dave
Posted: Sun Dec 31, 2006 10:04 am Post subject: : dead-stick topic The sound Michel |
Michel,
Could that sound be simular to the one i mentioned in this post ?
Dave
| Quote: | >Now once you put
nose down just after you break the stall I do get a bit of a THUD from
the rear........ I am guessing it the disturbed air on top of wing
washing onto the tail ?
Sent: Thursday, December 28, 2006 5:20 PM
Subject: Michel Fabic tearing topic
Michel,
I just in from 2.5 hours flying today in total.
I mentioned that i was doing airstarts after gliding the Kitfox and I
thought about you today so I went up and shut off mags and slowed to about
40 ias till the prop stopped. Then came this bright idea *** oh
yeah BRIGHT !!
well why not do some stalls and take off the headset to hear the sounds
you described before and all i heard was the air leaks !! I did about
half dozen stalls -- all power off and mags too !! some steeper than
others and I just get a shudder and a mush for the most part. Now once
you put nose down just after you break the stall I do get a bit of a
THUD from the rear........ I am guessing it the disturbed air on top of
wing washing onto the tail ?
Maybe if I hear air leaks then i have some taping and sealing to do some
time ?
Hope that helps you and it was fun........
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Michel
Posted: Mon Jan 01, 2007 7:37 am Post subject: : dead-stick topic The sound Michel |
On Dec 31, 2006, at 7:03 PM, dave wrote:
| Quote: | Could that sound be simular to the one i mentioned in this post ?
Yes Dave, it could.
On Dec 31, 2006, at 8:52 PM, Noel Loveys wrote:
| Quote: | I don't suppose your elevator hinges are a bit loose??
Yes, Noel, it could.
On Dec 31, 2006, at 9:20 PM, Dee Young wrote:
| Quote: | How about the turtle deck drumming.
Yes, Dee, it could.
Thanks for your answers, guys. I think I feel better knowing it's not a
wing. I did lift my headset to hear better (but with the engine on) and
it is definitively coming from right hand and behind me. I'll need a
passenger to do more hearing observation. Yet a new reason to go out
flying! Wow, cool!
Michel
smokey_bear_40220(at)yaho Guest
Posted: Tue Jan 02, 2007 10:52 pm Post subject: : dead-stick topic The sound Michel |
Michel,
It is often hard to find noises in vehicles, even
relatively quiet cars. One thing that may help is if
you hold the unused headset mike up to suspected
sources and listen over the intercom, squelch adjusted
accordingly. You will only hear it over the intercom
when the mike is near the source. Might help you
isolate it if the source is in reach.
If it is on the right behind the seat, the right
passanger might have to twist around a lot, unless
they do the stall while you check behind them from the
left seat.
Just an idea,
kurt S.
--- Michel Verheughe <michel(at)online.no> wrote:
| Quote: | Thanks for your answers, guys. I think I feel better
knowing it's not a
the engine on) and
me. I'll need a
reason to go out
flying! Wow, cool!
Michel
