Canopy Fitting
Eric Tingey
PostPosted: Fri Jan 05, 2007 4:04 pm    Post subject: Canopy Fitting Reply with quote
Group,
I put together a report on the method I developed to fit the Canopy to my CH601 HDS. Not sure how others have done it, but I've heard it is a bit of a trial and error process, this will eliminate that.
Thanks to Dino Bortolin, for his editing of the report.
Eric Tingey
CH601 HDS / Corvair
Canopyfitting[2].pdf
 Filename:  Canopyfitting[2].pdf
 Filesize:  144.21 KB
 Downloaded:  467 Time(s)
601zv(at)ritternet.com
PostPosted: Fri Jan 05, 2007 4:33 pm    Post subject: Canopy Fitting Reply with quote
I'm printing it out now. Thanks for sharing!
Robin in AR
N601ZV reserved
Do not archive.
larry(at)macsmachine.com
PostPosted: Fri Jan 05, 2007 5:37 pm    Post subject: Canopy Fitting Reply with quote
Congratulations Eric,
You've done in one piece what a lot of people have tried to explain a
good number of times with little success.
It's certainly not in the guidance provided by ZAC. I'd recommend you
forward this to Zenith to help them out.
Well done!
Larry McFarland
Eric Tingey wrote:
Group,
Eric Tingey
CH601 HDS / Corvair
