kitfox555(at)sbcglobal.ne Guest
Posted: Fri Jan 05, 2007 8:59 am Post subject: kitfox2 new builder |
What have you all done with the flap controller I'm playing around with it today and it seems to be loose ,does it hold when you put on flaps or do you have to hold it up? Mine has the leather in it, but seems like it should have clicks or something, any advise?
Jerry Evans
kitfox 555 [quote][b]
dave
Posted: Fri Jan 05, 2007 9:40 am Post subject: kitfox2 new builder |
Jerry,
I tighten mine tighter when mine gets loose and put a cotter pin back in.
Mine holds at any flap setting in flight fine
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
f.miles.tcp.833(at)clearw Guest
Posted: Fri Jan 05, 2007 9:51 am Post subject: kitfox2 new builder |
Jerry,
It is held in place by friction. You have to tighten the control handle until in flight air pressure will no longer move it. Looks like a poor system but it does work.
Frank
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of jerry evans
Sent: Friday, January 05, 2007 8:59 AM
Subject: kitfox2 new builder
Jerry Evans
kitfox 555 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 01234
1:34 PM
1:34 PM
skyflyte(at)comcast.net Guest
Posted: Sat Jan 06, 2007 11:20 am Post subject: kitfox2 new builder |
I had this problem many years ago, and after a lot of adjustments, i found the problem. The leather washer had compressed a bit with use, and adjusting the bolt holding the handle to the washer/welded on washer didn't work. The metal pieces were hiting each other before the leather washer could do its job. A thicker leather washer cured the problem.
Mike Cannon
Model II 490MC
From: "Frank Miles" <f.miles.tcp.833(at)clearwire.net>
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /> st1\:*{behavior:url(#default#ieooui) }
Jerry,
Frank
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" />On Behalf Of jerry evans
Jerry Evans
1:34 PM
1:34 PM
5[b]
