		wingnut
				 Posted: Sat Jan 06, 2007 4:23 pm    Post subject: Question for PDA GPS users: Hooking up power. |
				I'm adding a PDA GPS to my Model 4 and I'm kind of stuck on how to wire power to the PDA. I have a cigarette lighter adapter for the PDA but I don't really have a good place for a cigarette lighter plug in my panel (not to mention how ugly it would look). Ideally, I'd like to do some kind of permanent setup with the PDA's power cable, tucked and tie wrapped neatly into the rest of the harness. Problem is, the PDA is 5V so I can't just wire it into the buss. I suppose that I can hack the lighter adapter and tie wrap it to the frame somewhere behind the panel but I’d like something a little more ‘aircraft’ quality.
 I know there are other PDA users out there so I was wondering if someone had a suggestion.
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		dave
				 Posted: Sat Jan 06, 2007 5:46 pm    Post subject: Question for PDA GPS users: Hooking up power. |
				I have a 4 way cig adapter under dash on right side and the adapters plug
 into that for Intercom, radio and GPS....
 the Adapter is hard wired into master.
 Dave
  _________________ Realtime Kitfox movies to separate  the internet  chatter from the truth
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
		Graeme Toft
				 Posted: Sat Jan 06, 2007 5:57 pm    Post subject: Question for PDA GPS users: Hooking up power. |
				I have the Garmin iQue and had similar issues to yourself. In the end I
 fitted the lighter in behind the dash and fed the supply wire out to the
 docking station through a small hole in the dash. Looks OK and is a
 permanent fixture. I can use the lighter for other things such as air
 compressors, lights etc when camping. Its a good compromise.
 Graeme
		lcfitt(at)sbcglobal.net Guest
				 Posted: Sat Jan 06, 2007 9:53 pm    Post subject: Question for PDA GPS users: Hooking up power. |
				Just a thought here.  This may not be significant for you.  There was a post
 in the Lancair list some time ago about using PDAs and Laptops in airplanes.
 It seems that if the memory is hard drive based, there isn't enough air
 pressure to keep the read/write arm on the hard drive from coming in contact
 with the drive disk above about 10,000 ft.  Several guys reported disk
 crashes - destroyed the disk - in their personal experience.
 I found that an IPOD that I intended to use to record the sometimes crazy
 air to air talk in our group trips would crash predictably on every trip We
 were often at or above 10,000 ft..  The stated altitude limit is 10,000 ft.
 and is a hard drive problem.  If your PDA has solid State memory or if your
 not flying in the Western third of the US - probably no problem.  Most Ipod
 users will find that after a return to a lower altitude, the thing works
 normally again.
 Lowell
		Michel
				 Posted: Sun Jan 07, 2007 4:17 am    Post subject: Question for PDA GPS users: Hooking up power. |
				On Jan 7, 2007, at 2:56 AM, QSS wrote:
  	  | Quote: | 	 		   I have the Garmin iQue and had similar issues to yourself.
 This is interesting, Graeme, I also have the Garmin iQue M5 (with
 PocketFMS) and, like you, I installed a lighter socket behind the
 panel. I also use it for other purposes - when on the ground - like,
 recharging the battery of my cell phone. Always needed when on
 cross-country flights of several days.
 Cheers,
 Michel
		Float Flyr
				 Posted: Sun Jan 07, 2007 6:23 am    Post subject: Question for PDA GPS users: Hooking up power. |
				On the 'Fox it's easy enough to remove the top cowl and install the power
 outlet behind the instrument panel.
 There are tow points that I didn't see in the other posts.
 1 if possible wire the power outlets through a circuit breaker of no more
 than 5 A.  That will be enough for a small radio and the PDA.
 2 there is a difference between a power outlet and a cigarette lighter.  The
 cigarette lighter has a small clamp to hold the lighter in until it gets
 hot.  The power outlet does not.  If you buy one of these multiple outlets
 they are usually one cigar and three power outlets.  Be sure to cover the
 unused outlets and use tie wraps, Coraseal or wax string to hold the DC
 adapter securely in place.
 The guy who built my plane smoked like a tilt.  There is a cigarette lighter
 right on the dash.
 Noel
 [quote] --
  _________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
		Float Flyr
				 Posted: Sun Jan 07, 2007 6:25 am    Post subject: Question for PDA GPS users: Hooking up power. |
				It can also be used to trickle charge the plane's battery.
 Noel
 [quote] --
Kitfox III-A
		flier(at)sbcglobal.net Guest
				 Posted: Sun Jan 07, 2007 6:33 am    Post subject: Question for PDA GPS users: Hooking up power. |
				I use an L-shaped bracket behind the cluster with the cigarette lighter
 facing downward.  Keep in mind that some (older) battery powered devices
 like some handhelds and GPSs will backfeed when the master is off and that
 will drain the batteries in the device so unplug it.
 For 5V items with less than a 1A draw a 7805 voltage regulator and 2 caps is
 all that's required for a cheap and simple 12V conversion to 5V.  I do this
 all the time for PDA power.
 The LM350 is a 3A adjustable (3 terminal) regulator that with just a few
 more components can give you whatever voltage conversion you want.  I use
 these to power XM radio receivers and such from 12V.
 If an off-the-shelf auto adapter is more than $10 you're paying too much.
 As far as HDDs and altitude go, the comments in the other messages are
 correct for most of the drives out there.  I'd recommend using a flash-based
 device (like most PDAs).  There are high-capacity flash hdds available now
 if you have a notebook that you just have to have to fly.  Flash also takes
 away most of the vibration concerns.
 Ted
		wingnut
				 Posted: Sun Jan 07, 2007 6:53 am    Post subject: Re: Question for PDA GPS users: Hooking up power. |
				Thanks for all the help guys.  I like the idea of being able to use the power outlet to trickle charge the main battery. There's one snag though; In order to do this, the power outlet would have to bypass the master switch so I wouldn't be able to turn it off. Most of these car adapters draw some current even with no load so I'll have to remember to reach under the panel and pull the adapter or it will drain my battery.
 I think what I'll do is start off with the power outlet but eventually transition to some sort of DC to DC converter like one of these: http://www.powerstream.com/dda.htm
 It's a bit expensive at $30 but it's a nice package with integrated mounting flanges making it easy to bolt to the firewall. I tried using a 7805 and but was getting rather hot to the touch with just the PDA attached. I was surprised but when I looked up the specs I found that they're limited to 400mA. That's right on the edge of what my PDA is drawing at full bright.
 Thaks again for all the help.
 -Luis
		Float Flyr
				 Posted: Sun Jan 07, 2007 11:09 am    Post subject: Question for PDA GPS users: Hooking up power. |
				Correct you would have to leave the master and the power outlet breakers in
 to trickle charge the battery...Max current 70% the amp value of the
 breaker.   Remember to pull the breakers on everything else.
 The DC to DC adapters do consume a small (almost tiny) amount of current
 even while under no load but that is why you have master switches and as I
 recommend an accessory beaker between the power outlets and the main buss.
 You could use several 7805 in parallel to attain the current you will need.
 Keep a good heat sink on all of them.  I used one on a converter I built for
 a digital camera.  I could get three pics before the circuit board got too
 hot for my liking.  The answer was to install a resistor in series with the
 camera to reduce the load at the converter.  I didn't mind waiting an extra
 second or two for the camera to cycle.  It's been working well for just
 under ten years now.
 Noel
 [quote] --
Kitfox III-A
