nuckollsr(at)cox.net Guest
Posted: Sat Jan 06, 2007 10:32 pm Post subject: "Broken and Garbled" (Additional data) |
I think it's one of those once-in-a-blue-moon or perhaps in-our-fondest-wishes
kinds of advertising. We see it a lot when manufacturers talk about the wattage
of their audio systems. The $low$ hand-helds have transmitters that run in the
100 mW range. Some $high$ transceivers for the $licensed$ service may be
allowed
to run more . . . I haven't dug out the rules on this.
But consider the 100 mW case by punching numbers into a path loss calculator
at:
http://tinyurl.com/y9tte2
Use 0.1 watts, 14 km (about 10 mi) and 450 Mhz.
Use 0, 0 and -3 for transmit and receive antenna values
Use 0 for "other losses". Hit Calculate.
We see that this gives us a 4 microvolt signal at the
receiver end. A really good receiver can be barely
useful at about 1/10th this value or 0.4 microvolts.
This means that assuming the receivers in these $20 handhelds
are capable of 0.4 microvolt performance, we can tolerate
20 db of "other" losses over a 10 mi course and still communicate.
It would be interesting to evaluate these radios in the lab
but the ones I have don't have coax connectors where the antennas
go such that one might easily evaluate real transmitter power output
and real receiver performance. Given the less-than-ideal
antennas and poor probability that the power and sensitivity
numbers are equal to the example cited, I doubt that the
radios I've been using can be expected to produce useful
performance at the "advertised" ranges.
One can purchase much more expensive radios that operate
in this service. It's reasonable to expect some
improvements in performance, but it's still difficult to minimize
"other" losses in the communications path.
Most of the radios I've purchased were the $lowest$ I could
find because my path-lengths of interest ran from a few feet
to perhaps 50 yards. I often use them to communicate with
a technician in the cockpit while I'm working in the "hell-hole"
of an airplane. The poorest performing was good for perhaps
100 yards between vehicles on the highway and the last set
I bought are much better. They are usable out to 1 mile if
the two cars can see each other.
Idealized conditions are generally used when you're being
seduced into buying the critters. Real-world performance
and non-idealized path loss conditions are an all together
different matter.
cjensen(at)dts9000.com Guest
Posted: Sun Jan 07, 2007 4:03 am Post subject: "Broken and Garbled" (Additional data) |
Since I just happen to be in the market for a half-dozen walkie talkies
for a project, is there any concensus on the best, cheap unit....Cobra
MicroTalk? Motorola TalkAbout? Or, are they really all about the same.
I'm buying cheap as after a week, they are a Good-Will donation.
Chuck Jensen
