Posted: Thu Dec 21, 2006 10:22 am Post subject: Baggage door |
Chris,
I have worked on the door all the way up to riviting it. I have crimped the
inner flanges of the door frame in several areas because the upper and lower
skin edge was slightly bowed out in the middle. Now I believe I have crimped
the flanges about as much as I would want to and the only thing still out of
alignment is the middle of the top frame, which leaves the skin of the door
in that area about 1/8" proud. The corners are all in alignment with the
fuselage, everything looks good except this one bowed out spot. I certainly
can build up the fuselage at the intersection of the cabin top and the metal
fuse skin, but this will not be the true shape that the fuselage should
ideally have.
Any more suggestions would be welcomed, before I get the rivets out.
Not that this will help my situation, but I have also thought about placing
a fiberglass/kevlar super thin sheet which could laminate over the entire
door to seal off the gap on the top/bottom and back. The hinge area will
not allow coverage in that area. My mod would give better aerodynamics than
the 3/32 to 1/8 gap around the perimeter(That is provided I can sinch it
down tight to the skin)
JOhn G.
Deems Davis
Posted: Thu Dec 21, 2006 10:52 am Post subject: Baggage door |
John, I found that the hand seamer was a great tool to 'adjust' the
baggage door to match the contour of the fuse. just small adjustments
seemed to bring everything in line for me.
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
John Gonzalez wrote:
Chris,
crimped the inner flanges of the door frame in several areas because
the upper and lower skin edge was slightly bowed out in the middle.
Now I believe I have crimped the flanges about as much as I would want
to and the only thing still out of alignment is the middle of the top
frame, which leaves the skin of the door in that area about 1/8"
proud. The corners are all in alignment with the fuselage, everything
looks good except this one bowed out spot. I certainly can build up
the fuselage at the intersection of the cabin top and the metal fuse
ideally have.
placing a fiberglass/kevlar super thin sheet which could laminate over
the entire door to seal off the gap on the top/bottom and back. The
hinge area will not allow coverage in that area. My mod would give
better aerodynamics than the 3/32 to 1/8 gap around the perimeter(That
is provided I can sinch it down tight to the skin)
JOhn G.
Posted: Thu Dec 21, 2006 11:11 am Post subject: Baggage door |
Smack it with a hammer!
Just kidding. I haven't been back to that section yet, I just moved on
for awhile while waiting for new door pieces, but it sounds like you've
got it just about as good as you can get it. seriously, some have
reported that a bit of "man-handling" can improve the fit, but I'd be
leery of that, cause you might just put the corners out of alignment
while trying to improve the bow in the middle, or you might put a crease
somewhere where you wish you didn't.
Just a thought in the vein of the pursuit of perfection... someone
posted somewhere that you really don't notice the slight imperfections
when you're blasting along at 170 kts, or when you don't have a
particular section under a microscope (as you do when you're
constructing that area). It's really easy for me to get wound up in
utter perfection, but sometimes, it really is good enough. personally,
I'm not building a show winner. I think a first-time builder like
myself might not have the skills to do so. What I AM trying to do is
build it better than whatever airplane I rent to go buzzing around, and
I think I'm doing that, both from a safety, and from an aesthetic
standpoint. When I'm bummed that something isn't exactly perfect, I
just take extra time doing my preflight of a rental 172, and I start to
feel REALLY good about my building practices, and about the standard
I've set for myself.
cj
#40410
fuse
www.perfectlygoodairplane.net
Posted: Thu Dec 21, 2006 11:41 am Post subject: Baggage door |
Thanks Deems
Sorry, but haven't used that tool for some time, it is the plyer like tool
with the flat plate on each side. Seems like I could only change the angle
of the frame flange with that tool and I think it is the entire piece that
needs to be bent in slightly. Perhaps making some relief cuts in the frame
(At the intersection of the flange and the aluminum which isn't joined to
the skin or to the close out panel )with a dremel disk and then bending the
material between the cuts would cause the flange to pull in.
close out panel
_Flange_____
_
_
cut here and crimp _
-----------> ___________
flange
outside skin
This should pull the outer fange in in the bulged out area. I only need a
four inch area.
JOhn
| Quote: | From: Deems Davis <deemsdavis(at)cox.net>
Subject: Re: Baggage door
Date: Thu, 21 Dec 2006 11:51:51 -0700
John, I found that the hand seamer was a great tool to 'adjust' the baggage
door to match the contour of the fuse. just small adjustments seemed to
Deems Davis # 406
>Chris,
>the inner flanges of the door frame in several areas because the upper and
>lower skin edge was slightly bowed out in the middle. Now I believe I have
>crimped the flanges about as much as I would want to and the only thing
>still out of alignment is the middle of the top frame, which leaves the
>skin of the door in that area about 1/8" proud. The corners are all in
>alignment with the fuselage, everything looks good except this one bowed
>out spot. I certainly can build up the fuselage at the intersection of
>the cabin top and the metal fuse skin, but this will not be the true shape
>that the fuselage should ideally have.
>placing a fiberglass/kevlar super thin sheet which could laminate over the
>entire door to seal off the gap on the top/bottom and back. The hinge
>area will not allow coverage in that area. My mod would give better
>aerodynamics than the 3/32 to 1/8 gap around the perimeter(That is
>JOhn G.
Deems Davis
Posted: Thu Dec 21, 2006 1:35 pm Post subject: Baggage door |
I was able to physically apply some torque to my door, using just hands,
it didn't take very much and it got pretty close. the remainder I was
able to use the hand seamer, and make small adjustments, no need to cut
anything.
Deems Davis # 406
Thanks Deems
tool with the flat plate on each side. Seems like I could only change
the angle of the frame flange with that tool and I think it is the
entire piece that needs to be bent in slightly. Perhaps making some
relief cuts in the frame (At the intersection of the flange and the
aluminum which isn't joined to the skin or to the close out panel
)with a dremel disk and then bending the material between the cuts
close out panel
_Flange_____
_
_
flange
outside skin
need a four inch area.
JOhn
> Deems Davis # 406
>> <indigoonlatigo(at)msn.com>
>> Chris,
>> want to and the only thing still out of alignment is the middle of
>> the top frame, which leaves the skin of the door in that area about
>> 1/8" proud. The corners are all in alignment with the fuselage,
>> the metal fuse skin, but this will not be the true shape that the
>> over the entire door to seal off the gap on the top/bottom and
>> back. The hinge area will not allow coverage in that area. My mod
>> would give better aerodynamics than the 3/32 to 1/8 gap around the
>> perimeter(That is provided I can sinch it down tight to the skin)
>> JOhn G.
owl40188(at)yahoo.com Guest
Posted: Thu Dec 21, 2006 1:49 pm Post subject: Baggage door |
John,
Your door sounds similar to the way mine came out. I slowly worked it with my hands and the fit improved drastically. I haven't put the seal on but without it the fit looks pretty good to me. I am going to wait until I have the canopy on to install the seal and work it a bit more.
Good luck with it.
Niko
40188
Rick S.
Posted: Thu Dec 21, 2006 7:19 pm Post subject: Baggage door |
Guys,
Massage, bend, caress and shoot for this.....and use the hand seamer....I did all of that and it's N...I...C...E.
When asked by my fellow builder how I did it?? ....Why workmanship my lad...workmanship.
Naaaahh...metal is your friend once you figure out how to work it (think girlfriend/wife) with total respect.
Rick S.
40185
360.76 KB |
187 Time(s) |
_________________ Rick S.
RV-10
40185 |
Rick S.
Posted: Fri Dec 22, 2006 6:32 am Post subject: Baggage door |
Really give the hand seamer some thought. I had another builder ask me how I made mine fit so well. It was all minor work with a hands seamer. Take your time and don't bend the edges but use the tool to slightly "bow" them, don't close the jaws tightly on the skin but leave them open a bit so the skin can sort of roll and move as you work it, but just do a little at a time. Tape on the jaws help to keep the skin from slipping off.
Rick S.
40185
RV-10
40185 |
Posted: Fri Dec 22, 2006 7:35 am Post subject: Baggage door |
Thanks for the suggestions.
The problem I am having understanding the use of the seemer is that the
entire door skin is flat, any shape that the skin takes should be a by
product of the frame's shape which the skin is tied to. I really don't want
to touch the skin and bend it at the edges because it will be very obvious
where the break from straightness/flatness occurs. It seems that the slight
bow in the top part of the frame is what needs to be slightly removed,
perhaps with bend between two hands(Easy does it).
I am trying to digest what you are saying, hoping what I am saying is making
sense aswell.
JOhn G.
| Quote: | From: Rick <ricksked(at)earthlink.net>
Subject: RE: Baggage door
Date: Thu, 21 Dec 2006 14:30:07 -0500 (EST)
Rick S.
40185
rickgray(at)roadrunner.co Guest
Posted: Fri Dec 22, 2006 12:03 pm Post subject: Baggage door |
John,
You've received at least a dozen replies now. If it's that bad then make a new door.
It's that simple... move on :^).
Yes...I'm hitting the delete key.
Rick in Ohio at the Buffalo Farm
do NOT archive
Posted: Fri Dec 22, 2006 4:48 pm Post subject: Baggage door |
Rick,
you are actually confused with some of the other posts.
There have only been 5 repleys to my questions regarding the baggage door.
As for responses to the TURKEY VULTURE there are 17.
11 regarding IFR equipment
and 8 regarding the door latch security system.
Now that I am finished counting, The door really isn't bad at all, just
thought that some of you might have some unique ideas worth sharing that
might bring it from a 95% to a 100%. Making a new door would bring me to the
exact spot I am in right now, with no improvement...there is nothing
finallized, just want the extra 5% of result and learning before it is
finished.
JOhn G
[quote]From: "Rick Gray" <rickgray(at)roadrunner.com>
Date: Fri, 22 Dec 2006 12:19:02 -0500
John,
new door.
do NOT archive
Posted: Fri Dec 22, 2006 5:33 pm Post subject: Baggage door |
I'm ecstatic to receive all the posts, cause I AM makin a new door, and
I don't want to screw this one up!
cj
#40410
fuse
Tim(at)MyRV10.com Guest
Posted: Fri Dec 22, 2006 5:59 pm Post subject: Baggage door |
Sorry John, I'd reply about the door, but mine is only a 95% door,
so it wouldn't help you much. Does this count as a door reply for
you? Let's get those numbers up!
Rick,
the exact spot I am in right now, with no improvement...there is nothing
finished.
JOhn G
> To: <rv10-list(at)matronics.com>
> John,
> make a new door.
> do NOT archive
Rick S.
Posted: Fri Dec 22, 2006 6:48 pm Post subject: Baggage door |
Hey Rick....
Holidays got you stressing!!!!
Hit delete and move on dude.
It is a very visible part of the aircraft and if we can help John get it lined up then so be it...
POST AWAY...not like that crap about Lycoming vs. Eggenfellner, this is RV-10 structure!
We don't need attitude that comes from the back of your Buffalo's
With a smile, of course...lighten up.
Rick S.
40185
RV-10
40185 |
LloydDR(at)wernerco.com Guest
Posted: Fri Dec 22, 2006 7:37 pm Post subject: Baggage door |
You gotta be easy on him, he has been breathing cabin top dust for
several weeks now, and the resin fumes are getting to him!
Dan
N289DT RV10 E
PS Lyco or E-Sub's are not crap.... At least not cheap crap that is
Posted: Sat Dec 23, 2006 12:02 pm Post subject: Baggage door |
No Sir...Holidays are my FAVORITE time of year :^)!!
You might want to reread my reply....I 'thought' I was helping and even included a little smiley to make sure my post wasn't taken out of context......my sincere apology if it was.
http://rv6rick.tripod.com/ohiovalleyrvators/
Rick S.
Posted: Sat Dec 23, 2006 2:01 pm Post subject: Baggage door |
Lol....yeah I get it.
The engine remark was aimed at the actual debate between the two products, not the product, which I have shelled out my $43K for as well. Just a hint...it doesn't have a PSRU so...... :O
I totally understand the intent of the post, and didn't plan to become some sort of puesdo moderator. I know how frustrating trying to get something just right and when there are 20 options the more chance there is of finding one that works for you.
Happy celebrations to all regardless of your religious preferences....it's a birthday celebration for our house!!
Rick S.
40185
RV-10
40185 |
Posted: Sat Dec 23, 2006 4:49 pm Post subject: Baggage door |
Oh nooo here it goes again! $43k vs $29K? What do you get for the extra
money? "GRIN" That should fan the spark.
Playing PS3 in buildus interruptus, but it is 82 degrees outside!
Dan
N289DT RV10E
Rick S.
Posted: Sat Dec 23, 2006 7:38 pm Post subject: Baggage door |
Chrome valve covers and nice paint
lol...82????? it's not even 82 in Vegas right now!!!
Barrett's is my engine builder, and that means nothing against anyone else...they spent the time talking to me at OSH, explained everything, have a great reputation and Rhonda and the gang monitor the list. Monty Barrett's reputation and knowledge was enough for me along with all the good things all their customers had to say..and I did check..
Ric kS.
40185
RV-10
40185 |
Posted: Sun Dec 24, 2006 8:00 am Post subject: Baggage door |
I too agree that Barrett's is the way to go for a Lycoming. I spent
allot of time with them on the phone trying to make the decision, and
they were really good at helping me understand the different models and
options. If I had gone with a Lycoming, I would have chosen them to
build mine.
Dan
