:
William Curtis
Posted: Thu Dec 14, 2006 7:37 pm Post subject: Garmin 496 -Antenna |
Dang it - All these responses are making me rethink my plans!
Jim C
N312F
Date: 2006/12/14 Thu PM 10:32:19 EST
Subject: Re: RE: Garmin 496 -Antenna
Thanks, Jim C
N312F
Jim,
Let's see:
William Curtis
Posted: Thu Dec 14, 2006 8:28 pm Post subject: Garmin 496 -Antenna |
There is a minor flaw in both Garmin's logic and Avionics West's
opinion. The manufacturer can NOT make a service bulletin mandatory
for Part 91, and they can NOT take away an FAA granted certification.
ONLY the FAA can do that. Unless you are flying a type certified
aircraft for hire, where service bulletins must be complied with, you
can ignore said service bulletin until/if the FAA decides to make it
an AD. Not sure why sole means of navigation is an issue anyway, since
the unit has VOR built in. Perhaps you would want to be extra cautious
about an LPV approach, but until more info comes out that is about all
you need to do. In fact, the document itself says it is a non-problem
in the real world:
"Garmin notified the FAA of a discrepancy in a test specification
relating to the Initial Acquisition and Reacquisition of GPS
Satellites in the presence of high noise and interference levels.
These high noise levels do not exist in any real-world situation at
this time so there is little if any impact to GNS 480 (CNX80) users.
However, Garmin is committed to resolving the issue quickly and
removing any limitations on our WAAS navigators."
KM
A&P/IA
On 12/14/06, W. Curtis <wcurtis(at)core.com> wrote:
| Quote: | >> I have been planning on using the Garmin 496 with a panel dock. The
Jim,
certified?
Let's see:
configuration?
William Curtis
Kellym
Posted: Thu Dec 14, 2006 9:05 pm Post subject: Garmin 496 -Antenna |
All IFR navigation systems have to have monitoring to ensure they are on
the air and accurate. Ground based equipment have permanent receivers
nearby the fulfill that need and sound alarms in a tower or FSS if they
are out of tolerance. GPS has to use RAIM or a WAAS prediction program
to ensure enough satellites will be in view. Portables don't have that
function. You have to have an indicator in your scan for course
guidance...on screen indications not acceptable. You have to have an
annunciator to tell you what mode it is in, alert you to messages and
warnings..and other stuff in the TSO. You have to ensure no avionics
interference, which requires a fixed location. After all that, most
critical, the FAA has said they will never approve a portable, end of
discussion.
Thanks, Jim C
N312F
KCHD |
flysrv10(at)gmail.com Guest
Posted: Fri Dec 15, 2006 3:37 am Post subject: Garmin 496 -Antenna |
Speaking of IFR stuff...I would like an honest opinion regarding Garmin 480 and Garmin 430 from those flying them. Some people say that 480 is not intuitive. I have not fond customer review on either model, only magazine reports.
I have decided that I will not wait for GRT for their IFR GPS as they are estimating another year to get it to the customers,
Rob Kermanj
On Dec 14, 2006, at 9:02 PM, Tim Olson wrote:
[quote]--> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com (Tim(at)MyRV10.com)>
jim(at)CombsFive.Com (jim(at)CombsFive.Com) wrote:
| Quote: | --> RV10-List message posted by: <jim(at)combsfive.com (jim(at)combsfive.com)>
Jesse,
Jim C
-- Please Support Your Lists This Month --
(And Get Some AWESOME FREE Gifts!)
November is the Annual List Fund Raiser. Click on
the Contribution link below to find out more about
this year's Terrific Free Incentive Gifts provided
by:
* AeroElectric www.aeroelectric.com
* The Builder's Bookstore www.buildersbooks.com
* Aeroware Enterprises www.kitlog.com
* HomebuiltHELP www.homebuilthelp.com
List Contribution Web Site
--> http://www.matronics.com/contribution
Thank you for your generous support!
- The RV10-List Email Forum -
--> http://www.matronics.com/Navigator?RV10-List
LloydDR(at)wernerco.com Guest
Posted: Fri Dec 15, 2006 6:31 am Post subject: Garmin 496 -Antenna |
We asked the local FSDO their opinion on this issue with the portables,
and the feedback we got is that there has been allot of conversation on
making portables Legal for IFR but the main concern is not the unit
itself, rather the antenna, and its placement, this is what makes a
portable dangerous, because some just throw the puck up on the glare
shield and it could easily fall or somehow get blocked from receiving a
signal. The last thing you want to be doing is scrambling around in zero
vis and looking for your main nav source antenna. As for the units, they
say as long as they are hooked to ships power they feel they are just as
reliable as panel mounted units.
For what it is worth, I am also putting in the 496, but it will be
backing up the Chelton Freeflight so I can file /g. This of course is
after I get my IFR ticket, I did pass the written over Thanksgiving and
am about 10 hours into the flying portion.
Dan
N289DT RV10E
Posted: Fri Dec 15, 2006 6:53 am Post subject: Garmin 496 -Antenna |
Don’t know almost anything about the 480, but I have used the 430 quite a bit. First of all, it seems to be about the industry standard for pre-G1000 panels. They are everywhere and TONS of pilots know how to run them. That it a benefit in itself, IMHO. Even all the new Cirrus planes have one or two of them, I believe, along with the Avidyne glass. It is quite intuitive and is very stable. The screen quality leaves a little to be desired, and getting weather on the screen is not my recommendation because of the low resolution, size of the screen, and limited functionality of the weather it can display.
The controls are easy to use and it is easy to navigate. Once an approach is selected, it is hard to accidentally take it off that approach, unlike some handhelds I have used. It flies the TruTrak auto pilots beautifully, only horizontally, of course.
The COM and NAV are second to none in my experience, which is not very broad. The power output of the COM and the sound quality are great. The only thing I know about the 480, probably, is that the COM output power is not as high, but I can’t give any more details.
Overall, I would not say “Don’t do the 480”, but I know the 430 is extremely widely used and the $6,000 price tag is not too bad either.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kermanj
Sent: Friday, December 15, 2006 6:37 AM
Rob Kermanj
Jesse,
Jim C
this year"s Terrific Free Incentive Gifts provided
by:
http://www.matronics.com/cto browse Archive Search more: href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List ===========
12/14/2006 7:28 PM
12/14/2006 7:28 PM
Posted: Fri Dec 15, 2006 7:10 am Post subject: Garmin 496 -Antenna |
The 430 is designed to go direct and fly an approach. If you fly where
that is real world it will be great.
The 480 is design for the busy IFR system where you fly departures,
airways and approaches. It has all the airways in it, the 430 doesn't.
So you can enter your flight plan just as the clearance is read,
instead of every single waypoint. Yes, it will take a bit more to
learn, but CFIIs I know that mastered it say it is like night and day.
An IFR tool vs a VFR tool. Not to mention the 480 is now cheaper than
the 430W and has a bigger screen.
On 12/15/06, Rob Kermanj <flysrv10(at)gmail.com> wrote:
| Quote: | Speaking of IFR stuff...I would like an honest opinion regarding Garmin 480
reports.
Rob Kermanj
Jesse,
Jim C
www.kitlog.com
Posted: Fri Dec 15, 2006 7:16 am Post subject: Garmin 496 -Antenna |
I agree; having used the Loran C system, the Garmin 90, Garmin 150, Garmin
pilot III and the Garmin 295, I found that the only time I lost a fiz was
when the antenna was shielded and/or when the GPS satelittes were outputing
lower power. I used to be unable to get a lock inside a wood frame house but
now the power output is sufficent to get a lock in my living room. Another
concern of the FAA I am sure is whether there is sufficent computing power
in the handheld to process the incoming data and update the moving map at a
display rate which is adequate for the speed of the aircraft (had the 295
lockup while using the WAAS sfotware that was available). Most of the TSOed
units will handle speeds of 900+ kts. It would probably be helpful if a
laymens guide to the GPS theory was provided. Another concern would be the
testing and update controls on the software. Do not archive.
Posted: Fri Dec 15, 2006 7:17 am Post subject: Garmin 496 -Antenna |
I don't think that either the 430 or 480 would be a bad choice. They're
both good, despite their differences. I have heard that the 480
is better at route planning, and is more of a flight management
system, but personally I think that between those 2 systems, you'll
get used to either.
One benefit to the 480 is that you can couple it to the TruTrak's
and it will fly both laterally and vertically, so it does have
that one upside.
I do find that the amount of data you can get out of the 480 is
pretty great. In fact, I just added a CO Guardian CO monitor
to my plane, and it interfaces serially to the GNS480 and I can
get onscreen display of Cabin Pressure, Cabin Temp, and CO level
in ppm. Totally didn't expect to ever have that one.
Jesse Saint wrote:
| Quote: | Don’t know almost anything about the 480, but I have used the 430 quite
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org <mailto:jesse(at)itecusa.org>
www.itecusa.org <http://www.itecusa.org>
W: 352-465-4545
C: 352-427-0285
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Rob Kermanj
*Sent:* Friday, December 15, 2006 6:37 AM
*To:* rv10-list(at)matronics.com
*Subject:* Re: Garmin 496 -Antenna
magazine reports.
Rob Kermanj
<mailto:Tim(at)MyRV10.com>>
jim(at)CombsFive.Com <mailto:jim(at)CombsFive.Com> wrote:
> <mailto:jim(at)combsfive.com>>
> Jesse,
> Jim C
> Do not archive
by:
<http://www.buildersbooks.com>
* HomebuiltHELP www.homebuilthelp.com <http://www.homebuilthelp.com>
< /DIV>
< /DIV>
href="http://www.matronics.com/contribution">http://www.matronics.com/cto
12/14/2006 7:28 PM
12/14/2006 7:28 PM
