lcottrell
Posted: Sun Jan 07, 2007 3:16 pm Post subject: radio noise |
I attempted to put a capacitor, 4700, on my 12 volt line between the
regulator and the battery. I had some trouble with my EIS showing the right
RPM's. I had figured that I had wired it up backwards, so I made sure that I
connected it correctly and still had the same problem. Where have I erred?
Max RPM's showed was 350.
Larry,Oregon
HShack(at)aol.com Guest
Posted: Sun Jan 07, 2007 6:02 pm Post subject: radio noise |
In a message dated 1/7/2007 6:17:27 PM Eastern Standard Time, lcottrell(at)fmtcblue.com writes:
| Quote: | I attempted to put a capacitor, 4700, on my 12 volt line between the
Larry,Oregon
do not archive |
It should be an "electrolytic" capacitor. There should be a "+" & a "-" printed on it. It should be connected in parallel to your battery. It should be rated at a minimum of 25 volts.
Good luck.......
Howard Shackleford
FS II
SC
Posted: Sun Jan 07, 2007 6:03 pm Post subject: radio noise |
Larry,Oregon
do not archive |
Howard Shackleford
FS II
SC
