		Eddie G.
  Joined: 03 Nov 2006 Posts: 15 Location: Los Angeles, CA
				 Posted: Thu Dec 14, 2006 6:15 pm    Post subject: POR 15 |
				Has anybody used POR 15 as a primer sealer or tested it against other corrosion proofings?
 Thanx..
 Eddie
 (Trying to build a 601XL)
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		dougsnash(at)yahoo.com Guest
				 Posted: Fri Dec 15, 2006 4:20 am    Post subject: POR 15 |
				Eddie, I have only had very limited exposure to the
 POR-15 product line when I was playing with antique
 cars.  The trick to POR-15 is the phosphoric acid
 metal prep you put on the rusted steel to neutralize
 the rust and give the coating some bite to the steel
 before applying the top coat.
 I tried two starter kits on a car I was restoring.
 I'm not sure if I used them correctly or not but was
 not really that impressed with the results.  I've seen
 the hype at car shows so that is why I think I may
 have been misusing the product.  It did not work any
 better than good quality enamel paint.
 As for using it with aluminum, I cannot comment.  Is
 there a new POR-15 product designed for use with
 aluminum?  If you are thinking of using the Automotive
 products on aluminum, I would think they would be a
 bit on the heavy side for aviation use.
 If you were thinking of using it to coat the steel
 components such as the engine mount, my concern would
 be that supposedly the POR-15 is very resistant to
 cracks (I'm not sure on this point) but this feature
 could possibly hide a developing crack in the
 underlying metal.  Other than that, I suspect it would
 work well.  Powder coating would probably be better
 for this application though.
 Hope these opinions help a little.
 Doug MacDonald
 CH-701 Scratch builder
 NW Ontario, Canada
 Want to start your own business?
 http://smallbusiness.yahoo.com/r-index
		Eddie G.
				 Posted: Fri Dec 15, 2006 3:39 pm    Post subject: Re: POR 15 |
				I was looking for an interior primer sealer for where the parts contact each other and for under/around the rivets. Something that won't come off later with Corrosion X. I am not convinced self etching pirmers are good sealers since they are porous and may collect moisture. Not sure about Cortec or similar primers. And I don't want to deal with things like Alodine since part of the plane will be built in my spare bedroom.
 I'll try some engine paint on a test sheet and see how they hold up. They have been sticking good on my aluminum water pump so far.
 Thanx.
		pacificpainting(at)comcas Guest
				 Posted: Fri Dec 15, 2006 6:30 pm    Post subject: POR 15 |
				Get a can of Zinc Chromate and a brush. Look inside the wing of an older
 plane that was primed. They don't usually have much if any corrosion.
