dave
Posted: Sun Dec 31, 2006 4:12 am Post subject: Fuel shut offs |
Lynn,
I have one shut off for each wing tank and they join a " T" then flow into
on line through a see through glass filter and trap all the debris from the
wing tanks. The line the goes into a facet pump then along the longeron
and up to another "T" downstream from the dash tank's shut off valve. I
rarely used the facet pump other than to transfer fuel quicker to the main
tank. Gravity and air pressure seems to match burn rate without the Facet
pump . So I can isolate and shut off each tank separate from each other.
I hope this is correct and It has not failed me yet.
I should have added the wing tank shut offs are a brass ball type . Kind of
like a natural gas style if that makes sense. ? Hope ethanol likes them .
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Lynn Matteson
Posted: Sun Dec 31, 2006 8:59 am Post subject: Fuel shut offs |
The only difference I can see between my 'two-glass filters, two-
valves' system and yours is that I can determine which tank the crud
is coming from, if there should ever be any...and someday there
probably will.
Yup, my shutoffs are all the brass ball type, too.
My Facet is also pretty much going along for the ride. : ) I cycle
it occasionally.
Lynn
On Dec 31, 2006, at 7:11 AM, dave wrote:
Lynn,
flow into on line through a see through glass filter and trap all
the debris from the wing tanks. The line the goes into a facet
pump then along the longeron and up to another "T" downstream from
the dash tank's shut off valve. I rarely used the facet pump
other than to transfer fuel quicker to the main tank. Gravity and
air pressure seems to match burn rate without the Facet pump .
type . Kind of like a natural gas style if that makes sense. ?
Dave
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Posted: Tue Jan 02, 2007 11:06 pm Post subject: Fuel shut offs |
Lynn and the List,
Make sure you have a way to turn off ALL the fuel,
including the header tank, if you have one. That is
what the origional header-to-engine shutoff was for.
I agree that wing tank valves come in handy,
especially for down stream fuel line work. I don't
have them yet. I just put a clamp on the hose so far,
even in flight. Worry about damaging the Tygon hose,
but so far it is fine. A fuel system re-work is in
the plan for '07.
Kurt S.
--- Lynn Matteson <lynnmatt(at)jps.net> wrote:
| Quote: | The only difference I can see between my 'two-glass
filters, two-
which tank the crud
someday there
probably will.
ride. : ) I cycle
it occasionally.
Lynn
Lynn Matteson
Posted: Wed Jan 03, 2007 3:01 am Post subject: Fuel shut offs |
Hi Kurt-
My only non-shut-off-able (if that's a word) area is the first 18" of
fuel line right out of the tanks...after that come the ball valves
which are reachable while in flight, the header tank, then the easily
reachable main shutoff right on the center console. One of these days
when I need an excitement "fix", I'll shut off both ball valves, and
test the low-fuel warning system. With the valves shut off, the
header will still supply my engine until the fuel in the lines to the
header tank run out, then the low-fuel switch will trigger my panel-
mounted warning light. Testing the lightbulb is part of my 'prior to
starting engine' checklist, but checking the actual operation of the
system has to be done while the engine is running. I have done this
on the ground, but not yet in flight...no biggie, but when I need a
"pucker-factor check" I'll do it at altitude. : )
Lynn
On Jan 3, 2007, at 2:06 AM, kurt schrader wrote:
<smokey_bear_40220(at)yahoo.com>
Lynn and the List,
the plan for '07.
Kurt S.
> filters, two-
> which tank the crud
> someday there
> probably will.
> ride. : ) I cycle
> it occasionally.
> Lynn
N369LM |
Posted: Wed Jan 03, 2007 8:41 pm Post subject: Fuel shut offs |
Sounds good Lynn.
I didn't add the valves on my origional build, but
will add at least a left tank valve on my fuel system
rework. I want to simplify it for reliability and
move everything I can aft of the firewall to reduce
the chances of trouble in that hot spot. A fuel leak
around me isn't nearly as bad as one around the
engine, it turns out. I am usually not a "flamer".
Ha ha But my gascolator drain failure inches from my
exhaust last year got my attention. I think I had
help on that one....
Adding the left tank valve prevents crossfeed
inbalance from parking on a slope or from bad gas cap
seals in flight. Adding the second makes it all
controlable, but runs the risk of having them both off
in flight. This is really a check of my confidence in
my memory and habits to add both. But like you,
I have a low fuel light too. The light and level it
provides is part of my annual. light testing before
flight of course. I use an LED for reliability.
As always on this list, it is interesting to remember
your history here and think of all the progress you
made, Lynn.
Have a great New Year.
Kurt S. S-5
| Quote: | Hi Kurt-
the first 18" of
the ball valves
One of these days
ball valves, and
shut off, the
the lines to the
trigger my panel-
of my 'prior to
operation of the
have done this
but when I need a
Lynn
aldaniels(at)fmtcblue.com Guest
Posted: Wed Jan 03, 2007 9:42 pm Post subject: Fuel shut offs |
I have built them with a shutoff on each wing tank and also with just
the one shutoff in the center console. I really prefer the one with a
shutoff on each tank, but only if I have a low fuel warning system in
the header tank. Seems like I can never fly both straight and level (
among my many other faults ), and it seems like I keep the right wing
up. This fuel imbalance combined with my 220 pounds makes me left side
heavy. I built the last one, a 5/7 as close to factory as possible in
case I needed to sell it. The fuel system works fine, but parking on a
side hill will give a fuel imbalance but it has never been a problem. I
built it with and for my son who in a moment of weakness decided to get
married instead of keeping the plane. I bought his part out and have
kept it in the hangar in case he figured out how to afford it, but in
another moment of weakness they are starting a family.
Sounds good Lynn.
Posted: Wed Jan 03, 2007 10:06 pm Post subject: Fuel shut offs |
I considered installing the one way check valves in
the wing tank lines to prevent transfer, but not
restrict engine feeding. The problem is that you
still need to shut the fuel off to change a filter or
do other fuel system work, or you have to drain all
the fuel.
I agree, the 3 valve system seems best, 2 wing and the
main shutoff valve.
kurt S.
--- Alan Daniels <aldaniels(at)fmtcblue.com> wrote:
| Quote: | I have built them with a shutoff on each wing tank
and also with just
warning system in
the header tank.
Lynn Matteson
Posted: Thu Jan 04, 2007 5:52 am Post subject: Fuel shut offs |
Speaking of having help...when I had a tail pipe break off from my
Jabiru exhaust system, (due to me adding unsupported length) and the
resultant flame licked at my engine mount and scorched the outer
layer of my fuel sleeve. Yeah, the aviation Gods were looking out for
me that day. And when I filled the tanks to the max, and parked at a
slight side angle to load up my Granddaughter for a flight. My
daughter said "what's this water running off the wing here"? Holy
mackerel, get away from the plane while I level it out...yeah that
was a close one too.
Thanks to this list, I really feel like I HAVE made some progress,
Kurt. From advice as to which plane to buy, to knowing how much fuel
to (not) cram into the tanks, to recent advice on building
skis...which are now in progress...thanks guys and gals. : )
Lynn
On Jan 3, 2007, at 11:41 PM, kurt schrader wrote:
| Quote: | As always on this list, it is interesting to remember
made, Lynn.
Kurt S. S-5
N369LM |
