prop hub space
capsteve
PostPosted: Fri Jan 05, 2007 2:51 pm    Post subject: prop hub space Reply with quote
I've got my engine hung and am getting ready to fit the cowling, but I don't
have a prop or hub. I do have the spinner, but need to know the exact size
of the constant speed prop hub to ensure proper spacing. I figured I'd be
able to insert a spacer between the spinner backplate and flywheel. I did
check archives and vans does have a note online but I really need to hear
some actual measured dimensions to be able to sleep at night. I'm sure some
would also be interested in knowing if the MT and Hartzel are dimensionally
the same. Any and all input would be greatly appreciated.
Steve
40205
Iflyrv10.com
Coming soon
Fixitauto(at)aol.com
PostPosted: Fri Jan 05, 2007 3:57 pm    Post subject: prop hub space Reply with quote
For the hartzel prop make that space 2.00 in.
Roger 40079
jesse(at)itecusa.org
PostPosted: Fri Jan 05, 2007 7:44 pm    Post subject: prop hub space Reply with quote
If you call a local prop shop they will most likely have an old Hartzell and
maybe an old MT prop hub laying around that they will either give to you or
let you borrow. Just make sure it is a compatible hub for the type of prop
you are using, but I have done this twice and have two Hartzell prop hubs to
work with. Any prop shop will know what hub is compatible with your model
number of prop.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
Cell: 352-427-0285
Fax: 815-377-3694
n223rv(at)wolflakeairport
PostPosted: Sat Jan 06, 2007 7:50 am    Post subject: prop hub space Reply with quote
We used the dimensions on Van's web site to set the cowl for the RV-7 we
built before we had the prop. After we set the prop and reinstalled the
cowl, there was interference. We then had to re-cut the back of the
cowl to the fuselage and re-do that area, which then caused the cowl to
not fit as nice as we would have liked (it puts added stress on the side
hinges). On my -4 and on my -10, we had the prop prior to cowl install
and they both turned out nice.
Not to say it can't be done without the prop, but my recommendation is
to have the prop and spinner on before setting the cowl and you know it
will be right and will be able to sleep at night.
-Mike Kraus
