mclayton(at)rochester.rr. Guest
Posted: Sat Jan 06, 2007 6:24 am Post subject: KitFox 2 |
I have just purchased a Kitfox 2, SN 89, which was damaged in a
departure stall. The wings were badly damaged, while the fuselage
structure suffered only minor damage, along with the prop, which was
wood. It has a 532 installed. Does anyone know where I can get
plans, and perhaps parts for rebuilding the wing? The main front
spar appears to be a tube with some kind of I-beam inside. It will
need to be replaced.
I am also planning on putting airfoils on both the vertical and
horizontal stabs, and sealing the gap in the rudder and and elevator.
Mikey
donpearsall Guest
Posted: Sat Jan 06, 2007 9:41 am Post subject: KitFox 2 |
Mikey, it sounds like you have a big project ahead of you. Have you tried
contacting John McBean at http://www.kitfoxaircraft.com/
He may have the plans and perhaps some parts.
Don Pearsall
Posted: Sat Jan 06, 2007 10:13 am Post subject: KitFox 2 |
I just talked to John, and he was extremely helpful! He will be
providing a copy of the original instruction manual, which should be
very helpful. He also answered several questions I had about
increasing the height of the vertical stabilizer and rudder, as well
as installing an airfoil on the horizontal and vertical surfaces.
Parts-wise, it appears as though some of the parts that will be hard
for me to fabricate may be available.
Mikey
On Jan 6, 2007, at 12:40 PM, Don Pearsall wrote:
<donpearsall(at)comcast.net>
tried
Don Pearsall
