vg's
Goto page Previous  1, 2, 3, 4
ronlee
PostPosted: Tue Dec 26, 2006 12:47 pm    Post subject: Re: vg's Reply with quote
I now have over three hours flying time and several landings on my 701 with the slats removed and VG's on. I have over 75 hours in/on this plane. At this time I see no reason to ever put the slats back on. I will leave the mounting tabs on, as some day when I sell the new owner may want to try the slats. I have lots of them, (56 VG's) on each wing They are placed in the CCI pattern, which is, 2 close together then about a 5" inch gap and so on. The leading edge of the VG's is ten percent back from the leading edge of the wing chord, which includes the flaperons, but not the slats. My plane is ever so much easier to land. It sure feels like it climbs better. No stall just the mush as before. Trims are identical as with the slats on. If I didn't look out the window in flight I would never know the slats were missing. I think I have more VG's on then I would need though, as a result I may be getting some drag as I only gained 4-5 miles per hour at the same RPM. One thing I did lose is the uniqueness of the plane. Those slats are a real attention getter and conversation item. Could it be that's why Zenith retains them? Of course if a designer were to put VG's on his plane it would look like he/she was trying to correct something!
Ron Lee
Tucson, Arizona
billbutlergps(at)aim.com
PostPosted: Tue Dec 26, 2006 1:15 pm    Post subject: vg's Reply with quote
Ron,
If the new owner doesn't want the forward slats give me an email and I will.
robert.eli(at)adelphia.ne
Ron,
Thanks for your report on removing the slats. It is interesting that your
experiences seem to parallel the experience of others regarding the equal or
improved landing/takeoff, cruise, and stall behavior. How about any
differences in the takeoff and landing roll distances?
Bob Eli
jpspencer(at)cableone.net
PostPosted: Tue Dec 26, 2006 1:29 pm    Post subject: VG's Reply with quote
I just cut the slat brackets off my 701. I was able to match the claims of the our Aussie friends. The thing I found on my 701 was that the slats aren't active on approach unless the plane is forced into a high AOA, high drag attitude and kept there thruout the approach/landing(dragged in)-not usually considered good form for all the obvious and well known reasons unless necessary for high priority mission reasons of some sort. Also when the slats aren't active my plane was unstable on approach unless flown at Cessna 150 like speeds-hardly stylish for a proper STOL plane. Along with the rather nasty stability issue there was all sorts of airframe buffet with the slats on. The vgs fixed all the above and made my 701 what I consider to be a decent flying airplane-I couldn't say that when the slats were on it.
I've got something like 16 pages of flight test data. I consulted with an aero engineer on a possible structural issue here. The only downside I could find was that on takeoff I do believe you lose a minute amount to the slats(difficult to get any flight test numbers on this) but it's hardly relevant(except for showing off) since the thing will still come out in about a third of what it takes for a max effort landing(with the vgs in just the right position-I found placement to be important).I have followed all the recent posts on vgs and considered their merit before deciding what was right for me. What I noticed was that most of the more opinionated posts came from those who had never flown a 701 much less tried to do an objective before/after evaluation. At any rate I decided that the right thing for me was to cut the slat hangers off and bondo the holes up.
Aviation folks being what they are I know you will decide what's right for you-thats what i did.
Joe
Float Flyr
PostPosted: Tue Dec 26, 2006 1:53 pm    Post subject: vg's Reply with quote
Just like trim tabs and slats... Right!
VGs are just another tool to help planes fly better. Some need 'em some
don't. Depends not only on the plane but also the use of the plane. E.g.
speed vs. STOL
I almost forgot Do not archive again.
Noel
correct something!
Ron Lee
Tucson, Arizona
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Tue Dec 26, 2006 5:04 pm    Post subject: VG's Reply with quote
Don't cut too fast... one of those slat hangars could make a nice camera mount. Smile or even a landing light mount.
Noel [quote]
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Tue Dec 26, 2006 5:15 pm    Post subject: VG's Reply with quote
Bully for you Joe,
One question - you said that you found that positioning the VG's is critical. What position, in terms of % chord (or some other suitable reference) did you find gives the best performance?
Bob Eli
N701K
raymondj(at)frontiernet.n
PostPosted: Tue Dec 26, 2006 7:51 pm    Post subject: vg's Reply with quote
Ron,
Have you experienced any change in your angle of climb (Vy)?
Raymond Julian
Kettle River, MN.
PostPosted: Wed Dec 27, 2006 6:07 am    Post subject: VG's Reply with quote
As for placement I tried 12%, 10%, and 8%. I settled on 8 %(LE of VG at 147mm forward of rivet line on top of spar on my plane). 12% was too far back. At 10% on an extremely aggressive takeoff rotation the vgs would occasionally "uncover" and result in an extended takeoff roll. I haven't been able to force this situation at 8%.
I would stress that it is important to do your own flight testing before making this commitment as each of these planes is different and your results may vary considerably from mine.
Good Luck
Joe
PostPosted: Wed Dec 27, 2006 7:13 am    Post subject: VG's Reply with quote
Forgot to mention on my last post that I am looking for some sort of CG range data for the slatless wing-if anybody has or knows would appreciate it
BTW the last paragraph on my last post wasn't some BS liability disclaimer-it's real.
Happy New Year
Joe
daveaustin2(at)can.rogers
PostPosted: Wed Dec 27, 2006 7:23 am    Post subject: VG's Reply with quote
Re VG positioning..
I'd recommend you put more (closer together) VGs out at the wingtips to help make sure the inner wing stalls first. JMHO.
Dave Austin 601HDS - 912, Spitfire Mk VIII
vgstol(at)bigpond.net.au
PostPosted: Wed Dec 27, 2006 4:18 pm    Post subject: VG's Reply with quote
<I am looking for some sort of CG range data for the <slatless wing-if anybody has or knows would appreciate it
We have three slatless 701’s at our airfield, and some experience with adjusting CofG.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Hans’ (912S) weighs in at 503kg (1107lb) at 26% m.a.c., loaded for travel, with 82kg (180lb) pilot, 95litres (25gal) fuel in wing tanks, two jerrycans of fuel 28kg (62lb) on pax seat, and 20kg (44lb) baggage.
Gene’s (912) weighs in at 496kg (1091lb) at 25% m.a.c., loaded the same as above.
Hans’ and Gene’s were actually weighed in that loaded condition on professional scales.
Phil’s (912) was weighed empty, and the loaded conditions calculated. It weighed in empty at 283kg (623lb) at 22% m.a.c. This a/c has the original 40litre (10.6gal) fuel tank forward in the cowl, and 40litre (10.6gal) in the wings. Calculating the most forward CofG, (single pilot 82kg and full forward fuel), gives CofG at 21% m.a.c. Calculating full load CofG, (full fuel (80litres), pilot 82kg, pax 82kg, no baggage), gives 502kg (1109lb) at 28% m.a.c. Due to that forward fuel tank we had to put the battery right back in the tail to get the most forward CofG to 21%, which is still quite far forward...... This a/c has a history, in that when we bought it in a crashed condition the battery was forward of the firewall, so what was the actual CofG! The crash occurred when a ferry pilot, unfamiliar with 701’s, tried to take off from a short strip and then tried to abort too late when the aircraft didn’t want to rotate easily........ More detail on that in a separate post – there’s lessons there I think.
Of the three aircraft, Phil’s balances the best with a CofG at about 27% (pilot + pax + part fuel), Hans’ balances well at 26%, and Gene’s feels just a little bit nose heavy at 25%. This is testing the balance in glide, and the ability to flare comfortably at idle power. The next testing we will be doing is to adjust Gene’s to 27% to see if it feels better there......
Wishing fair skies and tailwinds all year.
JG
Page 4 of 4
