wingnut
Posted: Fri Jan 05, 2007 7:44 am Post subject: Repairing an IVOPROP |
I have an in flight adjustable IVOPROP ultralight. One of the blades has developed a small nick about the size of an eraser head. It's deap enough that the weave in the fiberglass is exposed. Is it possible to repair this or should I just replace the blade?
Luis Rodriguez
N824KF
Fox5flyer Guest
Posted: Fri Jan 05, 2007 8:45 am Post subject: Repairing an IVOPROP |
Warp recommends mixing up some epoxy and microballoons to fill in the nicks.
When its completely cured, file/sand smooth and paint (optional). I would
assume IVO would be similar. Then again, you could send it to IVO for them
to evaluate and repair.
Deke
lcfitt(at)sbcglobal.net Guest
Posted: Fri Jan 05, 2007 10:00 am Post subject: Repairing an IVOPROP |
Luis,
You'll get lots of opinions and second hand information from the list. My
suggestion is that you contact IVO. Then you will get some solid advice.
Lowell
wingnut
Posted: Fri Jan 05, 2007 6:39 pm Post subject: Re: Repairing an IVOPROP |
Got a response from IVO in case anyone is interested. Here's their short list of reccomended filler starting with the best option:
Polyester gel coat
Polyester fiber glass resin
2 part epoxy
