dave
Michel
Posted: Thu Dec 21, 2006 1:14 pm Post subject: Older Kitfox cruise speeds |
On Dec 20, 2006, at 2:57 PM, Paul Seehafer wrote:
| Quote: | Sure, the newer Kitfox (Riblett) airfoil helps to make the newer
Kitfoxes cruise faster, but even if you were to put a new Riblett wing
on an older Kitfox, my guess is you wouldn't see a lot of cruise speed
increase, because there is just too much positive wing incidence
causing a lot of drag.
Hello Paul,
Since I read your email, yesterday, I have been thinking about this and
I just can't figure out how it works. From the X-Plane flight
simulator, I am used to make digital models. I don't know how it is
done in real life but I guess it is done in relation to a reference
line. Let's say, a line going from the prop hub to the end of the
fuselage. From that, various airfoils can be built, each with a
different angle of attack. I think angle of attack (AoA) is usually
used as the angle to that reference line, where angle of incidence is
the actual angle made by the apparent wind and the airfoil.
If we look at the AoA, we see that, as it increases, the coefficient of
lift and the coefficient of drag increase too. As speed increases and
lift increases to the square of the speed, one has to push the stick to
keep the plane at level flight.
Now, if the actual attachment of the wings' root to the fuselage is
different from one model to another, it means that, for the same speed,
one plane will fly with a slightly greater nose-down attitude. But how
does that influences the maximum speed you can achieve for a given
engine horse power? My understanding is that an airfoil has a constant
lift/drag ration for a given AoA. Did I miss something?
Cheers,
Michel
akflyer Guest
Posted: Thu Dec 21, 2006 1:36 pm Post subject: Re: Older Kitfox cruise speeds |
If the tail has to come up higher in flight to get the wing level, then you have more drag. THe fuse is not "straight" in the airflow, the horizontal stab is a big brake back there, the struts are now at a nose down attidute which means they are not straight with the relative wind etc.. It all adds up to a slower plane.
Michel
Posted: Thu Dec 21, 2006 2:43 pm Post subject: Older Kitfox cruise speeds |
On Dec 21, 2006, at 10:36 PM, akflyer wrote:
| Quote: | If the tail has to come up higher in flight to get the wing level,
Thank you for your answer, Leni. What you are saying, basically, is
that a higher AoA attachment point of the wings won't increase induce
drag but parasite drag, right? It makes sense. However, if I may ask:
You wrote: The horizontal stab is a big brake.
Yes, it is. But if say, you decide to install a stronger engine that
gives you more speed, can't you adjust the angle of your horizontal
stab accordingly?
This is only a theoretical question because while my model 3 with its
new Jabiru can easily exceed Vne, only looking at the thin lexan
windscreen makes me throttle back long before that!
Cheers,
Michel
henrysfork1(at)msn.com Guest
Posted: Thu Dec 21, 2006 4:23 pm Post subject: Older Kitfox cruise speeds |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Just a quick note for those who may be interested. A guy from Rexburg, Idaho just crashed a P-51 on the interchange closing both north and south lanes of traffic. All that is left is two short pieces of the wing still connected to fuselage with the gear down and staring straight in the air. No tail section or engine/prop anywhere to be seen. Its strung around pretty good but the guy walked away from it. The word is they just completed an engine install.
Its always nice to see someone walk away from one of these even if is not a Kitfox.
Dee Young
Model II
akflyer Guest
Posted: Thu Dec 21, 2006 4:25 pm Post subject: Re: Older Kitfox cruise speeds |
Sure you could, but wouldnt it be better to drop the leading edge of the wing back down so you were not looking down when in cruise ???
Then you get into the adding more ponies, stretching it out, cruising faster, costing more, taking alot longer to get off the ground, and get away from the original spirit of the Fox.....
Why not just go buy a 180 and get it over with lol...
dosmythe(at)cox.net Guest
Posted: Thu Dec 21, 2006 4:49 pm Post subject: Older Kitfox cruise speeds |
Sure you could WHAT??? No reference to a previous post. Where is this
thread going. I'm lost
Don Smythe
Posted: Thu Dec 21, 2006 4:52 pm Post subject: Older Kitfox cruise speeds |
Hmmm, Older Kitfox cruise speeds and a P-51 crashed. Sounds interesting. Where is this thread going?
Don Smythe<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]-->
[quote] Just a quick note for those who may be interested. A guy from Rexburg, Idaho just crashed a P-51 on the interchange closing both
akflyer Guest
Posted: Thu Dec 21, 2006 5:50 pm Post subject: Re: Older Kitfox cruise speeds |
Sure you could....... He asked about changing the AOI on the horizontal stab. I replied that Sure you could, but it would be easier (or better) to lower the AOI on the wing ie. drop the leading edge of the wing....Either way you would have to do some welding right ?????
As all of this is hypothetical, the thread is really going nowhere quick.
Must have put a bigger engine in the thread huh...
I forgot where I was for a moment. I forgot that this was a strictly business only site...
nobeerchugforgettingofftopic
roncarolnikko(at)hotmail. Guest
Posted: Thu Dec 21, 2006 6:56 pm Post subject: Older Kitfox cruise speeds |
Hi Michel I think the undercamber in itself creates drag. This as well as
the lift on top from "Bernoulli's principle" or whatever make the wing
prefer to lift even at 0 AOA. The Riblett Airfoil has no undercamber, is
slippery, and glides forever. Sorry to but in, but I'm stoked on how fast
the Speedster really is. Ron NB Ore
ps Merry Christmas
| Quote: | From: Michel Verheughe <michel(at)online.no>
Subject: Re: Older Kitfox cruise speeds
Date: Thu, 21 Dec 2006 22:14:13 +0100
>Sure, the newer Kitfox (Riblett) airfoil helps to make the newer Kitfoxes
>cruise faster, but even if you were to put a new Riblett wing on an older
>Kitfox, my guess is you wouldn't see a lot of cruise speed increase,
>because there is just too much positive wing incidence causing a lot of
>drag.
Hello Paul,
Since I read your email, yesterday, I have been thinking about this and I
just can't figure out how it works. From the X-Plane flight simulator, I am
used to make digital models. I don't know how it is done in real life but I
guess it is done in relation to a reference line. Let's say, a line going
from the prop hub to the end of the fuselage. From that, various airfoils
can be built, each with a different angle of attack. I think angle of
attack (AoA) is usually used as the angle to that reference line, where
angle of incidence is the actual angle made by the apparent wind and the
airfoil.
lift and the coefficient of drag increase too. As speed increases and lift
increases to the square of the speed, one has to push the stick to keep the
different from one model to another, it means that, for the same speed, one
plane will fly with a slightly greater nose-down attitude. But how does
that influences the maximum speed you can achieve for a given engine horse
power? My understanding is that an airfoil has a constant lift/drag ration
Cheers,
Michel
Find sales, coupons, and free shipping, all in one place! MSN Shopping
Sales & Deals
http://shopping.msn.com/content/shp/?ctid=198,ptnrid=176,ptnrdata 0639
Michel
Posted: Sat Dec 23, 2006 4:22 am Post subject: Older Kitfox cruise speeds |
Hello Leni and Ron,
On Dec 22, 2006, at 3:55 AM, ron schick wrote:
| Quote: | Hi Michel I think the undercamber in itself creates drag.
Of course! But maybe I misunderstood what was in that scanned article.
I understood that if Denney had used a lesser AoA at the fixation of
the wing's root to the fuselage, the models 1, 2 and 3 would fly
faster. And that is what I don't understand. But if I misread then ...
I understand!
Happy holidays,
Michel
av8rps(at)tznet.com Guest
Posted: Sat Dec 23, 2006 5:28 am Post subject: Older Kitfox cruise speeds |
Michel,
I'm not sure about your X-plane flight simulator, but if you check out books
on the subject of aerodynamics and aircraft design it might clear this up
for you better than I can. But I do think Leni did a pretty good job of
explaining it. By getting the wing incidence out of wack it makes the tail
have to compensate, and adds further drag.
This whole scenario was played out somewhat years ago when Piper created
their PA-12 Supercruiser. One of the things they did to make their new Fat
supercub airframe fly faster was to reduce the amount of positive wing
incidence. And it worked. Although they did lose a bit of the Supercub
STOL performance. But not much. Today with the higher horsepower
conversions done to both the PA-12 Supercruiser as well as the Supercub, you
can hardly notice any STOL loss on the SuperCruiser. Somewhat similar to
what we've experienced with the Kitfoxes.
Paul Seehafer
Michel
Posted: Sat Dec 23, 2006 1:19 pm Post subject: Older Kitfox cruise speeds |
On Dec 23, 2006, at 3:05 AM, Paul Seehafer wrote:
| Quote: | By getting the wing incidence out of wack it makes the tail have to
Yes, Paul, I understand that and while I will always take a simulator
with a grain of salt, mine does a pretty good job at modelling things
like that. I am always amazed to see how changing one degree in the AoA
of the horizontal stab, or moving the CoG a couple of inches, changes
entirely the flight model, stall, etc.
I am not contesting the Kitfox article, nor the Piper engineers, I
merely try to understand how this works because if I learn something
today, then it is a good day.
Here is an hypothesis: The day Mr Denney sat and drew the first Kitfox,
as he made the line that would define the AoA of the wing, a fly came
to rest on his pencil. In a quantum of time, two different universes
came to exist: One where he drew the intended line, as it as now; and
another one where he was distracted by the fly and his ruler slid
slightly down thus making a line with a lesser AoA.
In both universes, now moving in their own individual existence, it
resulted in a constructed plane. In the first one, Mr Denney - after
the first test flight - realises that to keep a proper balance, the
horizontal stab has to be modified to keep the nose slightly up. In
the other universe, he decides - for the same reason - that it has to
be modified to keep the nose slightly down.
The question then is: Will the Kitfox in one universe - with the same
engine, etc. - fly slower than the Kitfox in the other universe?
Cheers,
Michel
akflyer Guest
Posted: Sat Dec 23, 2006 3:12 pm Post subject: Re: Older Kitfox cruise speeds |
has someone been hitting the kitfox holiday eggnog a little early????
or are they watching kitfox Xfiles????
eskflyer(at)lvcisp.com Guest
Posted: Sat Dec 23, 2006 4:26 pm Post subject: Older Kitfox cruise speeds |
I can answer this one .
In one universe the air is more dense than the other so both Kitfoxes are
flying at the same speed .
Cheers
Merry Christmas everyone
IN the holiday spirit uhhh holliday spirits in me lol
John Perry
DO NOT ARCHIVE
Michel
Posted: Wed Dec 27, 2006 5:24 am Post subject: Older Kitfox cruise speeds |
| Quote: | From: kurt schrader [smokey_bear_40220(at)yahoo.com]
When aircraft are designed, they are usually initially
layed out to be most efficient at a given cruise speed
and weight.
Thank you for this comprehensive explanation of all the challenges an aircraft designer meets, Kurt. It is, indeed, always a compromise. Maybe I misunderstood the article that Paul published for us on the list. I think I understood that if the models 1 to 3 were designed with a lesser wing AoA, the would fly faster but loose STOL capacity. I am sorry, I still don't understand.
Yes, the shape of every object in the airflow will contribute to more or less parasite drag. Yes it could be that the fuselage, being at a more nose-down attitude when the wings have a greater AoA, has a greater drag. But the author of the article doesn't know that, does he?
Likewise, I don't understand how a greater wing AoA increases STOL capacity. I have been told that there isn't such a thing as a stall speed, only a stall AoA. STOL means that you can land slower, right? Will the wing AoA make it stall at a greater AoA? I don't understand. I will make the fuselage more nose-up when stalling on landing. It can make your 3-points landing with a tailwheel touching first. But so can gap-sealing elevators, your CoG, your wheels' diameter, etc.
I am sorry, I don't get it and if I am the only one on the list not to get it so let it be. Maybe I am slow and in a few months I'll wake up in the middle of the night and shout: EUREKA!
Cheers,
Michel
mscotter
Joined: 15 Jan 2006 Posts: 49 Location: Winston-Salem, NC
Posted: Wed Dec 27, 2006 6:23 am Post subject: Older Kitfox cruise speeds |
Michel, I'll chime in for a moment and share my understanding of this, which
I **believe** to be correct from what I've read.
I think what was said was that the wing incidence was increased to give
better visibility over the nose. In other words, the wing incidence was
increased so that at any given time the fuselage would be flying at a lower
angle of incidence, hence allowing the nose to be lower and us to see over
it better.
As for wing Angle of Attack/Incidence and its relation to STOL capability, I
think what is being said is that since the earlier models had the wing
mounted at a greater angle of incidence on the fuselage then those aircraft
would, upon taking off, be at a greater angle of attack sooner (with respect
to the later model kitfox) and thus be developing lift and flying sooner.
Personally, I'd bet that you'd be hard pressed to measure the difference in
two otherwise comparably equipped aircraft, as these airplanes get off the
ground so quick already. But I digress...
Mark Scott
Elkton, MD USA
Merry Christmas to all
_________________ Mark Scott
Winston-Salem, NC |
Michel
Posted: Wed Dec 27, 2006 12:18 pm Post subject: Older Kitfox cruise speeds |
On Dec 27, 2006, at 3:23 PM, mscotter wrote:
| Quote: | <SNIP> hence allowing the nose to be lower and us to see over
it better.
Aha! Now we are getting closer, Mark! I am sorry, I didn't read
entirely the article Paul provided, mostly what he underlined in red. I
have then missed the point in the high AoA.
| Quote: | <SNIP> and thus be developing lift and flying sooner.
Good Lord! Then I have to revise my take off technique. I fly from a
long asphalt runway so STOL is not very actual. But, at occasions, I
need to take off from short grass runways. Now, I was instructed to
take off by pushing the stick full forward, if anything, to see sooner
over the cowling. Once I was with a passenger, on a hot summer day, on
a short grass field and I pulled the stick back a bit too soon, the
plane wasn't ready to take off. We did a few hop and I didn't like it
(nor my passenger, for the matter!
After that, I tried to improve the technique which is: Full throttle
and stick full forward. As soon as the plane is level, I wait for Vso
then pull the flaps and keep the plane a few inches over the ground
until speed is enough to go ballistic toward the sky, after pushing in
the flaps.
Is this wrong? Because if the high AoA is to help STOL, then I should
take off with the tailwheel still on the ground, right? I thought it
was important, on short fields, to be horizontal as soon as possible,
to have as little as possible induced drag and pick up speed fast.
Cheers,
Michel
Lynn Matteson
Posted: Wed Dec 27, 2006 5:39 pm Post subject: Older Kitfox cruise speeds |
You've been flying a lot longer than I have, Michel, but my takeoff
technique is different. I was instructed to hold neutral elevator,
full power, then at about 30mph, forward stick only until tail
raised, then hold neutral elevator until liftoff, or pull back
slightly to induce liftoff. Then either forward for ground effects
(shortfield) and quicker achievement of Vy, or back for Vx, but only
when Vy speed has been achieved. Of course my cowl is the Skyfox
cowl, and easier to see over (even for this 5' 6" pilot), so I don't
have to...or WANT to...push that stick forward too far, let alone
full forward. My soft field technique is to hold stick full back,
firewall the throttle, and hold stick back until it lifts off by
itself, then forward until Vy is achieved, then use stick to hold
Vy. As my instructor says, "as soon as you leave the ground, your
soft field is over."
Lynn
On Dec 27, 2006, at 3:18 PM, Michel Verheughe wrote:
> it better.
red. I have then missed the point in the high AoA.
a long asphalt runway so STOL is not very actual. But, at
occasions, I need to take off from short grass runways. Now, I was
instructed to take off by pushing the stick full forward, if
anything, to see sooner over the cowling. Once I was with a
passenger, on a hot summer day, on a short grass field and I pulled
the stick back a bit too soon, the plane wasn't ready to take off.
We did a few hop and I didn't like it (nor my passenger, for the
matter!
throttle and stick full forward. As soon as the plane is level, I
wait for Vso then pull the flaps and keep the plane a few inches
over the ground until speed is enough to go ballistic toward the
sky, after pushing in the flaps.
should take off with the tailwheel still on the ground, right? I
thought it was important, on short fields, to be horizontal as soon
as possible, to have as little as possible induced drag and pick up
speed fast.
Cheers,
Michel
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
