sportav8r(at)gmail.com Guest
Posted: Thu Jan 04, 2007 5:23 am Post subject: small spade lugs |
Bob: the barrier terminal strip in question has a terminal spacing of
.25" and with the thickness of the plastic dividers between, leaves
.180" width for spade terminals to fit under the screw heads. I saw
none that small in the DigiKey catalog, and found none that narrow in
my junkbox. I have an email in to "JD" at Infinity Aerospace, but no
reply so far. Looks like I may be grinding down my own lugs if I
elect not to just clamp bare wires. Is there a possible problem with
tinning the tips of the wires with solder, to prevent fraying when
shoving them under the hold-down plates, as far as getting a good,
lasting torque-down of the screws? I don't want anyting coming loose
under vibration later on. Something tells me the screws won't "mash
down" as well on solder-dressed stranded wire as they might on the
free strands.
-Bill B.
nuckollsr(at)cox.net Guest
Posted: Thu Jan 04, 2007 7:22 am Post subject: small spade lugs |
At 08:22 AM 1/4/2007 -0500, you wrote:
Please DO NOT clamp screws down on bare wires. It is ALWAYS
acceptable to file down the sides of a PIDG style ring terminal
to fit between barriers on a terminal strip.
| Quote: | Is there a possible problem with
| Quote: | Something tells me the screws won't "mash
free strands.
It's a toss-up. If that were my only choice, I'd probably
tin the strands first. The major problem with terminal strips
and wires is vibration support just outside the crimped, clamped
(or soldered) connection. This is the "magic" of the PIDG
style terminal . . . whether you crimp -or- solder, there
is a stress concentration in the wire's strands immediately
where they emerge from the electrical connection. The insulation
grip immediately adjacent to this stress point prevents future
failures at that location due to flexing under vibration.
In articles published by two different authors . . .
http://aeroelectric.com/articles/rules/review.html
http://www.aeroelectric.com/articles/richter/response_1.pdf
supposedly authoritative individuals hat-dance completely
around these simple-ideas described in . . .
http://aeroelectric.com/articles/terminal.pdf
In the 75 or so years since PIDG terminals were developed,
there have been billions of connections made between wires
and terminals that have run failure-free simply because the
designer took time to recognize and accommodate this
little vulnerability in a wire's termination.
< with experiment. >
< --Lawrence M. Krauss >
dsvs(at)ca.rr.com Guest
Posted: Thu Jan 04, 2007 7:46 am Post subject: small spade lugs |
Bob,
Allied sells "ferruls" that while not perfect, allow wire termination with support of the insulation in places that ring terminals will not fit. One down side is the need for still another crimper. I am suing an engine monitor that had no other good way to terminate the wires. I will report later after some flight time as to weather these "ferrules" work out. Don
---- "Robert L. Nuckolls wrote:
>free strands.
Posted: Thu Jan 04, 2007 12:03 pm Post subject: small spade lugs |
It suddenly dawned on me that I can crimp on a .250" FastOn male
connector and grind down the sides to correct width and slot the
center to straddle the little #4 screw, thus making my own mini-spade
lug. All the spades I have in my assortment have such wide slots,
there'd be almost no material left after filing the sides down. I
think this is what I will do. Thanks for the review of options.
-Bill
On 1/4/07, Robert L. Nuckolls, III <nuckollsr(at)cox.net> wrote:
>free strands.
bakerocb
Posted: Fri Jan 05, 2007 8:21 am Post subject: small spade lugs |
1/5/2007
Hello Don, You wrote: "I am suing an engine monitor that had
no other good way to terminate the wires."
Would you please identify the manufacturer of this unit to all of us? Just a
simple statement of who made it and a description of the configuration at
issue would be helpfull. Thanks.
OC -- The best investment we will ever make is in gathering knowledge.
Time: 07:46:44 AM PST US
Subject: Re: small spade lugs
Bob,
support
had
flight
