Tim_Lewis(at)msm.umr.edu Guest
Posted: Mon Jan 15, 2007 4:37 pm Post subject: RV-10 - Bushing installation in flap supports |
Listers,
There's apparently a revision to RV-10 plans page 22-8 (rev 1) that is current, but has not been posted on the "revisions" page at Van's web site. It involves the little brass bushings that go in the flap supports. Attached photo shows the revision.
Tim Lewis -- HEF (Manassas, VA)
RV-6A N47TD -- 850 hrs
RV-10 #40059 under construction |
269.84 KB |
182 Time(s) |
deruiteraircraftservices( Guest
Posted: Tue Jan 16, 2007 3:47 am Post subject: RV-10 - Bushing installation in flap supports |
Hi Tim,
You have one of the earlier kits out of the first two batches that were produced by Van's judging by your kit number. From at least number 400272, maybe earlier REV 1 is in the kit.
Marcel
billderou(at)yahoo.com Guest
Posted: Tue Jan 16, 2007 1:05 pm Post subject: RV-10 - Bushing installation in flap supports |
I have kit #29 and did receive the bushings. It was a while ago but I think they may have been shipped seperately. The bushings did fit perfectly without modifications but must be inserted after the wing skin is complete as the slot in the skin will not pass through the flap support with the bushing installed.
billderou(at)yahoo.com (billderou(at)yahoo.com)
N939SB, flying
RAS <deruiteraircraftservices(at)btinternet.com> wrote:
[quote] Hi Tim,
Marcel
John Ackerman
Joined: 19 Jun 2006 Posts: 130 Location: Prescott, AZ
Posted: Tue Jan 16, 2007 8:38 pm Post subject: RV-10 - Bushing installation in flap supports |
On kit 458, the skins can be made to pass over the installed bushings, but it will make you pucker!John
On Jan 16, 2007, at 2:05 PM, Bill DeRouchey wrote:
[quote]I have kit #29 and did receive the bushings. It was a while ago but I think they may have been shipped seperately. The bushings did fit perfectly without modifications but must be inserted after the wing skin is complete as the slot in the skin will not pass through the flap support with the bushing installed.
