kitfoxmike
Posted: Tue Jan 16, 2007 9:08 am Post subject: tail wheel fun |
I thought I would give a report on a little tail wheel experience that I had a couple weeks ago. First off, I have a home builders tail wheel. Second, the temps outside was 25degrees f. I went out to fly and was having a good time doing main wheel touches and decided it was time to land. I came in slow and did a three point land, as soon as I touched I was all over the place, major right then left after correction. I did a go around and tried a wheel landing trying to figure out what was happening, nice and smooth until the rear wheel touched, then it was all over the place again, I came to a stop and taxied a little to make sure the tail wheel was hopefully locked in, seemed to be. I took back off and went to the other runway this time and landed, nice and straight and on track. Got to the hanger and shut down and proceeded to back it into the t-hangar and found the tail wheel was having a terrible time locking in.
I went to the shop and got my grease gun with Amzoil grease. I went back to the hangar and raised the rear of the plane and greased the wheel and made sure all the old grease came out and the wheel locked and unlocked. This made a huge difference on the tail wheel, works perfect now. I suggest the Amzoil grease be used in both the tail wheel and the main wheel bearings. I went and did an experiment and repacked the left wheel and left the right one with the old grease in it. Then I went up and watched the wheels on both take off and wheel touch and goes and wow that left wheel free rolls a lot more than the right, I have the same preload on both. I went and did the right side and it now turns like the left. This stuff is great, expecially in the cold.
kitfoxmike
dave
Posted: Tue Jan 16, 2007 9:58 am Post subject: tail wheel fun |
Mike ,
I find the same on my Matco tailwheel , keep it greased.
I use that blue grease ( lithium ? not sure) , same as we use to sno
machines, farm equip and everything.
Amsoil ? I have no idea but if it is synthetic it is possbile that is will
attract moisture and not repel it.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
kitfoxmike
Posted: Tue Jan 16, 2007 10:09 am Post subject: Re: tail wheel fun |
I also wiped off all grease. Plus I decided to put grease in the wheel monthy. which for me is about 50 hrs. Good note on the lithium grease though.
dave
kitfoxmike
Posted: Tue Jan 16, 2007 10:45 am Post subject: Re: tail wheel fun |
Dave,
great idea, I have a nice vid camera and I want to make some, just too cold and I need to get the boy out on the runway to take pics. I see that you are 47, I turned 49 last August. I also put my heat gun in the hangar for when the door wheels decide to freeze and for any thing like the tail wheel freezing, works good.
kitfoxmike
Posted: Tue Jan 16, 2007 11:11 am Post subject: Re: tail wheel fun |
also, the heat I use is the 1500 watt gun. When I use a heat gun on fabric for those occational wrinkles, I use a heat gun used on monokote for remote aircraft.
Bob
Joined: 24 Oct 2006 Posts: 89 Location: Damascus, Maryland, USA
Posted: Tue Jan 16, 2007 12:43 pm Post subject: Re: tail wheel fun |
I need to forward this to my boss, who owns a nose-wheel RV-9!
Good grief, Dave, how many flights per prop do you get with eating water like that? Seriously, I see that this was a test, but I am curious if you got any erosion of the leading edge and what type of prop it is?
Bob
_________________ Remember that internet advice may only be worth what you pay. |
Michel
Posted: Tue Jan 16, 2007 12:48 pm Post subject: tail wheel fun |
On Jan 16, 2007, at 7:34 PM, dave wrote:
| Quote: | If we get everyone on this list to do a 10 minute movie each - well
then we can get our own site like KITFOXTUBE.com lol
That would be great, Dave, but we already have:
http://kitfox.lazair.com/
with Kitfox video. Should we try to regroup everything in one place?
Cheers,
Michel
dave
kitfoxmike
Posted: Tue Jan 16, 2007 1:22 pm Post subject: Re: tail wheel fun |
instead of being called, response to mowing the grass, it should be boys playing in the mud.
dosmythe(at)cox.net Guest
Posted: Tue Jan 16, 2007 1:47 pm Post subject: tail wheel fun |
Dave,
I was more concerned about an engine seizure rather than a prop. On a
25 degree day going from power off to full throttle can be risky. One other
video was engine off , restart, full throttle (cold day). Don't you worry
about an engine seizure?
Don Smythe
dave
Posted: Tue Jan 16, 2007 2:31 pm Post subject: tail wheel fun |
hehe YUP !!
I used to be big into 4 wheeling in the late 70s to early 80s
I was the first guy to do a 4 x 4 Pinto that was 6 feet tall with 350
HP plus used to do serious off roading.
Dave
Float Flyr
Posted: Tue Jan 16, 2007 2:50 pm Post subject: tail wheel fun |
Lithium is the milky white grease. As the lithium in it oxidizes it gets
darker. Blue may be Teflon.
Noel
Do not archive... Ok.
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
kitfoxmike
Posted: Tue Jan 16, 2007 3:33 pm Post subject: Re: tail wheel fun |
The teflon grease I have is blue and in a can. THis stuff is fluffy, real light, like wipped cream. I use it on the splines in drive lines.
Float Flyr
Posted: Tue Jan 16, 2007 3:53 pm Post subject: tail wheel fun |
I was on the Lazair sight the other night and I don't think it's any where
near back to fully operational.
Noel
[quote] --
Kitfox III-A
Float Flyr
Posted: Tue Jan 16, 2007 4:33 pm Post subject: tail wheel fun |
You got me...
The last Teflon grease I had was believe it or not pink. It turns as hard
as a rock when the temperature drops. I had a small supply of light green
Teflon grease a few years ago. It was the only thing I could use on the
dryer section of photographic processors that didn't pick up all kinds of
dust. I expect there are different weights/types of Teflon grease.... Then
again the label should tell you all you need to know.
Noel
Do not archive.
[quote] --
Kitfox III-A
