jdalton77(at)comcast.net Guest
Posted: Wed Jan 03, 2007 5:07 pm Post subject: Battery AND Starter Contactor? |
Hello,
I'm new to the list, and just getting started on the wings of an RV-10, having finished the tail kit last month. I've read Bob's book, but as I'm starting to design my electrical system I have (at least for now) a question.
The schematic in "the book" shows the main battery pos wire connected to the battery contactor and then from there to the starter contactor. I just viewed the HomebuiltHelper Video on wiring a homebuilt and they showed the battery connected directly to the "starter solenoid" which I think is meant to be called the starter contactor (at least it looks like one).
So my newbie questions are:
1. Are both of these approaches correct?
2. Is the "starter contactor" any different than the "batter contactor?"
3. Am I correct in that the device in the video is not called a "solenoid?" From reading Bob's book, I'm guessing this is the "close but no cigar" example.
Thanks and please be gentle.
Jeff Dalton
mprather(at)spro.net Guest
Posted: Wed Jan 03, 2007 5:47 pm Post subject: Battery AND Starter Contactor? |
Whooo.. This is a recurring topic of questions on the list.. Much
discussion in the archives.
Answers:
1. It depends on your design goals. Probably both designs aren't correct
however. Aircraft electrical systems need a high current battery switch -
either an electrically operated relay, or a big mechanical switch. A
primary reason is so that the whole system can be de-energized by
isolating the battery from the rest of the airplane. The high current
switch needs to be mounted as close as practicably possible to the
battery. The longer the run from the battery to the battery contactor,
the more care in protecting the wire that forms this connection.
2. Starter contactors are typically momentary switches, and can take
quite a bit of power to actuate 10Watts+. This extra current helps make
the switching action more robust - good for controlling currents in the
hundreds of amps. Battery contactors are continuous duty devices. They
consume less power, and won't switch a 200A+ load as robustly as the
starter contactor.
3. Your assessment seems correct.
Matt-
| Quote: | Hello,
question.
one).
no cigar" example.
Jeff Dalton
nuckollsr(at)cox.net Guest
Posted: Thu Jan 04, 2007 7:43 am Post subject: Battery AND Starter Contactor? |
At 07:59 PM 1/3/2007 -0500, you wrote:
Hello,
Both will "function" . . . but you won't find a type certified
airplane wired as shown in the video. It is the function of the
battery contactor to remove as much power from ship's wiring as
possible when in the OFF condition.
In the book we talk about the differences between starter contactors
and battery contactors. Starter contactors are intermittent duty devices
that draw a lot of coil current (3-5 amps) to provide large closing
forces on the contacts. Battery contactors continuous duty devices
that draw typically 1 amp or less.
no cigar" example.
All contactors (hi-current relays) have solenoids (short stroke,
linear-motion motors) but not all solenoids have contacts. This is
a good example of how common vernacular can confuse the details about
a part's functionality.
< with experiment. >
< --Lawrence M. Krauss >
Posted: Thu Jan 04, 2007 2:19 pm Post subject: Battery AND Starter Contactor? |
Thanks Bob. I just read that in your book.
Jeff
aurbo(at)ak.net Guest
Posted: Fri Jan 05, 2007 6:50 am Post subject: Battery AND Starter Contactor? |
Bob,
Thanks for the explanation, I especially like your words, "This is a good
example of how common vernacular can confuse the details about a parts
functionality".
I am totally confused. I bought the Van's "Starter Solenoid" and "Master
Relay" listed on page 82 of their accessories catalog and now I can't figure
out if they are the same animals as what are required in the Z-11 drawing.
In the Z-11 drawing the required devices are listed as Battery Contactor and
Starter Contactor.
Are these animals the same with just different names or should I throw away
the units I have and order new ones from B&C with the proper names just to
be sure?
| Quote: | From what I can glean so far it looks like they are the same, they are all
"contactors" just that one is continuous and one is intermittent. Is that
correct?
Thank you,
Mike
Posted: Fri Jan 05, 2007 7:28 am Post subject: Battery AND Starter Contactor? |
At 05:48 AM 1/5/2007 -0900, you wrote:
Bob,
functionality".
figure out if they are the same animals as what are required in the Z-11
drawing.
and Starter Contactor.
away the units I have and order new ones from B&C with the proper names
just to be sure?
all "contactors" just that one is continuous and one is intermittent. Is
that correct?
Thank you,
Mike
Yes. It's not uncommon for contactors to be referred to as
"solenoids" and they do indeed contain a solenoid for operation.
Starter solenoids mounted directly on starters have double duty -
the solenoid extends the pinion gear to mechanically engage the
starter. At the same time, it makes electrical connection between
the battery and starter motor by means of contacts in the same
assembly. Here, the proper term for the device is starter solenoid.
As soon as you pull it off the starter it becomes a fat relay more
properly called a contactor.
Posted: Fri Jan 05, 2007 9:36 am Post subject: Battery AND Starter Contactor? |
Bob,
Thank you kind sir.
Mike
