rexinator(at)gmail.com Guest
Posted: Fri Dec 29, 2006 10:00 pm Post subject: dead-stick topic |
Michel,
When I was in training it was considered risky to practice engine out
procedures by doing actual dead stick flight. Most of the training
flights were by flight schools and were done from tower controlled
airports. Possible dead stick practice accidents were enough of a
deterent to the schools considering they might be done by solo students
if taught by instructors.
I see no problem practicing them if you are allowed by the airport
authorities or have your own airstrip as long as safe procedures.are
followed. I intend to do them myself one day.
Rex
Snowy Colorado
Michel Verheughe wrote:
| Quote: | On Dec 28, 2006, at 11:20 PM, dave wrote:
> well why not do some stalls and take off the headset to hear the
> sounds you described before and all i heard was the air leaks !!
That would certainly be a good way to find out where the sound is
coming from, Dave. However, I have a problem. One year ago, I was
talking to this list about dead-stick landing and after I was told
that I never tried it after doing it with my instructor, I was told
that I should. Then I obeyed and I did, and I enjoyed it. In fact,
each time I am alone and the weather is stable, I land dead-stick. A
while ago, I told that to the Jabiru Engine list. There, I got the
opposite reaction. I was told that it was dangerous to cut out a
perfectly running engine and that I could try dead-stick with the
engine at idle.
Now, I am confused and I don't know if I should or I should not.
Michel
kirkhull(at)kc.rr.com Guest
Posted: Sat Dec 30, 2006 4:22 am Post subject: dead-stick topic |
Once you have mastered the procedure you should be fine. The reason they
don't teach this is that if you find out that you are not going to make the
field until the last min then you don't have enough time to restart the
engine and in some cases it wont start any way.
Float Flyr
Posted: Sat Dec 30, 2006 6:49 am Post subject: dead-stick topic |
When I was training my instructor and myself were out doing forced
approaches one day. It was a very cold dry day and we had had a very cold
week. All the ponds in the area were frozen over just like skating rinks.
For training purposes we used a hard deck of 500'. On one of the approaches
I lined up to land on one of the ponds The instructor asked why I didn't
line up on the woods road beside the pond. I told him about wing clearance,
potholes and the fact on the ice there was plenty of room for a rescue
aircraft to land also with the weather we had the ice was no doubt up to
carrying our weight. Also many ski-doo tracks went across the ice and
showed it to be very strong.... He said OK. I asked him then if he wanted
to make the next one a full on landing.... He wasn't interested! I later
told him that when flying with my father in his Lake LA4 we regularly landed
on ice.
For our forced approaches we used Engine to idle, carb heat and 20 Deg. Flap
(C172) with 3 sec of full throttle every 500' of decent to keep the CHT up.
It was considered very important to do the engine warms.
At that time a student and instructor (different flight school) got their
wings doing the exact same thing some 200 Mi away. Apparently they had
engine problems when going around from a forced approach. The weather in
their local was considerably warmer and damper than ours so I suspect what
they had was carb icing.
After that we were given a hard deck of 1000' AGL for forced approaches.
I have seen a film of a fellow in Alaska who flies a Cub stripped down. In
order to land he has to shut down his engine as he doesn't have breaks. He
also doesn't have a starter. Every landing at his home strip is both dead
stick and short on soft field. Hi wife and son fly in and out every day
under the same conditions.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
rliebmann(at)comcast.net Guest
Posted: Sat Dec 30, 2006 9:18 am Post subject: dead-stick topic |
On the subject of intentional dead stick landings, we should check the FAR's
to make sure that it legal to do so. Back when I was building hours towards
my commercial rating I told an FAA friend that I was doing intentional dead
stick landings and he said that they were not allowed by the regs.
Ron N55KF
Float Flyr
Posted: Sat Dec 30, 2006 11:49 am Post subject: dead-stick topic |
Better get a longish ladder for those guys that went flying without an
engine. If there is such a regulation by FAA it just goes to show how
uninformed some civil servants really are.
Noel
[quote] --
Kitfox III-A
Michel
Posted: Sat Dec 30, 2006 3:43 pm Post subject: dead-stick topic |
On Dec 30, 2006, at 2:45 AM, ron schick wrote:
| Quote: | Ah Michel I always try to learn from others then do as I feel
comfortable.
Here is how I feel about it, Ron. I don't do anything that is not
necessary, this is recreational aviation, right? The pleasure is in
flying. But training for an eventual engine stop is part of safe
flying, I think. It happens that, with the Jabiru the engine stopped,
my plane sinks a bit faster than at idle. Norway is not Illinois and if
I find a field for landing, it will be of a handkerchief size. So, I
train dead-stick precision landing at my very long asphalt runway home
airfield. I have a friend who lost power on initial climb and while it
went just fine (did a 180 and downwind landing) he get very irritated
by the three or four seconds he lost by thinking: "This is not
happening to me! This is not happening to me!"
I think aviation safety is about recognising at once a situation and
act as an automatic response to what one has trained for. I have read
of bad emergency landings due to the pilot not being able to make his
mind where to land, or trying vainly to restart the engine.
Michel
kitfoxjunky(at)decisionla Guest
Posted: Sat Dec 30, 2006 7:09 pm Post subject: dead-stick topic |
Before the Kitfox, I used to jockey around a C-150 Aerobat. I was taking some aerobatic instruction at a remote strip and the instructor pulled the mixture and had me nose up till the prop stopped. That was my first real dead stick landing in a powered airplane. Many years later the family rented a cottage in Northern Ontario, and there was a 6,000 abandoned airstrip next to the lake. I used to go out very early in the morning just after sunrise...climb to 4000' above the field, then shut down the engine and do dead stick landings. Those got to be routine so I moved up to dead stick loops and rolls. At first I found there was a big difference emotionally between a windmilling prop and one that was not moving...then I simply got used to it.
I mentioned this when hanger flying once and someone called it reckless. After that I kept my mouth shut. About three years ago I had my first real emergency landing, and I think part of the reason I remained calm was because seeing the prop stopped was not unfamiliar. In retrospect, I was glad I had that dead stick experience under my belt.
Gary Walsh
KF IV Anphib 912S
C-GOOT
www.decisionlabs.com/kitfox
do not archive [quote][b]
Posted: Sat Dec 30, 2006 7:49 pm Post subject: dead-stick topic |
I agree with you completely. Back in 1967 while I was building hours to get
my commercial rating I was being instructed by a pilot from Unites Airlines
who was also a good friend of mine. With him on board a Cessna 150 we did 20
deadstick landings where we killed the engine completely at 10,000 feet.
| Quote: | From that height we glided back to our home airport 10 times with the prop
windmilling and 10 flights with the prop stopped. My friend assurred me that
during the next 40 to 50 years of flying, I was sure to have at least one
complete engine failure forcing me into a gliding situation. He wanted me to
be ready for it when it happened. I learned the difference in the way the
plane flew in each mode and when I should use the turning or stopped prop to
best suit the situation. After the 20 flights I felt good about facing the
time that it would happen.
When it did occur in N55KF back in 1992 with just 92 hours on a new engine,
that experience paid off. It all came back to me. To this date I still shut
the engine off and glide for fun. I start at 5000 feet agl and chase
thermals over a long grass strip out in the country.
Back then when I took my commercial flight test the examiner pulled the
mixture at 2500 ' agl and said that my plane was on fire and my kids were in
the back seat. I had to get the plane on the ground as fast as possible.
After spiraling down and turning final the examiner told me to hit the white
line at the start of the runway. After hitting the line he said "I like to
see that again".I said "ok thats easy". I pushed the mixture in and with the
prop still windmilling, advanced the throttle at which point he pulled it
back and had me taxi to the parking area. He said that he was considering
failing me because of my cocky attitude when I told him that I could easily
hit the white line a second time. It was then that I told him of my 20
deadstick landings and that was how I became proficient at deadstick spot
landings....
He advised me that, at that time, it was illegal to deliberately kill an
engine as it was considered to be an "aeorbatic" maneuver which I was not
checked out to do. He knew that I was going to be hired by United soon and
he passed me anyway.
Today, I spend an hour going thru the regs looking for anything on
"deliberately" killing ones engine. I could find nothing on the subject but
if something is there, it is beyond me.
Happy New Year everyone, Ron
| Quote: | Here is how I feel about it, Ron. I don't do anything that is not
flying. But training for an eventual engine stop is part of safe flying, I
think. It happens that, with the Jabiru the engine stopped, my plane sinks
a bit faster than at idle. Norway is not Illinois and if I find a field
for landing, it will be of a handkerchief size. So, I train dead-stick
precision landing at my very long asphalt runway home airfield. I have a
friend who lost power on initial climb and while it went just fine (did a
180 and downwind landing) he get very irritated by the three or four
seconds he lost by thinking: "This is not happening to me! This is not
happening to me!"
I think aviation safety is about recognising at once a situation and act
as an automatic response to what one has trained for. I have read of bad
emergency landings due to the pilot not being able to make his mind where
Michel
Graeme Toft
Posted: Sat Dec 30, 2006 7:58 pm Post subject: dead-stick topic |
Michel, I couldn't agree more. Time is so precious when encountering an
engine failure and it is not always when we have the luxury of sufficient
height that it happens. I am fortunate to have walked away from 2 engine
failures but both were totally different. On the first occasion I was at
1500 feet and by the time I realised the prop was stationary and that the
engine had failed I had lost precious time that could have been better used.
It was only after a good ten to fifteen seconds that my training really
kicked in and I carried out my first forced landing with time on my side.
The second as you know was totally different in that I was only at 300 - 400
ft and a long way offshore. You would think that the first experience would
have conditioned me to handle the second one in a more professional manner,
but I am convinced that we all handle stressful situations differently. In
my case the realisation of the engine failing again took time to sink in and
compounding the situation was that this time due to the NSI gear box, the
prop was free wheeling quite fast. My brain was tell me the instruments were
receding, my eyes were telling me that the prop was turning and my ears were
telling me that the normal flight noises had stopped. I was confused and
clearly remember questioning what I was seeing. Again I lost valuable time
and with limited options was lucky to select one that again I walked away
from ( Or should I say swam away from). You are completely right in saying
"I think aviation safety is about recognising at once a situation and act as
an automatic response to what one has trained for" but Imp afraid I don't
know how many times it takes to prepare you for the real thing. I only know
that without me taking the same sensible approach to engine failures as you
do yourself, I truly believe I would be wearing my wings rather that
strapping them onto my back when I fly.
Graeme
Float Flyr
Michel
Posted: Sun Dec 31, 2006 8:40 am Post subject: dead-stick topic |
On Dec 31, 2006, at 4:09 AM, kitfoxjunky wrote:
| Quote: | About three years ago I had my first real emergency landing, and I
This is exactly what happened to me when I did my first dead-stick
landing without an instructor, I became fascinated by looking at the
prop that had stopped. Wrong reaction! But I was over a 3 km long
runway of a nearby commercial airport, I had plenty of time to make my
landing.
Incidentally, I went flying a bit today, the last day of the year, and
did some stalls. The sound I hear doesn't come from the wings. I think
it might come from the elevator. I hear it when the stall starts and
when I get out of it.
Have a very nice new year's celebration, everyone, and ... many happy
flying hours next year! (Gee, flying a Kitfox is good; I had so much
fun today!)
Michel
Float Flyr
Posted: Sun Dec 31, 2006 11:52 am Post subject: dead-stick topic |
I don't suppose your elevator hinges are a bit loose??
Noel
[quote] --
Kitfox III-A
Michel
Posted: Mon Jan 01, 2007 7:26 am Post subject: dead-stick topic |
On Dec 31, 2006, at 4:58 AM, QSS wrote:
| Quote: | Imp afraid I don't know how many times it takes to prepare you for the
real thing.
I don't know either, Graeme. If you go to this site:
http://www.planecrashinfo.com/index.html
then look at "Last Words," in the menu, you'll see from the cockpit
voice recordings that some professional pilots keep professional to
their last words - as if they were robots; while others loose control
of their feelings.
Michel
smokey_bear_40220(at)yaho Guest
Posted: Tue Jan 02, 2007 11:11 pm Post subject: dead-stick topic |
Michel,
You said it sounds like fabric ripping? Back there?
Check all your elevator/stab mounts for solid
attachment. It may take a lot of force, but then they
move a little?
Kurt S.
--- Michel Verheughe <michel(at)online.no> wrote:
| Quote: | Incidentally, I went flying a bit today, the last
the wings. I think
stall starts and when I get out of it.
| Quote: | Michel
Michel
Posted: Thu Jan 04, 2007 12:22 pm Post subject: dead-stick topic |
On Jan 3, 2007, at 8:10 AM, kurt schrader wrote:
| Quote: | You said it sounds like fabric ripping? Back there?
move a little?
Well, not exactly ripping fabric, Kurt, but rather 'slamming on the
fabric.' Of course, I do a very careful walk-around prior to each
flight and I haven't notice anything loose or even slightly untied. But
when I lift the horizontal stab, with my hand, I can hear a sound that
comes from the elevator's hinges that are slightly moving. But it's a
weak sound and I doubt that's what I hear when I stall. But I'll try
your trick of using the unused headset mike as a direction finder.
Actually, I'll do anything to have a reason to go out flying!
Michel
Posted: Thu Jan 04, 2007 9:11 pm Post subject: dead-stick topic |
Michel,
Right after I finished my last test flying, I had a
loud drumming on the belly fabric on landing from the
next flight. It really got my attention! What was
coming appart!!!
Seems that I had removed the camera I used for
inflight panel recording during testing, but didn't
remove the rubber washer from the camera mount bolt.
It came off the (up facing) bolt and that little
rubber washer (about the size for a garden hose)
sounded like the tail wheel was coming off. Found it
under the baggage deck.
Sometimes it is the simple stuff....
Kurt S. S-5
there?
they move a little?
| Quote: | Well, not exactly ripping fabric, Kurt, but rather
'slamming on the
prior to each
hear a sound that
moving. But it's a
stall. But I'll try
direction finder.
out flying!
Michel
Michel
Posted: Fri Jan 05, 2007 12:44 pm Post subject: dead-stick topic |
On Jan 5, 2007, at 6:10 AM, kurt schrader wrote:
| Quote: | Sometimes it is the simple stuff....
I agree Kurt. Maybe it's only (the stall sound) my denture coming
loose, hitting my glass eye, which lifts my wig and disturbs my hearing
aid.
Michel
Posted: Fri Jan 05, 2007 8:13 pm Post subject: dead-stick topic |
Actually, I first thought of viking helmit horns doing
something bad during stalls....
First sign of a Norwegian stall? Your helmit sticks
to the skylight...
For me, stalls are usually fine. But if I haven't
spun in a while, there is usually a strange noise
coming from the cockpit.
Kurt S.
denture coming
disturbs my hearing aid.
Michel
FlyboyTR
Joined: 04 Nov 2006 Posts: 215 Location: Mobile, Alabama
Posted: Sat Jan 06, 2007 7:42 am Post subject: Re: dead-stick topic |
Just a short response/comment about dead stick landings. Of all “major” component failures in your airplane…I’ll take an engine-out…hands down! …wing, elevator, tail, etc…fails…or at worst it chooses it’s own direction of travel away from the plane… all the piloting skill in the world isn’t going to help, unless you have a BRS, etc. I have always been a believer in being the PIC and being able to “fly the plane” without the assistance of forward thrust. Dead stick landings in a C-177 Cardinal were common practice…and actually quite fun. In the 90’s we shifted from GA to Quicksilver’s and Challengers (about 2500+ hours). Here we found people that had fly-ins with “field events.” Dead stick landings were our specialty…always! 9 out of 10 landings I could drop the wheels within 10 feet of the line…the 1 out of 10 I fell short a few feet! Good stuff!
My CFI (1970) was a crazy WWII pilot. His stories of walking away from the crash left a deep impression on me. I will try to quote something he said. “…If you can’t control your aircraft at MCA, with or without an engine, or put the #!%& wheels where YOU want them, with or without an engine, or instantly respond to an inflight emergency…what gives you the right to think you can fly at 150 knots! Planes don’t crash into the air…they crash into the %!#$ ground! Going up in the only option you have…you’re coming down and you’d #$% well better know how to put your plane exactly where you want it” I don’t think I will ever forget his words. …may he RIP.
This diatribe is longer than I had planned. Sorry! However, I have always practiced dead-stick landings, and we are now practicing them in our Kitfox Vixen. During an emergency, time is what you usually don’t have. Wasting it (time) trying to figure out what you should do could easily be your killer! Always have a plan, always FLY the plane…with or without the engine! As my old CFI (Tommy) said, “Going up is optional…you’re coming down!”
Travis
_________________ Travis Rayner
Mobile, AL
Skystar Vixen, N-789DF
Continental IO-240, Prince P-Tip Prop
ADI-II Autopilot
AnyWhereMap Navigation with weather
www.enotam.net (My Flying Info Website)
Aerobatics(at)aol.com Guest
