bcondrey
Posted: Wed Dec 13, 2006 5:30 pm Post subject: Annunciator Panel Update? |
Anybody got an update on the potential annunciator panel that was being discussed several months ago?
Bob
nuckollsr(at)cox.net Guest
Posted: Thu Dec 14, 2006 7:50 am Post subject: Annunciator Panel Update? |
At 05:30 PM 12/13/2006 -0800, you wrote:
<bob.condrey(at)baesystems.com>
Bob
That topic was one of several being massaged around
plates of tacos at the el Mexico cafe but it seems
to have died out. None of the pepper-heads present
has demonstrated an interest in stepping up to the
project.
< with experiment. >
< --Lawrence M. Krauss >
aadamson(at)highrf.com Guest
Posted: Thu Dec 14, 2006 9:27 am Post subject: Annunciator Panel Update? |
Well, I'll throw my hat in the ring as at least a paper designer.
I've been toying with a simple microprocessor based application that could
take either active hi, or active low, and maybe alternating types of inputs.
It could then generate either active hi, or active low, or flashing outputs,
along with an associated audio notification event. This would all be
configurable from a simple serial port based device and some windows or
other software. It would obviously support a "test" mode and would be
configurable for audio volume. Second generation would allow recorded voice
instead of simple tones. Most likely, I'd center it around low power
incandescent or LED annunciation lights.
Because IO on micros *isnt* unlimited, perhaps looking at 8 gazintas, and 8
gazoutas as a start. Power would be 9-32v and regulated on the board. I'd
look for something the size of a pack of gum or maybe just a smidge large to
stay in thru hole parts and allow it to be available in Kit form.
Would there be much interest in the above? I'm most likely going to do the
Honeywell type lights, which are LED based and has been what is driving my
desire for the above.
Alan
sportav8r(at)gmail.com Guest
Posted: Thu Dec 14, 2006 10:05 am Post subject: Annunciator Panel Update? |
Put me down as interested in one, Alan.
Bill B. re-doing RV panel for glass/IFR this spring
On 12/14/06, Alan K. Adamson <aadamson(at)highrf.com> wrote:
Alan
Posted: Thu Dec 14, 2006 10:44 am Post subject: Annunciator Panel Update? |
Allan
Looks very good to me. (Although I don't have the slightest idea what
"gazintas" and "gazoutas" are!?)
I'd be interested.
Carlos
cjensen(at)dts9000.com Guest
Posted: Thu Dec 14, 2006 11:01 am Post subject: Annunciator Panel Update? |
Carlos Trigo wrote...
Allan
I'd be interested.
Carlos
Think of it as a batch of bad food from Taco Bell. The food "gazintas"
and a few hours later, the food "gazoutas", though I suspect Alan was
referencing electrons and not e coli.
Chuck
rtitsworth
Posted: Thu Dec 14, 2006 1:25 pm Post subject: Annunciator Panel Update? |
Alan,
It would also be nice if the audio output could be manually muted (i.e.
until the input conditions was fixed at which point it would auto re-arm)
unless/until another input generated a second warning which would trigger a
subsequent audio signal. This is better than shutting off the audio as you
could forget to turn it back on/up.
It would also be nice to have the visual intensity dimmable (perhaps
external to the board) as it would be nice to have the annunciations "very"
bright during the day, but not blinding at night.
If it were LED based, it would be nice to be able to configure/switch the
LED colors (red, yellow, green, etc) during assembly.
Some thoughts on the test function/circuit...
1) It could be designed to only test the lights by suppling power directly
to the lights (bypassing the processor) - simple and software independent
but a rather weak "test".
2) It could be designed into the processor/code (ie. a manually activated
"all on" mode).
3) It could be designed to be a circuit "in-front" of the processor (i.e.
pulling all selected inputs high or low - thereby testing the
processor/coding as well) which is the most complex.
If option #2 (above) it might be nice if the "test" were automatically
performed at startup such that all the lights would initially come on
automatically and then hitting the test (or mute) button would extinguish
them. Thereafter, you would hold the momentary "test" button to test again.
Perhaps "holding" the mute button (>1 sec) would function as the test button
(saving a button).
Of course, following a "test" event, any prior illuminated warnings should
still be illuminated.
.02
Rick
Posted: Thu Dec 14, 2006 1:50 pm Post subject: Annunciator Panel Update? |
At 12:26 PM 12/14/2006 -0500, you wrote:
<snip>
| Quote: | Would there be much interest in the above? I'm most likely going to do the
Alan
Alan,
If I may be of assistance in helping configure I/O, designing
with DO-160 friendly techniques, helping with packaging, I'd
be pleased to help.
Bob . . .,
cberland(at)systems3.net Guest
Posted: Thu Dec 14, 2006 2:42 pm Post subject: Annunciator Panel Update? |
Aerotronics out of Billings Montana has something very similar to your
current discussions. May be worth contacting them.
http://www.aerotronics.com/
Craig Berland
| Quote: | Well, I'll throw my hat in the ring as at least a paper designer.
<snip>
| Quote: | the Honeywell type lights, which are LED based and has been what is
driving my desire for the above.
Alan
Alan,
be pleased to help.
Bob . . .,
Posted: Fri Dec 15, 2006 7:39 pm Post subject: Annunciator Panel Update? |
Ok, I've been doing a bit more thinking about this widget.... I'm really
trying to avoid designing the kitchen sink into it, and also I don't want
the complexity of multiple modules that all have to be interfaced.
I'm applying the KISS principle if at all possible.
I've nailed down a feature list a bit further. This is just major features
and is broken out by Hardware, and Hardware/Software. I've also included a
"future additions" section to keep those in perspective.
*If* we were to do a little virtual design here. Maybe we could nail down a
final V1 feature set, work up a prospective component list. From there we
could scratch out a schematic and then obviously, we could get some
prototypes done and build a couple and see how they work.
Single sided, or at the most double sided would be preferred. Concerns that
we'll have to watch for is RFI/EMI and how to keep that to a minimum.
Hardening this device should not be in the cards just yet, unless that can
be done easily.
At this point, we should work to a prototype.
Ok, so here's my feature list. Feel free to comment on it and if there are
questions, let me know. One note, this should be designed to work in both
metal and composite airplanes (that means we'll have to make sure grounding
is available and adequate.
Since the original round, I did think of a couple of nice to haves.
Rick's ideas muting and was a good one, that lead me to thing about
priorities and overrides. These can be handled in software.
Dimming was another good idea and the inclusion of some PWM for driving
led's etc. (we'll really have to watch EMI/RFI from those!)
This should be designed with PC tools that the average joe can afford if we
are to work in a collaborative environment with and around this.
So, what do ya think?
Hardware
a) 8 control inputs (can be active hi, active lo, or strobed)
b) 8 control outputs (can be active hi, active lo, or strobed)
c) microprocessor control
d) flash memory (perhaps processor embedded)
e) serial port output (output strings for external usage - e.g. Engine
monitor display, EFIS display, etc)
f) serial port input (command processor for configuration, s/w upload, etc)
g) 8 low level audio inputs
h) 3 low level audio outputs
i) audio tone generator
j) 9-32v DC power supply
Hardware/Software
a) test circuitry (lights, processor, logic, etc)
b) smart mute circuitry (mute until remedy, then re-arm, etc)
c) smart dimming circuitry (PWM for LEDs, ambient light sensor, for auto
adjust, etc)
d) event priorities for both control outputs and audio outputs (can be
linked or combined via configuration)
e) queued events with queue clearing logic (would need to integrate with
event priorities)
Future additions
a) recorded or recordable voice messages in place of tone generated sounds
b) ethernet or some other form of faster interface technology
Obviously, the number of inputs and outputs (gazintas and gazoutas) are
arbitrary, but 8 is a nice micro number
Alan - wanna be designer at large ;>
N1DeltaWhiskey(at)comcast Guest
Posted: Fri Dec 15, 2006 8:37 pm Post subject: Annunciator Panel Update? |
Alan,
Thanks for looking into this a bit further. I have been trying to locate a
row of enunciators to let me know when some defined parameter is out of
normal/desired ranges (row of idiot lights if you will, with some additional
features such as audio alert via the headphones. After reading over your
list, not sure how KISS your proposal is, but will leave that conversation
to those that might have a better idea of what they are talking about. I am
not sure what all the "features" do, or are supposed to do, or how I would
use them.
I am wondering, though, if dimming wouldn't be better performed by simple
light sensitive resistive circuitry (could be paralleled with user
adjustable) rather than PWM. I am assuming that the enunciator panel is for
the purpose of displaying fault/attention needed events and would not be lit
continuously (not sure what I would want continuously lit on such a panel).
If true, then it is doubtful that any meaningful power savings could be had
by going to the complication of PWM.
Just some thoughts. Hope you can produce a well engineered design/product
(e.g., competitive costs are factored in).
Doug Windhorn
Posted: Sat Dec 16, 2006 6:04 am Post subject: Annunciator Panel Update? |
At 10:36 PM 12/15/2006 -0500, you wrote:
Emissions from microcontrollers in this application is nil. Aperture
areas are so tiny as to make radiation insignificant. I/O artchitecures
for minimizing external influences (your COMM and Transponder
transmitters)
is also easy.
| Quote: | Hardening this device should not be in the cards just yet, unless that can
be done easily.
Single sided is virtually impossible with contemporary components
due to pin-out density and the dearth of thru-hole parts in small
footprints. Go to ExpressPCB.com for their free ECB layout software
and fast-turn, low-cost prototyping services. Their software will
support double sided, plated thru holes + up to two intermediate
planes that can be used for Vcc and Gnd.
| Quote: | At this point, we should work to a prototype.
Hardware
There are many fine processors offered. My personal choices
for new projects tend to check out the PIC series devices
first. LOTS of low cost development tools and a large contingent
of open source, open ideas users groups.
| Quote: | d) flash memory (perhaps processor embedded)
All of the Flash PICs can be programmed in place on the
product.
| Quote: | g) 8 low level audio inputs
| Quote: | Hardware/Software
adjust, etc)
event priorities)
years ago I used a lot of 3 x 5 recipe cards not unlike note
cards for a research project to organize a project like this.
One stack of cards for features (market driven)
One stack for design requirements
One stack for organizing program flow
Nowadays, one could use PowerPoint in the same manner with
the advantage of being able to share the document with others
via the 'net. In any case, the ability to massage individual details
and then rank them for orders of importance and or program flow
is important.
| Quote: | Future additions
This number is irrelevant right now . . . figure out which
features will be watched (market and flight-safety drives
this thinking) first. The size of the hardware is about the
last decision to be made before you start laying out the ECB.
| Quote: | Alan,
Yup, master caution warning systems often include a mute/stop-flashes
button that will cause the system to stop being a distraction . . . but
the tones/flashing comes back after some period of time . . . unless
the condition clears.
| Quote: | It would also be nice to have the visual intensity dimmable (perhaps
| Quote: | Some thoughts on the test function/circuit...
LED reliability is so high that press-to-test of lamps is
not very useful. Better to have a test feature in the processor
that does some nice hat-dance with the lights on demand. Pressing
buttons to "test" things should encompass as MUCH of the system's
hardware as possible. The act of simply testing light bulbs is not
very reassuring.
| Quote: | 2) It could be designed into the processor/code (ie. a manually activated
"all on" mode).
(saving a button).
Yup.
Get your PP "note cards" started. Your discussion is already
too large and detailed to let you put your arms around it with
threaded e-mails.
Posted: Sat Dec 16, 2006 9:27 am Post subject: Annunciator Panel Update? |
Doug,
Thanks for the comments. Yes, you are correct in your assumptions. One
note about PWM. I'm not hooked on it, as it's a huge EMI/RFI generator.
However LED's don't dim very well with just voltage reductions similar to
what a dimmer would do. They dim more easily with pulses. I'm also not
trying to clone dimmer functionality. When dimming makes sense to be
generated in software, specific to the output (idiot light functions), then
we'll look at it.
Thanks for the comments. Yes, I too haven't not found an annunciator panel
driver that meets my needs. Hence my interest in designing one .
Alan
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Sat Dec 16, 2006 9:26 pm Post subject: Annunciator Panel Update? |
In a message dated 12/15/2006 9:41:58 PM Central Standard Time, aadamson(at)highrf.com writes:
| Quote: | Ok, I've been doing a bit more thinking about this widget.... I'm really
the complexity of multiple modules that all have to be interfaced. |
Hi Alan- not sure how useful this might be, but here's what I did on my RV- works pretty good, but not very fancy- might give you a useful idea or two...
http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5126
There are 5 additional entries including the wiring diagram (available in ACAD) seen by clicking >>Next entry>> at top of pages. Fotos get bigger by clicking on them.
Thanks again to Expercraft for the great website resource!
From The PossumWorks in TN
Mark Phillips
_________________ From The PossumWorks... |
