LM(at)malmstrom.ch Guest
Posted: Fri Dec 15, 2006 11:49 am Post subject: Bad idea to skip section 32: Tailcone Attachment ? |
Hello group
I am quickly approaching section 32 where you attach the tailcone. As I am heavily ‘shop space challenged’, I’d like to postpone this step as long as possible. My idea is to:
- Temporarily attach (cleco) the tailcone and do what can be done in the baggage area.
- Remove the tailcone and finish the rest of the fuselage (including cabin cover).
- Install the engine, cowling & panel.
- Finally install the tailcone completely.
Jesse had an image recently where the cabin cover was installed without tailcone so it seems to be possible. What are the traps and gotchas with this approach? What can be done in the baggage area and what not?
Thanks everybody in advance.
Lorenz.
#40280
http://www.malmstrom.ch/RV10.htm
dav1111(at)cox.net Guest
Posted: Sat Dec 16, 2006 3:15 am Post subject: Bad idea to skip section 32: Tailcone Attachment ? |
I didn't see Jesse's picture concerning attachment of the cabin top without attachment of the tailcone but I suspect it must have been merely a sitting on of the cabin top to the fuselage and not an install.
Not having attempted to do any work in the baggage area without the tailcone attached I can't say for sure what is and is not possible but I would not recommend removing the tailcone and attempting to do the cabin top before attachment.
Russ Daves
N710RV
First Flight 7/28/06
seipel(at)seznam.cz Guest
Posted: Sat Dec 16, 2006 7:03 am Post subject: Bad idea to skip section 32: Tailcone Attachment ? |
If you permanently attach the cabin top before you attach the tailcone,
you're going to have a heck of a time getting the tailcone on later. I
had a hard time getting things lined up properly with 2 people and the
top wide open where I could see what I was doing and had access to
everything, I can't imagine trying to do it with the cabin top in the way.
I also don't think you can do a whole lot in the baggage area without
the tailcone on.
PJ
RV-10 #40032
Lorenz Malmström wrote:
Hello group
the baggage area.
cabin cover).
what not?
Lorenz.
#40280
Posted: Sat Dec 16, 2006 8:41 pm Post subject: Bad idea to skip section 32: Tailcone Attachment ? |
In complete agreement, I don't think you can do much of anything. Do not
even try unless you wnat to rebuild the entire thing again. I have been
working on this area for two weekends and I am skipping steps because my
wires are in the mail and my baggage floors are not riveted in yet, but the
tailcone has been on for a month now. This part seems to be going very slow
as I keep having to plan ahead as to not fall into a trap. Ordering and
waiting on mail deliveries.
John G.
| Quote: | From: PJ Seipel <seipel(at)seznam.cz>
Subject: Re: Bad idea to skip section 32: Tailcone Attachment ?
Date: Sat, 16 Dec 2006 10:03:25 -0500
you're going to have a heck of a time getting the tailcone on later. I had
a hard time getting things lined up properly with 2 people and the top wide
open where I could see what I was doing and had access to everything, I
I also don't think you can do a whole lot in the baggage area without the
tailcone on.
PJ
RV-10 #40032
>Hello group
>baggage area.
>cover).
>Lorenz.
>#40280
