		Darrellhaas(at)verizon.ne Guest
				 Posted: Fri Dec 29, 2006 3:57 pm    Post subject: sequence of kits |
				Thanks Jeff for the info. Is there a  preferred sequence as far as which kit one should work on? I will probably start  with the rudder kit like many others but where should I go from  there?
  Darrell
  DO NOT  ARCHIVE
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Tim Juhl
  Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
				 Posted: Fri Dec 29, 2006 6:25 pm    Post subject: Re: sequence of kits |
				For the XL it was suggested to me to do rudder, horiz. stab, elevator, flaps, ailerons, wings, and fuselage.
 Read ahead, study the plans and don't be afraid to ask for advice. The kit is well designed but there is still plenty of opportunity to screw up.  Careful planning reduces the amount of scrap aluminum you'll produce.
  _________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
		Jaybannist(at)cs.com Guest
				 Posted: Fri Dec 29, 2006 6:49 pm    Post subject: sequence of kits |
				Darrell,
 My sequence was rudder, stabilizer/elevator, wings (along with nav/strobes & landing/taxi lights and controls), fuselage, dual sticks, canopy and landing gear.  I rigged the aileron cables before I closed my wings.  Canopy and main landing gear get in the way of other stuff if done too early.  The nose gear can be completed after the fuselage is nearly complete, but before the engine mount is installed. You can't really complete the canopy until your engine mount is bolted into place, your completed instrument panel and the forward top skin are finally riveted in place.  This is probably an over-simplification, but you will begin to get the picture as you proceed.
 Jay in Dallas
 "Darrell Haas" <Darrellhaas(at)verizon.net> wrote:
  	  | Quote: | 	 		  Thanks Jeff for the info. Is there a preferred sequence as far as which kit one should work on? I will probably start with the rudder kit like many others but where should I go from there?
 Darrell
 DO NOT ARCHIVE
		roger(at)nwtradingpost.co Guest
				 Posted: Fri Dec 29, 2006 6:57 pm    Post subject: sequence of kits |
				Did my wings before the flaps and slats because I read that you needed to
 make sure that the brackets on the flaps and slats fitted the wing.
 Roger
 701 - completing rear fuselage (tonight I hope)
		jeffrey_davidson(at)earth Guest
				 Posted: Sat Dec 30, 2006 6:08 am    Post subject: sequence of kits |
				Darrell,
             I believe that in the end, it really doesn't matter.  My 601 HD Manual starts on the wings.  Later portions of the manual expect that you have the skills learned building them.  I started with the rudder, then went on to build the stabilizer, and then the elevator finishing the tail.  I left the electrical work until now just putting in conduits for the wires as I built the airframe.  I also built from kits to pay as I went along.  I was lucky that Zenith is one of the two kit manufacturers still in business since 1994 (Van's is the other).  Other kit manufacturers I thought about are long gone (Pulsar & Team).  I also watched the ads and bought another builder's untouched wing kit saving me money and returning some to the other builder.  Some prefer to do the fuselage first for encouragement reasons.  You get to sit in it earlier, but eventually you need all the parts to fly!
             Jeff Davidson
 From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Darrell Haas
  Sent: Friday, December 29, 2006 6:57 PM
  Subject: sequence of kits
 [i]Thanks Jeff for the info. Is there a preferred sequence as far as which kit one should work on? I will probably start with the rudder kit like many others but where should I go from there?[/i]
 [i]Darrell[/i]
 [i]DO NOT ARCHIVE[/i]
   [quote]  [b]
		bretttdc(at)yahoo.com Guest
				 Posted: Sun Dec 31, 2006 9:55 pm    Post subject: sequence of kits |
				Your sequence really does not matter.  This thing will not fly until it aaaaaaaaaalllll  is done.  I have been three months from finishing for three years.  I was thinking I was three weeks from taxi tests last week. A very experienced  new friend of mine told me I was still three months away.  That was after I had a breakthrough weekend thanks to his help. I hate to admit it but; I think he  is  right.
  Make a  plan that works for you.  Modify it as is needed.  Try to do something on the project every day.  Remember that someday you will fly this thing.  It sure is looking better today; but only  because I did something yesterday!  I did not get as much done today as I had planned; but I got a lot done.  I have plans for tomorrow as well. I have passed the point that quiting is not an option.  I WILL FLY THIS THING SOMEDAY.
  Brett
		ggower_99(at)yahoo.com Guest
				 Posted: Tue Jan 02, 2007 11:12 pm    Post subject: sequence of kits |
				A good friend of mine, also a airplane builder,  answer this when asked how long it will take to build, etc.
 "Work on your project in a daily basis, if you cant, at least work on something of the plane every day"
 Saludos
 Gary Gower.
 Brett Hanley <bretttdc(at)yahoo.com> wrote:[quote] Your sequence really does not matter.  This thing will not fly until it aaaaaaaaaalllll  is done.  I have been three months from finishing for three years.  I was thinking I was three weeks from taxi tests last week. A very experienced  new friend of mine told me I was still three months away.  That was after I had a breakthrough weekend thanks  to his help. I hate to admit it but; I think he  is  right.
  Make a  plan that works for you.  Modify it as is needed.  Try to do something on the project every day.  Remember that someday you will fly this thing.  It sure is looking better today; but only  because I did something yesterday!  I did not get as much done today as I had planned; but I got a lot done.  I have plans for tomorrow as [quote][b]
		naumuk(at)alltel.net Guest
				 Posted: Wed Jan 03, 2007 3:18 pm    Post subject: sequence of kits |
				If you're looking for a sequence that will give you  the most hands-on skill in the shortest time, start with the stab.
  Bill Naumuk
 HDS Fuselage
 Townville, Pa
		PatrickW
  Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
				 Posted: Thu Jan 04, 2007 7:51 am    Post subject: Re: sequence of kits |
				I'm doing it in the following order, which spreads out the cost:
 Rudder Kit (at Rudder Workshop) - Done.
 Elevator/Stab Kit - Done.
 Engine - Looking for a rebuildable core.
 Wings/Fuel Kit - In progress.
 Fuselage - not there yet...
 Gear/Controls/Canopy - not there yet...
 Regarding the engine, I'm going with the Corvair.  A couple of people have told me that it's best to start on that early, as sometimes there are long lead times for parts.
 - PatrickW
