door latched security system - Door Closer
Goto page 1, 2  Next
LarryRosen
PostPosted: Tue Dec 19, 2006 9:46 am    Post subject: door latched security system - Door Closer Reply with quote
Anyone have a solution to add a rear handle. How would it attach to the
fiberglass door? Would any reinforcement be necessary.
Here is a photo of the Lancair closer
<http://lrosen.nerv10.com/door%5Fhandle/>
and also what looks like one on Vic's RV-10
<http://lrosen.nerv10.com/Construct/SunNFun_2006/Vic%20RV10/slides/2006-04-07-SnF-13.html>
Larry Rosen
#356
Tim Olson wrote:
there is no rear handle.
Larry Rosen
#40356
N205EN (reserved)
<http>
dlm46007(at)cox.net
PostPosted: Tue Dec 19, 2006 1:13 pm    Post subject: door latched security system - Door Closer Reply with quote
I plan to add a rear handle and the easy way to do it is create a couple of
1/2" circular hardpoints in the doors then drill and tap. Also considering
adding another hand inserted pin for each door at the rear.
dav1111(at)cox.net
PostPosted: Wed Dec 20, 2006 3:41 am    Post subject: door latched security system - Door Closer Reply with quote
I put a rear handle on my doors so it was easier to pull in the rear part of the door before closing the door handle. I used rivnuts into the inside door frame and made a cloth handle with grommets in each end and screwed it on. Works great to make sure the rear part of the door can be pulled in tight enough to allow both the front and rear pins to slide into the frame.
I also as part of the pre-flight manually check both the pilots door and passenger door pins are fully seated by feel.
My pilots door DID NOT come off during one of my test flights, however it came open on takeoff and I was lucky enough to have made a long pull down loop strap that I was able to grab with my left hand while making sure I was still flying the airplane and hold the door down enough to keep it from coming completely off while I advised the tower I had a problem and needed to come back around for landing.
I made a somewhat normal close in downwind, base and final, landed and had to replace a bent hinge and do a little fiberglass work around the rear hinge which had pulled out.
It is imperative to manually check each pin, front and rear, on each door as part of the pre-departure check list.
The doors are in my opinion the weakest part of the Van's RV-10 design, but it is without a doubt the best airplane I have every flown in my 1500+ hours (owned 7, including an RV-6A).
Russ Daves
N710RV First Flight 7/28/06
Tim(at)MyRV10.com
PostPosted: Wed Dec 20, 2006 4:33 am    Post subject: door latched security system - Door Closer Reply with quote
I don't want to make you a bad guy Russ....but get a feel for this
with an honest question.
Were you very diligent about checking the pin before this happened,
or did this incident really set you in motion for doing it as
part of a good preflight check?
I'm just not yet installed on the warning kit, but I really don't
think I could trust myself to simply rely on a latch warning
kit any more than I could be trusted to check the pins. I heard
way back about a door coming off, so I never really had a period
where I wasn't checking the pins...but not everyone had heard these
stories before, so it may be different for them. I'm just
trying to get a feel for how it was for you.
Tim Olson - RV-10 N104CD - 180 hrs
Russ Daves
Tim(at)MyRV10.com
PS: That fabric handle sounds like the excellent way to go, fastened
with rivnuts. I'm going to see if later I can accomplish the same
thing easily.
Russ Daves
dlm46007(at)cox.net
PostPosted: Wed Dec 20, 2006 5:15 am    Post subject: door latched security system - Door Closer Reply with quote
One other thing I saw a small knob that could be threaded into a single hardpoint; just something to grab to pull the door fully in before using the door handle.
deutscht(at)rhwhotels.com
PostPosted: Wed Dec 20, 2006 6:37 am    Post subject: door latched security system - Door Closer Reply with quote
Russ, The best thing about your post below is that you first "flew the
plane". I have been in the flight training business for 34 years and
have personal knowledge of several fatalities because of lesser
incidences (lost fuel caps, open baggage doors, ect.) GOOD JOB!!!!! To
the rest of us NEVER, NEVER quit flying the plane! Even if a door does
come off.
Tom Deutsch, 40545
Waiting to paint
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill
Sent: Wednesday, December 20, 2006 7:14 AM
Subject: Re: door latched security system - Door Closer
the door handle.
PostPosted: Wed Dec 20, 2006 6:38 am    Post subject: door latched security system - Door Closer Reply with quote
Were are you guys positioning the rear handle so us with bad shoulders can reach around and grab it? Photos would help.
Tom Deutsch
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Russell Daves
Sent: Wednesday, December 20, 2006 5:40 AM
Russ Daves
www.aeroelectric.com
Rick S.
PostPosted: Wed Dec 20, 2006 7:07 am    Post subject: door latched security system - Door Closer Reply with quote
And he makes it part of his passenger brief, to include why it's part of his passenger brief so the passenger while trying to get a feel for the airplane is constantly looking at the door while flying with a wrist strap around his wrist to reel the door back in when it flys open!!! Wink
I was prepared though because I slept the night before at a Marriot Courtyard, not a Holiday Inn!!
Actually I slept at home, that comment was just for Tom!
Rick S.
40185
Rick S.
RV-10
40185
PostPosted: Wed Dec 20, 2006 7:32 am    Post subject: door latched security system - Door Closer Reply with quote
Ok now I'm really curious! How did you know of my involvement with
Marriott?
Tom Deutsch,
pitts_pilot(at)bellsouth.
PostPosted: Wed Dec 20, 2006 7:45 am    Post subject: door latched security system - Door Closer Reply with quote
I don't know if I have enough knowledge to comment here, so I'll ask a
few questions?
Why not add switches (sub-micro or reed) to the door to detect proper
closure and wire them to disable the starter relay if the door isn't
closed properly?
Is the closure problem related all the door pins or just one or two per
door? (how many pins are there???)
As for the 'dings' when the door is closed with the latch pins out .....
would a piece of stainless embedded in the frame minimize the damage??
Linn ...... getting closer to my own kit!
jesse(at)itecusa.org
PostPosted: Wed Dec 20, 2006 8:36 am    Post subject: door latched security system - Door Closer Reply with quote
Answers below.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
Cell: 352-427-0285
Fax: 815-377-3694
Rick S.
PostPosted: Wed Dec 20, 2006 8:47 am    Post subject: door latched security system - Door Closer Reply with quote
Linn,
If you can picture this...the gas strut is located on the aft portion of the door. With the latch handle on the front. The door has some flex to it so when you pull it down at the front, the front leads the way and stops at the cabin cover frame. Due to it being flexible and pressure from the strut, the aft portion of the door stops just short of completely sitting flush on the cabin cover. That's why the rear handle works well, it seats the aft part of the door to the cabin, then the latch pins can pass into the nylon blocks located fore and aft on the cabin door frame. If the door isn't fully seated the pin will extend outside the rear cabin block wearing away and dinging the exterior finish as the pin bounces and grinds at that point. As the airplane moves forward the door shifts further aft until the front pin disengages and allows the door to open.
I don't think this is a big deal. You just have to follow the pre-takeoff checklist and reach around and feel for the pins sticking through the framework. It worked just fine flying with Russ and adding the lights add another safety measure.
Rick S.
40185
Rick S.
RV-10
40185
indigoonlatigo(at)msn.com
PostPosted: Wed Dec 20, 2006 9:16 am    Post subject: door latched security system - Door Closer Reply with quote
I thought Tom was Motel 6, Tom Bodett that is...oh, wrong guy.
Subject: RE: door latched security system - Door Closer
Date: Wed, 20 Dec 2006 07:07:33 -0800 (GMT-08:00)
Rick S.
40185
PostPosted: Wed Dec 20, 2006 9:30 am    Post subject: door latched security system - Door Closer Reply with quote
From what it sounds like, a rotational handle at the middle of the door,
down at the bottom edge, which has a taperred engagement piece, which pulls
the bottom in while the handle is rotated, then at the same time causes a
shaft from the rotating handle to be pushed forward to engage the front pin
hole and another shaft going back to engage the rear hole would work.
I would work on it if I had time, but since my builder number is 409 and I
am QBing it and still don't have the cabin top on...I don't seem to be doing
too well on pace. how about you guys who are finished...any desire to design
improvements when you are not burning fuel?
I notice Tom's post, #545 waiting on paint. Damm. light speed you must build
to be where you are.
[quote]From: "Jesse Saint" <jesse(at)itecusa.org>
Date: Wed, 20 Dec 2006 11:35:41 -0500
Answers below.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
Cell: 352-427-0285
Fax: 815-377-3694
PostPosted: Wed Dec 20, 2006 12:33 pm    Post subject: door latched security system - Door Closer Reply with quote
I agree Tom. When the prop departed my Pitts I went through the '"Rule number one, fly the airplane. Rule number two ...... see rule number one." littany ...... and I really don't know if I said it out loud or just in my mind. The outcome was a non-event .... the Pitts landed uneventfully on A1A and the prop landed uneventfully in the ocean.
Linn
Tom Deutsch wrote:
[quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> st1\:*{behavior:url(#default#ieooui) } <![endif]--> <![endif]--> <![endif]-->
Russ, The best thing about your post below is that you first “flew the plane”. I have been in the flight training business for 34 years and have personal knowledge of several fatalities because of lesser incidences (lost fuel caps, open baggage doors, ect.) GOOD JOB!!!!! To the rest of us NEVER, NEVER quit flying the plane! Even if a door does come off.
Tom Deutsch, 40545
Waiting to paint
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of David McNeill
john.erickson(at)cox.net
PostPosted: Wed Dec 20, 2006 6:51 pm    Post subject: door latched security system - Door Closer Reply with quote
I absolutely do not want to hear any more complaining from folks with
builder numbers in the 400's and up about going to slow. It will damage my
very fragile ego!! Smile
John
#40208 Wings
wvu(at)ameritel.net
PostPosted: Wed Dec 20, 2006 7:19 pm    Post subject: door latched security system - Door Closer Reply with quote
There are two pins per door, one fwd and one aft which engage the holes in
the bulkheads to hold the doors shut. The closure problem is related to
the rear pins because the door handles are positioned near the fwd edge of
the doors, thus not enough pull power on the aft edge. Van's idiot lights
are sufficient to ensure proper closure before engine start. However, IMHO
the door latch mechanism needs to be redesign. I feel that sooner or later
the holes in the bulkheads are going to be enlarged from normal usage and
eventually lose their pressure on the door seals. Those white blocks are
offering zero support IMHO being held on my two screws.
One other similar design issue. I feel that the front seat adjustment
handles can use some more thoughts. They are too close to the side panels
to operate with one hand, especially if you're going to have covers on the
side panels. I had to use my two index fingers to pull the handle up to
slide the seat when flying with Alex last week. Also, it would be nice if
you can slide the seats off without having to losen the bolts holding the
handles on first.
Anh
few questions?
closed properly?
Rick S.
PostPosted: Wed Dec 20, 2006 8:37 pm    Post subject: door latched security system - Door Closer Reply with quote
Hey John!!
Back in the Viper??
And at builder #40185...no complaints from the 200's either, but as it comes together....August for a guess, I offer the quote..."Good things come to those who wait"
There is not a "hurried" or "anxious" bone in my body to finish, and given the opportunity to brag...the finished product will show that. Smile
As it get close John I'll let you know so you can get your leave scheduled;)
Rick S.
40185
Rick S.
RV-10
40185
dav1111(at)cox.net
PostPosted: Thu Dec 21, 2006 2:39 am    Post subject: door latched security system - Door Closer Reply with quote
I don't mind owning up, I failed to manually check the pins and this was my wake up call. You can believe that it was the last time that it failed to happen.
Russ
Goto page 1, 2  Next
Page 1 of 2
