		rv10(at)sinkrate.com Guest
				 Posted: Tue Jan 16, 2007 11:16 am    Post subject: James Cowl Question |
				Deems,
 What are you using for a spinner for your James Cowl?
 -Ben Westfall
 Portland, OR
 #40579 – gas tanks
		Deems Davis
				 Posted: Tue Jan 16, 2007 12:28 pm    Post subject: James Cowl Question |
				I ordered a 14" spinner from Aero Composites
 http://www.aerocomposites.com/ , the same place I'm getting my prop from.
 Deems Davis # 406
 Finishing - ( A Misnomer ! )
 http://deemsrv10.com/
 Ben Westfall wrote:
  	  | Quote: | 	 		   Deems,
  -Ben Westfall
  Portland, OR
  #40579 – gas tanks
		rvbuilder(at)sausen.net Guest
				 Posted: Wed Jan 17, 2007 7:10 am    Post subject: James Cowl Question |
				If you go with a MT prop, you can specify the 14" spinner from MT for no
 extra charge.
 Michael
				 Posted: Wed Jan 17, 2007 10:15 am    Post subject: James Cowl Question |
				In my days researching the Lancair ES (when it was still affordable to buy
 their kit and they didn't add the carbon canopy   ) Aerocomposite was the
 blade of choice. I can understand when one is spending 225K for a composite
 plane that 13K (at the time) was nothing, but for a plane close to half that
 price is 14.4K really that much better in performance, appearance or reason
 one would go this way, than an MT for 7-8K?
 Honestly just asking so I know. Not questioning the decision to chose the
 more expensive blade just wondering in my cost cutting if 6K is worth the
 price.. For example, 6K in an engine may produce something to show for the
 difference in price.. what about this blade?
 Pascal
		Tim(at)MyRV10.com Guest
				 Posted: Wed Jan 17, 2007 11:36 am    Post subject: James Cowl Question |
				Pascal,
 When it comes to these specialty add-ons and upgrades, the thing
 to keep in mind is that the generic, plans-built RV-10, with
 only the standard creature comfort add-ons, will be quite a nice
 airplane indeed.  There are possible, and even some definite
 benefits, depending on your needs or desires, that can be had
 by changing props, pistons, cowlings, engines, fuel injection
 systems, electrical ignition systems, and things like that.
 There is one important thing to keep in mind though, for those
 who have any budget worries. In probably most to nearly all of
 these cases, the end-product incremental advantage of these
 things is an extremely small percentage of the already
 nice plane you would have built without those add-ons.
 That's in no way knocking those products, as to the people
 with them, they may place higher value on those features
 than other builders.  Some people like pretty 3-blade props,
 some like electronic ignition, and so on.  The chance though,
 that you'll actually gain truly *meaningful* measurable
 differences in knots, or many other measuring sticks, is really
 small.  So for those on tight budgets, you're not losing much
 by going with the basics.  That might be blasphemy to those
 who truly love the upgrade, but honestly, the value added
 is not "necessity"....it's in their personal desire.
 For me, the most desirable upgrades were the electronic
 ignition and fuel injection, allowing a great running
 engine at low fuel flows. The rest was gravy.   The
 interesting thing is, I would bet that even if someone
 picked the best prop, best cowl, Hi comp pistons, F.I.
 and Elect. Ign., and a few more goodies and did them ALL,
 they're still talking about owning a plane that flies
 probably within 0-10 kts of the other guy, and both
 guys will love their planes.
 I myself am looking at hearing the results of the cowl tests,
 because if those can statistically prove that ALL of the
 proposed benefits come true, then I'll consider a cowl
 swap at the right time and price in the future...it'll
 depend on the actual numbers though, as I've already
 determined that I've got plenty enough enjoyment factor
 for me.
 So that doesn't answer your question, but just rest assured
 that however you build it, you will probably find very
 acceptable in the end.
  buy their kit and they didn't add the carbon canopy   ) Aerocomposite
  was the blade of choice. I can understand when one is spending 225K for
  a composite plane that 13K (at the time) was nothing, but for a plane
  close to half that price is 14.4K really that much better in
  performance, appearance or reason one would go this way, than an MT for
  7-8K?
  the more expensive blade just wondering in my cost cutting if 6K is
  worth the price.. For example, 6K in an engine may produce something to
  show for the difference in price.. what about this blade?
  Pascal
				 Posted: Wed Jan 17, 2007 5:52 pm    Post subject: James Cowl Question |
				One value of the more expensive prop, of course, is perceived value.  One car is perceived more valuable than another sometimes just because it cost more, not necessarily because it is better.  If you gain performance with the 14.4K prop, I doubt it will be 8K worth (all IMHO).  For that price you could get two Hartzels and have a 4-blade. J I personally have an aversion to composite props, but that’s all I say.  My dad was with an organization in Mali with a Caravan with composite props and they didn’t last worth anything with the sand.  That was a long time ago, but the memory sticks.  So, I would recommend going with the aluminum cheap prop, but that’s just me.  The composite looks cool, but at 2,700rpm and 200mph, you’ll hardly notice.  Oh yeah, and with the aluminum prop you don’t have to do all the pinhole filling and sanding.  That’s enough of a reason in itself. J
 Do not archive.
 Jesse Saint
 Saint Aviation, Inc.
 jesse(at)saintaviation.com
 www.saintaviation.com
 Cell: 352-427-0285
 Fax: 815-377-3694
		Deems Davis
				 Posted: Wed Jan 17, 2007 7:45 pm    Post subject: James Cowl Question |
				If you go and check the race results for AirVenture cup you will find
 that the winners and top finishers have two things in common. A James
 cowl/plenum, and an Aero Composite Prop.
 Deems Davis # 406
