owl40188(at)yahoo.com Guest
Posted: Tue Jan 16, 2007 7:18 am Post subject: Cabin cover fit pictures |
For those interested I have attached some Cabin Cover fit pictures.
Niko
40188
49.89 KB |
198 Time(s) |
54.21 KB |
188 Time(s) |
56.29 KB |
172 Time(s) |
44.98 KB |
175 Time(s) |
52.99 KB |
185 Time(s) |
49.83 KB |
174 Time(s) |
46.56 KB |
171 Time(s) |
60.15 KB |
179 Time(s) |
52.57 KB |
198 Time(s) |
cloudvalley(at)comcast.ne Guest
Posted: Tue Jan 16, 2007 8:42 am Post subject: Cabin cover fit pictures |
Hello Niko,
My wife and I have just finished building our empennage kit; we have not ordered the rest of the kit yet. We are interested in the canopy/cowl discussions. Are these pictures you have of the fiberglass canopy? We are not sure what will transpire with Van's QC on theirs, or if you or someone will come up with something else. ( read your post about graphite). We are really naiive about this whole process, and are hoping this canopy/cowl problem will be resolved by the time we buy the rest of the kit. Thanks for your input.
Brian and Ruth Preston
#40666
| Quote: | -------------- Original message --------------
Niko
40188
millstees(at)ameritech.ne Guest
Posted: Tue Jan 16, 2007 9:06 am Post subject: Cabin cover fit pictures |
I have been following the thread about the quality of the canopy with some consternation;
1. Graphite is currently in very short supply, and consequently the price is unreasonably high, if you can even locate it. The likelyhood of finding enough to build even one canopy is problematic. The outlook is not much better, because Boeing is grabbing up everything on the market.
2. I built a glass airplane a few years ago, and compared to the quality I got on that kit, the Van's canopy is excellent. Fiberglass requires shaping, and lots of surface preparation. To expect a bolt on fiberglass part is unrealistic, and contrary to the whole idea of kit building.
Steve Mills
RV-10 40486 Slow-build
Naperville, Illinois
finishing fuselage
[quote] --
mritter509(at)msn.com Guest
Posted: Tue Jan 16, 2007 9:43 am Post subject: Cabin cover fit pictures |
Steve,
Have you received your canopy?
[quote]From: <millstees(at)ameritech.net>
Subject: RE: Cabin cover fit pictures
Date: Tue, 16 Jan 2007 11:05:09 -0600
consternation;
Steve Mills
finishing fuselage
Posted: Tue Jan 16, 2007 10:35 am Post subject: Cabin cover fit pictures |
As one can see from the pictures I am well into making Vans cowl fit and I am not planning on a graphite cover. I have about 30 hrs into sanding and fitting it and there are many hours left before its done although given the build times that some people have quoted I consider myself a slow builder. What makes it inconvenient for me is that two people are needed to fit the Cover. So I can't just sand a bit and then fit it take it off resand refit etc. Each time I try to fit it I need a helper. I have probably trial fit it about 8 to 10 times now. By the way, as a data point on the high end I have 2100 hrs into this kit now and I believe it will take somewhere in the 3000 to 3500 hrs to complete.
The difficult part about making a graphite one would be making the tool. I haven't looked at getting graphite at all but most aircraft manufacturers purchase the high end of the graphite fibers with the medium and low strength ones being sold for things such as skiis, tennis racquets, golf clubs etc. I believe the fiber that doesn't meet the specs of the airframe manufacturers is sold as lower grade. The supply for the high end fibers might be tight and at the same time the supply of the medium to low end fiber might be plentifull. Don't really know though maybe someone else can chime in here.
Niko
40188
Slow-build kit & builder
AV8ORJWC
Posted: Tue Jan 16, 2007 10:39 am Post subject: Cabin cover fit pictures |
I appreciate Steve's contrarian view and consternation. A balance in intelligent conversation is a good thing. So was the comment on corrosion.
Each may be found to be baseless but is heartfelt and therefore worth reading. Toray is the supplier, the shortage is only when buying hundreds of bolts of production for commercial airliner manufacture (we use the stuff at work every day)and only momentary in time as to supply shortages. It is not holding up Boeing sales one iota.
The world of plastic planes has come a long way from Styrofoam glued slabs, hotwire and paper cup mixing process in darkened garages. The White Knight was a great example. The heavens are now our limit. Fitment and finish is a matter of mold building, quality control and where the labor is applied. I feel many would like to take advantage of the QB concept on labor application, just like doing repetitive rivets on the umpteenth wing rib. The marketplace will sort out each person's place. The 51% rule should insure that each builder has the knowledge and skill set to maintain the safety and airworthiness of their kit.
I respectfully conclude Steve that if VANS canopy is of higher quality than your workmanship on your last aircraft, we are talking totally of different issues. Integrated roll bars, air distribution plenum with overhead lights and switches, fitment to within 0.010", improved placement and adhesion of windows, advanced door hinges and lockable latch assemblies are the improvements being considered. Oh yes, don't let me forget the work Dave McNeill did on improved shoulder harness mount points. Did I mention dozens of hours not washing off fiberglass dust from your arms and purging your respiratory system to catch a breath.
Carbon fiber is superior for antenna ground planes and static dissipation. The wingtips would likely remain fiberglass for antennae concealment. A simple tape of fiberglass impregnated resin has resolved the contact between dissimilar materials on the nobility table for performance military aircraft for years. I am confident that corrosion is not going to be an issue. The product will not be for everyone. Nor is it intended to be. There may be some who would actually like to build their own mold and lay it up. To each their own product.
I suspect Mark's question was answered within your response.
John Cox
#40600
james.k.hovis(at)gmail.co Guest
Posted: Tue Jan 16, 2007 11:38 am Post subject: Cabin cover fit pictures |
John,
Good comments. I have a question related to this discussion, how
"conforming" is the Van's design to the crashworthiness requirements
of FAR part 23 as they relate to roll-overs in a crash? Looking at
these pictures, I really wonder how well the cabin top will hold up in
a roll over. Carbon-epoxy (even the low grade stuff) is tons stronger
and more impact resistant than glass-epoxy matrix. Van's takes pride
in pointing out they design to part 23 requirements and show static
testing of a wing as proof. Note: Part 23 roll over requiremetns after
inverting on the ground are 3.0 g vertical load with a .5 cof of
friction sliding load (23.561) after surviving a 9.0 g longitudinal
crash impact. This means the top (VT contacting ground) has to
withstand 8,100 # of vertical load while also withstanding 4,050# of
sliding interial load in the forward direction. Seems a couple peices
of steel tubing or a few layers of carbon epoxy placed in strategic
positions would greatly enhance crash strength.
Carbon fiber and fiberglass lay-up is essentially the same, both
require a mold. Unless the latest automated carbon fiber layup robots
are used, I don't think you'll see any better quality (where the cabin
top meets the aluminum structure) that you are seeing today with a
hand-layup process regardless whether carbon or fiberglass is used.
Remember, you are fitting an item that has a certain level of process
and dimensional control to items that are made by different processes.
Aluminum forming processes (i.e. drop hammer die, hyrdoforming on form
blocks, or brake forming) is capable of holding tighter profile
tolerances than most hand layup composites. This is why you'll see
mismatches and such between the cabin top and the Al strucutre and
will need to do some hand fitting.
their own product.
John Cox
#40600
Posted: Tue Jan 16, 2007 12:14 pm Post subject: Cabin cover fit pictures |
I would think that Boeing would be soaking up all the pre preg material and
not the hand layup stuff.
As a side note, I wonder if Van's used one of their 10s to make the tool for
our parts. When I visited Van's in the beginning 06, I took photos of both
10s and as I remember, at least one of them did not have finish work on it
that was of good enough quality to pull a mold from so it must be that the
mold was made from the original mockup and that was what was used to
fabricate the tops for both of their 10s and probably our tops.
IMO the best way to make a good mold would be to pull a mold off a perfectly
blended, perfectly finished 10 with the doors and everything in place. Mark
the seem lines between the window, doors and fiberglass/aluminum interfaces
and then later mark the molds on the outside of these scribe lines to give
the builders a little wiggle room.
Again, some of the observations some buiders are finding are QC issues, but
some of the fit issues might not only be an issue of original tools shape
producing a questionable mold, but there are shrinkage issues with the part,
and also variances between each builders fuselage(Longeron shape).
It is damm amazing that all this stuff goes together aswell as it does. I
understand that even LanceAir's prepreg parts need a lot of tweeking to get
them together.
Unlike Lance Air, the glider manufacturers don't pull parts out of molds
until the part has been closed up. Top and bottom of wing, right and left
halves of fuselage, etc. The molds are indexed so they fit together with the
parts inside them and then they are glued and left inplace for some time to
fully cure.
I too am not looking forward to fitting my top and then the doors. I should
be starting soon.
For those looking for a better solution, there may never be one so maybe
just count on putting in the time and anticipate sore shoulders, elbows and
hands. Itchy skin is fun too.
John G. 409.
consternation;
Steve Mills
finishing fuselage
AV8ORJWC
Posted: Tue Jan 16, 2007 12:51 pm Post subject: Cabin cover fit pictures |
I am confident (without any knowledge to the contrary) that VANS initial
testing of N410RV met the requirements of FAA FSDO NM-09 and the Seattle
MIDO. I have no such quantitative information on N220RV or the
replacement canopy for N410RV after the door issue. Same individuals who
will approve the replacement unit made of carbon fiber of improved
strength, conductivity and lighter weight here in Orygun. Less weight
on top, more room for heavies like me or enhanced and remotely mounted
avionics. I would wager that most completed riveted aluminum fuselage
and empennage kits are pretty darn close on exactly same dimensions. I
would further state that from canopy to canopy they are a WAG different.
Having seen the clear difference by a part made of equal strength of MT
fiberglass and that of Company X carbon they are dimensionally thickness
and weight, light years dissimilar.
A careful review of a side view on most finished RV-10s will find a
distinct break at the transition between the fiberglass matrix and the
top of the empennage. Proper use of flox, fiber or stress transferring
threads will assist in the needed transition.
John Cox
the Turbanator #40600
Rick S.
Posted: Tue Jan 16, 2007 1:12 pm Post subject: Cabin cover fit pictures |
I think Steve is right on regarding quality,
Having sat back and watched all the cabin cover bashing for the last few days it seems everyone has different perceptions of quality....yes the interior has veins that need sanding...sand them off, learn a new skill called body work and move on to the next step. I didn't care for working on my top but (read itch and dust)...it's a part of the build so in order to fly this thing you have to get past it.
It's not like anyone tried to hide the fact there are substantial composite parts on the RV-10. I didn't open my fuselage kit and say HEY!!! what's this big green thing!! If this is your first time working with fiberglass, let me tell you, it sucks. If you REALLY like it, you might have a nice selection of whips, chains and handcuffs in your closet!! But it ain't that bad.
It wasn't my first time working with composites so no surprises here. FWIW the top is very smooth and typical of the finish I've seen on raw glass work on race cars and boats. Yes the bagged side is rough, not sure it could be much better considering size and shape. It's the nature of the beast. Pinholes are a fact of life in glass parts. Cirrus will sell you a nicely finished fiberglass cabin top but then you'lll miss out on all the education you will receive performing your own body work pluis saving more than a hundred thousand dollars as well.
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
Posted: Tue Jan 16, 2007 1:45 pm Post subject: Cabin cover fit pictures |
I think I may have started this rough canopy discussion, and I'll go
ahead and say that I just went ahead and made it fit. I got messy. I
put it on there and took it off quite a few times. It fits. I'll make
it smooth, and it'll be neato. It's my first time working with glass,
but metalworking tools make quick work of it. It also makes quick work
of my metalworking tools Initially, I was worried about strength,
but after I got it fitted, it seems that like everything else on the
aircraft, once it's connected to the surrounding structure, it's pretty
tough. I've been having fun pretending that I'm coming in from a
blizzard when I'm done with a cutting session. Covered in "snow". Yay.
cj
#40410
fuse
www.perfectlygoodairplane.net
Posted: Tue Jan 16, 2007 2:20 pm Post subject: Cabin cover fit pictures |
Well I'm well past it and the canopy came out looking great - but could have
done with a little less education on fiberglass work.
Mark (N410MR Flying)
| Quote: | From: Rick <ricksked(at)earthlink.net>
Date: Tue, 16 Jan 2007 13:12:13 -0800 (GMT-08:00)
that bad.
Rick S.
40185
Posted: Tue Jan 16, 2007 2:30 pm Post subject: Cabin cover fit pictures |
Mark:
Yes I have received my canopy, and will begin installing it in about a
month.
Steve Mills
finishing fuselage N750SM (reserved)
Posted: Tue Jan 16, 2007 3:04 pm Post subject: Cabin cover fit pictures |
Steve,
Installing the canopy, doors and windows take some time (fitting, sanding,
fitting, sanding and more fitting and sanding) but the end product (a flying
RV-10) is more than worth the effort. The nice thing about fiberglass as
opposed to aluminum is that voids, dings and other imperfections can
generally be fixed. I had plenty of each but at the end of the day it all
came out looking great. A little flox and/or micro balloons can smooth over
most problem areas.
Best of luck on working your way through the process.
Date: Tue, 16 Jan 2007 16:27:59 -0600
Mark:
month.
Steve Mills
Rick S.
acs(at)acspropeller.com.a Guest
Posted: Tue Jan 16, 2007 7:00 pm Post subject: Cabin cover fit pictures |
I'll own up.....I use compressed air to get all the fibreglass dust off
me.....and then a leaf blower to remove from the clothes on the washing
line....and then the pool filter...
A bit like a Cat In The Hat story.
John 40315 do not archive
rvbuilder(at)sausen.net Guest
Posted: Wed Jan 17, 2007 7:56 am Post subject: Cabin cover fit pictures |
Hello John,
So is anyone going to develop a "carbon copy" alternative to the fiberglass canopy? My wife are not nearly ready yet; we have only finished the empennage, but we are interested. Please let us know more. Thank you
#40666
[quote]-------------- Original message --------------
[quote] --> RV10-List message posted by: "John W. Cox"
hotwire and paper cup mixing process in darkened ga rages. The White Knight was
door hinges and lockable latch assemblies are the improvements being c onside red.
John Cox
#4060 0
AV8ORJWC
Posted: Wed Jan 17, 2007 10:44 am Post subject: Cabin cover fit pictures |
Yes an aeronautics manufacturer is considering such a product.
It cannot be a “carbon copy”, beyond exact attachment points and exterior detail airflow. The construction features, door hinging, security latching and safety items are (In my opinion) an improvement. To the novice, it would not be identifiable until the door opens.
When the first canopy is installed, it would have to be tested to standards.
John Cox
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of cloudvalley(at)comcast.net
Sent: Wednesday, January 17, 2007 7:55 AM
Hello John,
#40666
> John Cox
> #4060 0
Posted: Wed Jan 17, 2007 11:22 am Post subject: Cabin cover fit pictures |
Us early adopters are missing out on all the good stuff starting to come
down the pike. If this does become available and a builder goes that route
just think of the "fibergalss education" they will miss.
[quote]From: "John W. Cox" <johnwcox(at)pacificnw.com>
Date: Wed, 17 Jan 2007 10:44:04 -0800
It cannot be a "carbon copy", beyond exact attachment points and
standards.
John Cox
Hello John,
Thank you
#40666
balance in
on corrosion.
stuff at work every
not holding up
glued slabs,
White Knight was
finish is a matter
builder has the
quality than your
different issues.
windows, advanced
being c onside red.
improved shoulder
catch a breath.
dissipation. The
between dissimilar
product will not be
would actually
product.
> John Cox
> #4060 0
